Looking for advice on how best to clean the inside of an oil radiator.
The problem is that it may have minscule metal shavings in it.
Thank you.
Thank you.
Send it out to be ultra-sonically cleaned
I looked into using a certified ultrasonic business. The kind aircraft use to clean out oil coolers. It was cheaper to buy a new one.
Replace it !
I was trying to avoid buying another radiater because up here there are not a lot of merchants for that kind of thing.
Your advice is valuable.
Thank you Fred, Brian, Kea and Dan.
Have you called Seattle Radiator, I’ve had radiators (water and oil) ultrasonically cleaned there before and plan on using them again to clean my radiators for my RFR. If you can’t find them DM me I’ll send you the number. Added link https://www.google.com/search?q=ultr...-gws-wiz-serp#
I changed my oil system plumbing to run the pump discharge through the oil filter and then to the cooler, not the other way around. That way, if anything of size comes from the pump, it will be stopped by the filter.
Don't most (all?) oil filters have a bypass in them anyway, and at our high rpm oil flow rates a lot of the oil is bypassing the filtering media ?
There are currently 6 users browsing this thread. (2 members and 4 guests)
