Results 1 to 11 of 11
    Florance, AZ
    Liked: 42
    Default Thermo Housing / Water Outlet
    Looking for a replacement housing for my 88-SF Renard Pinto - found a hairline crack in mine after fitting a thermostat (no, it tightened nice and even).
    Looks like a Cortina Mk1 & 2 part - number on it: 731F-8250-AA.
    Racing this coming weekend, looks like a tough weld...
    John H.
    Reynard 88SF
    Late Braking Member
    Danville, California
    Liked: 272
    Default Dave Bean
    Hi,
    Dave Bean carries a raw casting, I.E. no holes and gasket side needs machining. If you have access to a mill, no problem.
    Otherwise Mopar Slant 6 and '78 and newer Mopar small block V8 water outlets work. Summit and Jegs have some options.
    Derbyshire, United Kingdom
    Liked: 360
    It's a standard Ford Kent part - might be worth cross-posting in the FF section as I'd imagine someone there has a spare.
    Lincoln NE
    AS tlracer says it's a 1600 "Kent" part
    if none turn up, there's always Burton
    fast but expensive DHL shipping
    https://www.burtonpower.com/thermost...rwd-fp610.html
    St. Louis, MO
    Liked: 32
    You also might try British American Transfer. They list the part, although they may not have it in stock.
    https://batford.net/
    Arizona
    Liked: 378
    Do a search on eBay for this: 1974 2.0L ford pinto water outlet
    That will bring up numerous hits. Be cautious of which model you need. There are some that the two bolt holes are kind of 'in line' across the water outlet and some that the two bolt holes are 'offset' from centerline.
    Liked: 160
    Default everco w1440
    Ther is an Everco w1440 on Ebay. Located in Houston. Maybe cross reference that to another number.
    Search D1FZ-8592B
    Florance, AZ
    Liked: 42
    Exactly what I found - Thanks!
    John H.
    Reynard 88SF
    Lincoln NE
    Just to be really sure.....is this on a 1600 or a 2L?
    you posted in the 2L section, but it sure looks 1600
    Florance, AZ
    Liked: 42
    On a 2.0L Pinto engine - but is a 1.6L Kent part. Typical race car....
    John H.
    Reynard 88SF
  14. #11
    Florance, AZ
    Liked: 42
    Default Fixed?
    I have a replacement on the way (Everco part number), next couple of days I hope. Since it's still in one piece and not broken - just a fracture - I've jot it patched with JB Weld (long dry time, high strength & high temp - just in case.
    Believe it or not - the Kent engine was used in a lot of industrial equipment, including sweepers, an industry I have contacts in.
    John H.
    Reynard 88SF
  15. The following 3 users liked this post:
