Results 1 to 26 of 26
    Milan, MI
    Liked: 337
    Default Unacceptable towing
    Heard a F1000 got flipped and dragged by…..
    a non-releasable flat tow.
    At Rd America. Go figure.
    Muleshoe, Texas USA
    Liked: 264
    Default Flat tow
    It appears this happened. A notice has since been sent to all of the FRP drivers that they can request an "Indy Tow" instead of the solid hook.
    RaceDog
    Messenger Racing
    Muleshoe, Texas USA
    Milan, MI
    Liked: 337
    After the event where a driver refused a hard-tie-tow and then the fallout from that, you’d hope someone would get the message before someone gets badly hurt or worse.
  4. The following 7 users liked this post:
    Liked: 3909
    Default Related thread...
    https://www.apexspeed.com/forums/sho...ight=tow+strap
    Liked: 339
    Makes me think it is time to think about some kind front tow attachment point.
    Liked: 3909
    That makes sense, but would likely require bodywork mods, or removal of the front bodywork to hook up to a dedicated tow "ring."
    I have an unused 3rd-spring bracket and/or exposed frame that would maybe suffice once the nose is off..
    Liked: 1010
    Default Already taken care of
    Read the link in DW's post above. The GCR says that a driver can refuse a flat tow with a non releasable attachment, unless specific class rules require a tow hook
    Liked: 3909
    From the June 2025 GCR:
    I. Flat Towing
    Formula and sports racing cars may be flat towed with a hard connection only with the driver’s consent,
    unless specific class rules require a towing eye for flat towing with a hard connection. If the class’s rules do
    not require a towing eye and the driver of a formula or sports racing car does not consent to being flat towed
    with a hard connection, the car must be flat towed only with a connection that can be released by the driver.
  12. The following 5 users liked this post:
  13. #9
    Liked: 339
    If you do any kind of pre-event testing, that rule will not hold water if the track is running the test.
    Why not just get with the program and adapt to current flat tow practices. The tow crews are simply not up to speed with what we require.
  15. #10
    Liked: 565
    What program is that, Brian? What current town practices are you talking about?
    Peter Olivola
    (polivola@gmail.com)
  17. #11
    Pittsboro IN
    Liked: 317
    I. Flat Towing
    This is all well and good until the track supplied tow crew gets there and doen't know the Club rules. They will more than likely not at alll be interested in what you are trying to telll them, especially if it's a hot tow situation
  18. #12
    Duncannon, PA
    Liked: 358
    Unfortunately it is your responsibility to pay attention to what they are doing and if you don't like it get out of the car!
    Ed
  19. The following 5 users liked this post:
  20. #13
    Winston-Salem, NC
    Liked: 219
    Had to let go of a tow at VIR earlier this year. was stopped just past pit out (out of gas) and they wanted to turn me around to tow back up pit road. They sent out an off-road RV kind of rig to tow me and it had a MUCH tighter turning circle than my FF. Had to let go and explain it to them.
  22. #14
    Liked: 565
    Quote Originally Posted by s800racer View Post
    It's important that drivers in these situations explain what their cars can and can not do to the EV crew. In this situation, they should have turned you around by pushing you back and forth before hooking up, but they won't necessarily know that's the best way to handle the situation if you don't tell them. Expecting EV crews to know and understand the capabilities and limitations of every car and type is a bit much. Especially as they hire fewer and fewer SCCA trained staff.
    Peter Olivola
  24. #15
    Liked: 1743
    so VARA has been using the same crew for nearly 20 years. Advanced Fire and Rescue. Years ago Cal Speedway and Willow Springs had their own crews and insisted on using them, and eventually VARA prevailed. We've used them at Buttonwillow, Willow Springs, Cal Speedway, Chuckwalla, Pahrump, Las Vegas, and the Podium Club in AZ. They go where we go.
    AFR is a small business set up specifically to work motorsports events. Top notch guys, top notch equipment, and they know our cars and drivers. They are a part of every driver's meeting too.
    Our entry fees aren't any higher than anyone else's. And they do hot tows too.
    Don't understand why more clubs don't try to develop this kind of arrangement.
  25. The following 4 users liked this post:
  26. #16
    Liked: 1482
    My tow yesterday at Laguna was non-releasable. Don't know who SFR used.
    At Buttonwillow, the crew there (CalClub's own I believe) always uses a releasable rope.
  28. #17
    Late Braking Member
    Danville, California
    Liked: 281
    SFR used Laguna Seca's E-Crew last weekend.
  30. #18
    Pittsboro IN
    Liked: 317
    Ed
    Oh, I fully agree but the track crews are not going to be easy on you
  31. #19
    Liked: 1224
    Jackie Steward carried a wrench with him. Should we all have a big knife?
  33. #20
    Liked: 1010
    Default club rules
    If it is a SCCA sanctioned, the region should be responsible for making certain that any track crews know the rules about this issue and abide by them. Too many race cars have been unnecessarily damaged by "track crews" that are local toe truck drivers with no real training in the proper procedures. I have been on the short end of that deal at least twice.
  34. The following 4 users liked this post:
  35. #21
    Liked: 2058
    Unfortunately, the local club is going to usually retain whomever is the cheapest to hire, so you are going to get oftentimes the least trained.
  37. #22
    Lincoln NE
    Ed
    With some of the vintage clubs, at least, they tell you NOT to get out unless you are on fire.
  38. #23
    Muncie, Indiana
    Liked: 1238
    I. Flat Towing
    The CRB put this into effect following the issue at Runoffs.
  39. The following 4 users liked this post:
  40. #24
    Duncannon, PA
    Liked: 358
    Really? You think I am going to sit in a car and let some yahoo drag me along for the ride? I don't think so! Just keep this in mind, I don't need you, you need me. Without entries they will not exist.
    Ed
  42. #25
    Liked: 3909
    Ed
    I think they are telling you to stay in the car while the track is still hot because you're safer that way. I don't think it's intended to make you stay in the car forever.
    If it's otherwise, I agree it makes no sense.
  44. #26
    Liked: 274
    Too many F600s have gotten flipped and dragged. I refuse the hard connection every time. Some tow crews don't like it. Got sent to the stewards at Pitt in 2020 because I was "arguing with the tow truck driver." I guess respectfully asking and explaining why is "arguing" to some people.
  45. The following 2 users liked this post:
There are currently 255 users browsing this thread. (0 members and 255 guests)
