Results 1 to 12 of 12
    Senior Member Michael Lensen's Avatar
    Vancouver, Canada
    Liked: 15
    Default Cleaning an oil radiator
    Looking for advice on how best to clean the inside of an oil radiator.
    The problem is that it may have minscule metal shavings in it.
    Thank you.
    Pittsboro IN
    Liked: 317
    Send it out to be ultra-sonically cleaned
    St. Charles, Illinois
    Liked: 222
    I looked into using a certified ultrasonic business. The kind aircraft use to clean out oil coolers. It was cheaper to buy a new one.
    Liked: 743
    Default Oil cooler
    Replace it !
  5. The following 4 users liked this post:
    Liked: 1101
    Quote Originally Posted by Michael Lensen View Post
    Thank you.
    If you think there's metal particles in your oil cooler, best to replace all of your oil lines as well. Do a full detergent clean of the oil tank, sump, and all of the fittings.
    Vancouver, Canada
    Liked: 15
    I was trying to avoid buying another radiater because up here there are not a lot of merchants for that kind of thing.
    Your advice is valuable.
    Thank you Fred, Brian, Kea and Dan.
    Seattle,Washington
    Liked: 34
    Have you called Seattle Radiator, I’ve had radiators (water and oil) ultrasonically cleaned there before and plan on using them again to clean my radiators for my RFR. If you can’t find them DM me I’ll send you the number. Added link https://www.google.com/search?q=ultr...-gws-wiz-serp#
    Vancouver, Canada
    Liked: 15
    Hi Rick, I haven't but did find a shop here in Vancouver that offers the service.
    But thanks for the info.
    Quote Originally Posted by Rick Brannon View Post
    Rocklin, CA
    Liked: 65
    I changed my oil system plumbing to run the pump discharge through the oil filter and then to the cooler, not the other way around. That way, if anything of size comes from the pump, it will be stopped by the filter.
    Liked: 3911
    Quote Originally Posted by Lyngengr View Post
    I run an XRP screen filter between the sump and the oil pump. IMO, normal automotive oil filters are too restrictive and could cause starvation at the pump when the oil is cold or too thick. That needs to be on the pressure side.
    Comment - I may have misunderstood what Lyngengr said, so...
    If Lyngengr meant the "pump discharge" was the pump pressure side, not the discharge from the sump to the pump, what he said is a good idea.
    Last edited by DaveW; 07.05.25 at 3:43 PM. Reason: Maybe read the quoted post wrong
  14. #11
    Savannah, GA (via Montreal)
    Liked: 1006
    Don't most (all?) oil filters have a bypass in them anyway, and at our high rpm oil flow rates a lot of the oil is bypassing the filtering media ?
  15. #12
    Liked: 3911
    Some do for sure, but the bypass is triggered by excess pressure, usually somewhere over 80 psi. Atmospheric pressure (~15 psi) is certainly not enough to do that. That's why restriction on the suction side is so dangerous.
There are currently 129 users browsing this thread. (0 members and 129 guests)
