Finally got out for more than just 8 minutes. Still chasing problems.
The car will have no power when any steering input is applied. The keyhole (turn 5) shows this, braking, downhill and a right hand turn. I'm full throttle on the car and there is no acceleration until a few seconds on the back straight. The car also has no power in 3rd gear, I top out at 107-111mph back straight of mid-ohio. I have been told I should be able to hit 130mph.
1. Carb was looked at by Ivey, they suggested increase the level of the in the bowl, this helped a little.
2. spark gap was about 0.036" (next time I'm putting it at 0.026")
3. The valve lash on both intake/exhaust was ~0.016" measured cold. (going to change to the recommended 0.008 and 0.01")
4. Cold compression with throttle open and all 4 plugs removed.
- #1 178psi
- #2 147psi
- #3 155psi
- #4 155psi
Aim data
https://www.dropbox.com/scl/fi/0u0sd...=rkhdpoj2&dl=0
https://youtu.be/13VgajdP_UM?si=2WcyWB9qmJTzG12t
