Results 1 to 12 of 12
    Titusville, Florida
    Default Kent AL flywheel, Pressure Plate, clutch disc
    1 each Tilton 50-107 110 tooth aluminum flywheel $300 (very good to excellent condition)
    1 each Borg & Beck Standard FF pressure Plate $50 (good to very good condition with no flaws in friction surface)
    1each Standard FF clutch plate. This plate was installed but never used because car was put into storage. $40
    585-615-2755
    Savannah, GA (via Montreal)
    Liked: 987
    curious, is there a Vintage group running Kent's that allows an aluminum flywheel?
    (sorry if I'm out of touch)
    Powhatan, VA
    Liked: 168
    I'd imagine you could run them in Kent based sports racers and such. Lotus 23s for example ?
    Titusville, Florida
    I have no idea. This was purchased for a B-MOD Solo II car and was mounted on a Lotus Twin Cam engine. It is in very good condition so hopefully it can find a new home.
    Liked: 987
    good point, my FFord bias showed through there; vintage sports racers probably have looser rules :-)
    Deep River, Ontario, Canada
    Liked: 153
    Default Flywheels
    Hi Ian. If you have been around long enough and like to sleep at night you run the class/group rules. Within a smidge obviously. I know you would never think otherwise. If 'they' want a trophy that bad good on them. 2 years later they will be history anyway.
    Cheers. Ken.
    Calgary
    I will take the flywheel.
    George Murray
    Liked: 987
    Quote Originally Posted by Robins Ken View Post
    Cheers. Ken.
    Good point Ken, but it is a 3 second job to try a magnet on the face of the flywheel on a Kent :-) cheers
    Liked: 153
    Yes you could easily do that from underneath on a VD.
    I have a story. There was a flywheel that had a beryllium insert . Made the rule book weight. Cdn. F1600 years ago. Yes, I was running my team that weekend.
    Best. Ken.
    Liked: 987
    Best. Ken.
    let me guess ... Jacek?
    Liked: 153
    Same guy who took the surplus F1 fuel one year after the GP. And put it in a Kent. Had to buy a new fuel cell.
    Liked: 712
    Default F/Ford
    I knew a guy who did that in the 80's, early Turbo F1 era. Of course, it didn't run right and he couldn't figure out why the spark plugs looked like they were burning coal oil.
    For those who don't remember, F1 mandated that fuel could not be added during a race. To keep their power advantage over the normally aspirated engine teams, fuel suppliers to the Turbo F1 teams figured out how to make one gallon of fuel act like two (or more). He even tried cutting it with regular gas but it was still too much for a F/Ford to burn..
