Results 1 to 15 of 15
    Milan, MI
    Liked: 336
    Default Unacceptable towing
    Heard a F1000 got flipped and dragged by…..
    a non-releasable flat tow.
    At Rd America. Go figure.
    Muleshoe, Texas USA
    Liked: 264
    Default Flat tow
    It appears this happened. A notice has since been sent to all of the FRP drivers that they can request an "Indy Tow" instead of the solid hook.
    RaceDog
    Messenger Racing
    Muleshoe, Texas USA
    Milan, MI
    Liked: 336
    After the event where a driver refused a hard-tie-tow and then the fallout from that, you’d hope someone would get the message before someone gets badly hurt or worse.
    Liked: 3904
    Default Related thread...
    https://www.apexspeed.com/forums/sho...ight=tow+strap
    Liked: 338
    Makes me think it is time to think about some kind front tow attachment point.
    Liked: 3904
    That makes sense, but would likely require bodywork mods, or removal of the front bodywork to hook up to a dedicated tow "ring."
    I have an unused 3rd-spring bracket and/or exposed frame that would maybe suffice once the nose is off..
    Liked: 1006
    Default Already taken care of
    Read the link in DW's post above. The GCR says that a driver can refuse a flat tow with a non releasable attachment, unless specific class rules require a tow hook
    Liked: 3904
    From the June 2025 GCR:
    I. Flat Towing
    Formula and sports racing cars may be flat towed with a hard connection only with the driver’s consent,
    unless specific class rules require a towing eye for flat towing with a hard connection. If the class’s rules do
    not require a towing eye and the driver of a formula or sports racing car does not consent to being flat towed
    with a hard connection, the car must be flat towed only with a connection that can be released by the driver.
  12. The following 4 users liked this post:
  13. #9
    Liked: 338
    If you do any kind of pre-event testing, that rule will not hold water if the track is running the test.
    Why not just get with the program and adapt to current flat tow practices. The tow crews are simply not up to speed with what we require.
    Liked: 564
    What program is that, Brian? What current town practices are you talking about?
    Peter Olivola
    (polivola@gmail.com)
  15. The following 3 users liked this post:
  16. #11
    Pittsboro IN
    Liked: 317
    I. Flat Towing
    This is all well and good until the track supplied tow crew gets there and doen't know the Club rules. They will more than likely not at alll be interested in what you are trying to telll them, especially if it's a hot tow situation
  17. #12
    Duncannon, PA
    Liked: 355
    Unfortunately it is your responsibility to pay attention to what they are doing and if you don't like it get out of the car!
    Ed
  18. The following 3 users liked this post:
  19. #13
    Winston-Salem, NC
    Liked: 218
    Had to let go of a tow at VIR earlier this year. was stopped just past pit out (out of gas) and they wanted to turn me around to tow back up pit road. They sent out an off-road RV kind of rig to tow me and it had a MUCH tighter turning circle than my FF. Had to let go and explain it to them.
  20. #14
    Liked: 564
    Quote Originally Posted by s800racer View Post
    It's important that drivers in these situations explain what their cars can and can not do to the EV crew. In this situation, they should have turned you around by pushing you back and forth before hooking up, but they won't necessarily know that's the best way to handle the situation if you don't tell them. Expecting EV crews to know and understand the capabilities and limitations of every car and type is a bit much. Especially as they hire fewer and fewer SCCA trained staff.
    Peter Olivola
  22. #15
    Liked: 1731
    so VARA has been using the same crew for nearly 20 years. Advanced Fire and Rescue. Years ago Cal Speedway and Willow Springs had their own crews and insisted on using them, and eventually VARA prevailed. We've used them at Buttonwillow, Willow Springs, Cal Speedway, Chuckwalla, Pahrump, Las Vegas, and the Podium Club in AZ. They go where we go.
    AFR is a small business set up specifically to work motorsports events. Top notch guys, top notch equipment, and they know our cars and drivers. They are a part of every driver's meeting too.
    Our entry fees aren't any higher than anyone else's. And they do hot tows too.
    Don't understand why more clubs don't try to develop this kind of arrangement.
