Results 1 to 16 of 16
    ohio
    Default Leaking penske 8760
    Back for more fun! I noticed some oil on the side of the car after a week of very cold weather.
    Is this a common problem?
    Recommendations on a place to send it to have it tested? I hope I don't have to have them rebuilt.
    Or just send it in to Penske?
    https://www.dropbox.com/scl/fo/481pj...=mt91hcj7&dl=0
    Fitchburg, WI
    Liked: 417
    I used Warren Wilson at Wilson13 in Indy for rebuilding my Multimatics. Competitive pricing and a very quick turnaround. Warren is a damper guy in Indycar so I recommend getting them to him before their season starts if you choose him.
    Van Diemen RF99 FC
    Chatham Center, New York
    Liked: 1095
    Anze Suspension is one of, if not the largest Penske dealers in the country, and one of the best shock engineers around.
    516-587-5181 cell
  5. The following 4 users liked this post:
    Columbus, OH
    Liked: 482
    516-587-5181 cell
    Rebuilt my stuff. Very good and very helpful.
    Orlando Florida 32812
    Liked: 691
    Another vote for ANZE...........if I lived in Chicago, I'd get to vote for ANZE twice !!
    ohio
    thanks for this feedback.
    Why not just send to Penske? The overhaul cost is lower.
    Liked: 3907
    Default Link to what I posted in the vendor feedback section:
    Quote Originally Posted by redcar9 View Post
    ...Why not just send to Penske? The overhaul cost is lower.
    I don't have a price comparison, but my experience with Penske in Reading, PA has been excellent.
    https://www.apexspeed.com/forums/sho...l=1#post650354
    Liked: 3907
    Angelo (ANZE) and Steve Horn at Penske (Reading, PA) are both excellent choices for damper service, IMO.
    ohio
    I'm going with Penske as they have a lower cost and faster turnaround. I think the other place is too advanced for me. I'm just trying to get on the track and not have a catastrophic failure.
    near Athens, GA
    Liked: 1126
    From looking at your pictures, I'm pretty sure that oil is NOT coming from your shock. Looks to me like it's leaking from either the top of your bell housing, or the overflow pipe to your catch can.. or the tube running to it.
    The track for the oil does not appear to be coming from the shaft end of the shock.. about the only place it can leak from.
  14. #11
    Liked: 3907
    Good point - I didn't look at the photos before. You (redcar9) need to take the dampers off and study more closely where it's actually originating.
    However, having said that, getting the dampers properly refurbished is a good idea in any case, so it certainly won't be a waste of $.
  15. #12
    Muncie, Indiana
    Liked: 1238
    Clean your ICP perches carefully and manipulate them to make sure that is not where your leak is coming from. Those need to monitored and serviced occasionally as well. Richard at ICP can handle those for you 317-273-0089.
  16. #13
    ohio
    I sent them off to Penske as it was the most cost effective.
    They found this. https://www.dropbox.com/scl/fi/t7y04...=7ujwtbdn&dl=0
    .040" bleed hole
    .020" safety wire
    Wild stuff, they said it works and must have been a race day fix.
  17. #14
    Liked: 307
    Default Safety Wire
    I have seen this before - cheap and practical if you want less bleed. Not sure whether you could feel this at Club Level..............
    I second Anze and Penske for rebuilds - Angelos always around the FRP races and knows this type of car, Penske pleasantly surprised me on a rebuild of a set of very special inter connected ride height shocks for a 333 Ferrari.
    Phil
  19. #15
    ohio
    Phil
    Oh I'm sure I had zero clue it was in there. Dang! That's a wild car!
    I'm having Penske add the velocity dependent piston and looking forward to trying that out!
    Member jcolley's Avatar
    Portland, Maine
    Liked: 28
    Mine as well and even cheated and setup my shocks up per Dave's service history. May not be perfect FC to F1000, but a good place to start.
