Page 9 of 11 FirstFirst ... 567891011 LastLast
Results 321 to 360 of 434
  1. #321
    Classifieds Super License Dave SanF 50's Avatar
    Alameda in SF Bay area (CA)
    Liked: 46
    Default Welcome to Thill
    This is the FF section so I believe that accounts for the lack of responses to your query.
    For a FA, I'd gear for a slowest corner around 45 mph (T5 & T11) and a top speed around 145 mph entering T1. Track record for a FA is 1:38.461 which is an average of 104.7 mph.
    hope that helps.
  2. #322
    SF bay area
    Liked: 6
    Hi Joules,
    I had the FA record for Thunderhill from about noon on the first SCCA day at the track until the next morning when Nancy James qualified. But I've been racing FF with Dave Jalen for about 15 years so FA is a dim memory. I ran a Ralt RT5 super Vee as Atlantic. I had the allowed 1835 motor, which peaks a lot lower than the Cosworth or Toyota, so I think my gearing would be useless to you. Dave mentioned 145 turning in to T1, which is a bit of an exaggeration. The Super Vee has a lot less drag than a "real" FA, so it gets up to about 142. The last time my car was run, it was visibly pulling away from a Swift 014 at that point every lap. I suspect the Swift was getting 135 or so. You should set 1st gear for the exit of T11 which is around 35. I hope this babble was some help.
    Mike
    P.S. my Ralt is leading a simple life as a vintage car
  3. #323
    Haslet, TX
    Default What happened to the attachment???????
    Hi Folks,
    Didn't we used to have a great table of tracks and gears as the attachment to this thread? Any idea what happened to it? The current attachment is a track layout...
    Bill
  4. #324
    Senior Member cliff's Avatar
    kansas city, MO
    Default Brainard gearing
    Any input about brain are gearing would be appreciated. Top speed?
    Thanks in advance
    Cliff
  5. #325
    Contributing Member racingflyboy's Avatar
    Frisco, CO
    Liked: 86
    Default Bainerd gearing
    Hi Cliff-
    Here's what I normally ran at BIR. (I have a 9:31 diff) 1st: 19:32, 2nd: 20:27, 3rd: 21:24, 4th: 24:24 (on the "new" 2..5mi course. Ran 25:24 on old 3 mi. with the mile long straight plus high banked turn 1 - flat out until T3!) Top sped? You'll be around 130.
    Have fun there. Tony "Fubar" Foster and Ethan Mackey are very experienced there, talk to them when you get there. Tell I sent ya!
    Steve Barkley
    1969 Palliser-Winkelmann WDF1 FF1600
  6. #326
    Liked: 438
    Default Track Gearing
    Hopefully I have attached an Excel doc I have with a bunch of gearing for different tracks. OK, so that didn't work. Is there a way to upload an Excel doc? If not is there somewhere I can place it. OR I can email a copy to anybody who wants one.
    Graham
  7. #327
    Member Angus's Avatar
    Tyler, Texas
    Default MSR Houston Gearing
    Does any one have FF gearing for MSR Houston? Haven't run there before.
    Many thanks!
  8. #328
    Junior Member 32F Racer's Avatar
    Willis, Texas
    Quote Originally Posted by Angus View Post
    Many thanks!
    I will pull my records for MSR that we run for our car. We are running a 9:31 R&P.
  9. #329
    Willis, Texas
    Default Coronado Fleetweek
    We will be running SVRA Coronado Fleetweek in a couple of weeks and I am looking to find a gear ratio to run out there. I have a 1977 Crossle 32F with a 9:31 R&P in it.
    Thanks for the help
  10. #330
    Sagle, Idaho
    Liked: 186
    Publish as PDF Document.
    Step 1 Launch Excel. Open the Excel worksheet you want to publish.
    Step 2 Click the "File" tab. Click the "Save As" icon.
    Step 3 Click the down arrow in the "Save as type:" list box. Select "PDF" from the list of file types.
    Step 4 Click on the "Standard (publishing or printing)" radio button labeled: "Optimize for."
    Step 5 Type an appropriate name in the "File name" input box.
    Step 6 Press the button labeled "Save" to create the PDF file.
    Lawrence Hayes
    Hayes Cages, LLC
    Sagle, ID.
  12. #331
    Willis, Texas
    Quote Originally Posted by 32F Racer View Post
    Thanks for the help
    Still waiting for some help with this. Just want to make sure I have time to order gears if need be.
    1977 Crossle 32F
    with training wheels
  13. #332
    Liked: 1069
    Default PM me
    Justin,
    Send me a PM or email. You may have to activate the function in your profile.
    Dan
  14. #333
    Contributing Member trout roberts's Avatar
    Tucson, AZ. Formerly from the Pacific NW
    Default Nola & cota
    I'm going to be running the SVRA races at New Orleans and at COTA.
    1981 Crossle 45F with 9:31 R&P and about 60 lbs of ballast in the driver's seat.
    I'll be running Toyo R888 vintage tires.
    Any gearing recommendations greatly appreciated.
    Show up in either paddock and the first beer is on me...
    Trout <º{{{><
  15. #334
    Liked: 46
    Default Starting point
    NOTE: I have a DB1 Kent w a 9:31 and I ran Avon slicks (shorter than the Toyos). I ran the long course (3.4 mi) with its 1K straight.
    My gears:
    18:33
    21:30
    24:28
    26:25
  16. #335
    Dave SanF 50
    Thanks for replying!
    I'm assuming that you're quoting ratios for the NOLA long course.
    Trout <º{{{><
  17. #336
    Liked: 46
    Default nope-COTA
    trout
    Sorry, I should have stated the track being you mentioned two. COTA has the 1K straight so the ratios I gave were for COTA.
  18. #337
    Willis, Texas
    Default Nola
    We will be running at Nola this year with a 77 Crossle 32F 9:31 R&P. Looking for a gear set up for this track.
    1977 Crossle 32F
  19. #338
    Member goodyscrossle20's Avatar
    New Milford,CT.
    Default formula ford at dominion va.
    has anyone ran at dominion .I have a 9/31 ring&pinion, new hooisers I am looking for trans ratios.i will be racing there in 2 weeks with VRG. THANKS
  20. #339
    Member chrisH's Avatar
    Pittsburgh
    Liked: 30
    Default VIR-Honda
    Can anybody point me in the right direction for VIR with a Honda? Please specify R&P so I can do the conversion.
    Thanks!
    Chris Horan
  21. #340
    Member Chris Forrer's Avatar
    Pensacola, fl
    Default VIR gearing
    Don't know if this will help with a Kent rather than a Honda but....
    Using a 9:31
    1st 19/32
    2nd 22/30
    3rd 24/28
    4th 25/26
    Good luck!
  22. #341
    Macomb, Mi
    Liked: 48
    http://www.apexspeed.com/resources/baseline_gearing.htm
    This is a good summary for a 10:31 diff....
  24. #342
    Gainesville FL
    Post
    Thanks Ray for the gearing chart.
    Paul Crouch
  25. #343
    Liked: 46
    Default Runoffs @ Indy 2017
    Anybody thinking way ahead to the Runoffs regarding gearing? The "Baseline_gearing" lists Indy road course (which configuration?) gears for a 10:31 as 18:32; 20:30; 23:29; 25:27 (26:25 for a 9:31).
    That seems about right for a 3.7K ft straight to me given the Hoosier Radial is slightly taller than the bias plys (~3%??).
    Any thoughts?
  26. #344
    NYC
    Default PittRace Gears
    I'm running the Majors at the Pittrace full circuit in a few weeks, looked through this thread and didn't see anything for Pittsburgh.
    Does anyone have recommendations for a Honda with 10:31?
    Cheers!
  27. #345
    Senior Member GAC's Avatar
    Peoria, IL
    Liked: 91
    Quote Originally Posted by Dave SanF 50 View Post
    Any thoughts?
    FYI, Indianapolis Raceway Park is not the Indianapolis Motor Speedway. It is the track west of Indy with the road course, drag strip, and 5/8 mile oval where the NHRA Nationals are held, among other events. It was renamed to O'Reilly Raceway Park and then renamed to Lucas Oil Raceway.
  28. #346
    Liked: 46
    thanks for the info, GAC
  29. #347
    Junior Member RANDY BAILEY's Avatar
    CORPUS CHRISTI, TX
    Default PCF gearing at Indy Motor Speedway for OWC
    Does anyone have the gearing for IMS road course for upcoming SVRA Open Wheel challenge in June. I have a Db-1 with 10:31 on Hossier threaded tires. Thanks in advance.
  30. #348
    Ann Arbor, MI
    Default CFF at Indianapolis Motor Speedway Road Course
    Hey Folks!
