Results 1 to 6 of 6
    Texas
    Default Distributor rebuild & Pertronix kit
    My Kent FoMoCo type 12100 distributor is in need of a rebuild .... need a recommendation on who can do this.
    Also, I'm told the Pertronix type 1241LS is the kit for this distributor. Can someone confirm? Yes, I contacted Pertronix, but the guy I dealt with was no help.
    Rob S.
    Nederland, TX
    Ontario Canada
    Liked: 190
    Quote Originally Posted by r33rob View Post
    Rob S.
    Nederland, TX
    You'd be better off to replace that distributer with something a bit more modern that parts are available for. Lucas 43D and the variants of it on the market come to mind.
  3. The following 4 users liked this post:
    Simi Valley
    Default FoMoCo Distributor
    f
    Rob S.
    Nederland, TX
    Can confirm Pertronix PN 1241LS is correct for that distributor,
    Had good luck with mine (so far) understand QC is not what it used to be at Pertronix ?? , Also use that distributor with points/cond which are still available. Standard points are good to over 7K
    CA
    Liked: 281
    Quote Originally Posted by DPLarsen View Post
    f
    if you really want to stick with that distributor as Dana mentioned I would stick with points and condenser and not deal with the inevitable pertronix failures.
    Hamilton, Ohio
    Quote Originally Posted by tstrong View Post
    Along those lines, do those of you using Pertronix w/Bosch distributors, replace the Pertronix units at some regular interval, so as to avoid the "inevitable failure?
  9. #6
    Liked: 1223
    Quote Originally Posted by RA1713 View Post
    Old ones might last. New ones don't.
There are currently 8 users browsing this thread. (0 members and 8 guests)
