Results 1 to 6 of 6
    San Antonio
    Default What part is this? Threaded throttle cable anchor? Titan Mk6
    Hi. 1st post. New to FF. Just bought a '70 Titan Mk6. And not a very good mechanic...
    Can anyone tell me what these are called? They anchor the throttle cable at each end (carb & pedal). 5/16-24 threads.
    I'm going to try and clean up the threads. But, if I could source new ones, I'd feel better.
    Thanks!
    Skip
    Liked: 900
    Pegasus calls them a barrel end clamp:
    https://www.pegasusautoracing.com/pr...sp?RecID=12184
    Comet calls it a cable clamp:
    https://cometkartsales.com/collectio...=Single%20Bolt
    5/16-24 seems HUGE, though. Are we talking something else?
    Late Braking Member
    Danville, California
    Liked: 269
    Those look like the cable housing mounts, you know the things that hold the cable assembly to the chassis, not the actual cable end fittings.
    San Antonio
    Yes. They hold the throttle cable to the chassis. Bolt goes through a hole in the chassis... The female thread is what the throttle cable threads into.
    Thanks!
    Late Braking Member
    Liked: 269
    Default Titan registry
    Maybe these guys can help https://teamterrificracing.net/TitanRegistry/
    Personally, I'd make my own but I have a lathe.
    Petaluma, CA
    Liked: 666
    Ethan Shippert
    https://www.norwestff.com