    Totally newbie here. Have a 1978 FF with treaded Dunlops and 9:31 diff ratio. I'm planning on going to the SVRA Open Wheel fest at Indy in June.
    I'm still learning how to change the gears, only have a few spares, and not much idea how to figure out what I'm going to need for the June weekend.
    Would sure appreciate any guidance.
    Thanks!
    Larry
  31. #349
    Sequim, WA
    Liked: 46
    Post Tires ?
    How old are your Dunlop tires? How much time is on those tires.? When (date) were they first used ? How strong is your engine? When was the head on your engine removed, cleaned, valve springs checked, leak down? All would affect your gearing, particularly top gear.
  32. #350
    Ann Arbor, MI
    Don't know the exact age of the tires but they were first used in July 2015 and have perhaps 30 laps on them. Engine was rebuilt last year by Elite engines and has only testing miles on it. It's fresh.
    And yes of course all those things—including personal preference—will affect the final gearing. I'm simply looking for a starting point.
    Quote Originally Posted by Albatross View Post
  33. #351
    Liked: 46
    Default Portland Major Gearing
    I looked in Jake's book and noted the starting point gears for Portland. Anyone have any thoughts on gearing for that configuration?
    Jake's book states (9:31) and the old gumball Hoosier/GYs
    20:30
    22:29
    24:28
    25:26
    The first gear is taller than a Willow Springs first. That seems pretty tall to me. The radial Hoosiers are a tad taller than the previous tire.
    Anyone from the NW care to comment?
  34. #352
    Sequim, WA
    Liked: 46
    Default Portland gears
    Dave, Having raced at the Portland track several times each year for many years. Here are some considerations. Except during the very early racing season each year, the track will be using the chicane on the front straight. And the entry announcement usually states that the front chicane will or will not be used subsequently during the balance of the season. The chicane is often referred to as the "Festival Turns". Plan on them being used for your event. I can only give you the 9:31 gearing for the "better" Club Fords using the "front chicane" (Festival Turns). I would guess that the recommended gears for a "modern Ford" as in Formula F be one tooth LESS for each gear ratio. Here are the gears used for Club Ford: 18:33, 20:30, 22:28, 25:27. A word of warning-the front chicane can and will be a "cluster F..." on the opening start/lap of the race. Good luck, hope that you do well and have a great weekend.
  35. #353
    Liked: 46
    Senior Member Ed Erlandson's Avatar
    Burbank, California
    Default portland gears with chicane and hoosier 60 radial
    Hi Dave,
    See you there, as the RV hook-ups are scarce or non-existant, pit close by and we can share resources.
    I hope to be there Thursday PM, and good luck to us getting in on Thursday evening.
    A bit closer on gears . I was there last year running with the Hoosier spec tire, so this is close.
    17;33
    19;31
    22;29
    21;24
    Not only is the chicane (Karen McCoy verified we are using the chicane) really tight, so is the right turn onto the back straight, so I have a lower 1st gear than you have seen. (I also have the lap record)
    BE SURE TO BRING A MUFFLER !!!! It is mandatory per Portland state regulations.
  38. #355
    Senior Member Keith Robinson's Avatar
    Abbotsford British Columbia.Canada
    Liked: 85
    Indianapolis Motor Speedway Road Course.
    I'm going to OWWC also and have been given this gearing as a suggestion from a FF driver that was there a year or two ago.
    19/32 22/30 24/28 25/26 with 9/31 final drive.
    Anyone have anything to add?
    Quote Originally Posted by larryw View Post
    Hey Folks!
    Thanks!
    Larry
  39. #356
    Fallbrook, N. San Diego Co.
    Default Streets of Willow
    Anyone drive the Streets of Willow? Looking for an idea of top speed going counter clockwise. Porsche will be doing an autocross there in Oct. It appears that the main straight is about 400 yrs long.
    Mark
  40. #357
    Savannah, GA (via Montreal)
    Liked: 990
    Quote Originally Posted by Ray Rivard View Post
    Thx, but also needs a rear tire run-out number if available to be 100% complete.
    cheers
  41. #358
    Liked: 438
    Mark
    It appears that the main straight is about 400 yrs long. That is really long.
    Graham
  42. #359
    Just guessing from the Goggle Map and the help of a spelunker.
    Mark
  43. #360
    Texas
    Liked: 17
    Default MSR Houston gearing starting point, please
    RF84, Kent, 9:31.
    thanks
    Randy Smart
There are currently 33 users browsing this thread. (0 members and 33 guests)
