The SRF exemption is just a silly straw man argument at this point.[/QUOTE]
If it's a safety issue for some Sports Racers (it is) then it's a safety issue for all Sports Racers
If it's a safety issue for some Sports Racers (it is) then it's a safety issue for all Sports Racers[/QUOTE]
So, you're saying the speed of the cars, the design of the bodywork and the effect of diffusers and wings have zero impact on the spray generated behind the car? You believe all Sports Racers are the same.
They are not. BTW, the lights on a SRF are 3 feet off the ground.
Monger was in a pack of cars that blocked his forward view & had no time to react when his line of sight cleared. That's pretty clear from his in-car video (https://youtu.be/MHa6LnGb6IQ?si=Yu3eo_9Zu_04UKPi). The video isn't the best quality but it looks like dry conditions and nobody had rain lights on anyway. Not that it would have mattered in his crash.
The fallout from Monger's crash wash they mandated front bulkhead reinforcements on all F4 cars.
Turner crashed into an already crashed car on the pit straight on the first lap of a race with 104 entries. I'm not sure rain lights were much of a factor there either.
The ire is far from random: there are plenty of alternatives to "abysmal" rain lights that don't cost $200, or even $100. Nobody to date has provided any hard evidence that the 2019 FIA spec is so much better than the other FIA-spec lights or other LED lights on the market.
In fact, the only comparison anyone provided was Steven Davis' video (which while unscientific as hell was at least somewhat informative and had a killer soundtrack).
All that we get are glib statements about how the status quo sucks and why not use the most expensive option possible because it's really not a lot of money. I tell you what, every one of you jokers that says $200 isn't a big deal can send that amount to my paypal right now: sam@lockraceworks.com. Hell, send me $200 a month since that's pocket change to you.![]()
The one and only time I ever got run over from behind in a rain race in 400+ starts was two years ago at Mid-Ohio. Buzzbomb decided to try passing half the pack on the first run into China Beach. He ended up climbing over my right rear, and landed on both my right front and Albani's right sidepod. Ended Albani's weekend and I got to run around with about 3/4" of toe out on my right front.
Just think, if I had a marginally brighter rain light that flashed, it would have made Buzzbomb not-retarded and no incident would have happened!
FV is entry level in SCCA. That does does not mean it can be called affordable. The affordabliity of SCCA racing is dictated by the actions of SCCA competitors. The vast majority of 'active' SCCA competitor have no concern about affordability.
If you are so worried about the safety of your rain light, then mount it to your roll bar.
FIA is the only major organization with a standard for a 'motor racing rain light'. FIA is a motor racing oriented organization.
Those against the FIA rain light have absolutely no organizations that match FIA's motor racing credentials. DOT, SAE, etc. have no motor racing expertise. They all so do not have a category of lights listed for use on race cars operating in the rain.
In other words there is no other organization that can challenge the FIA on the rain light specification.
Light is installed in 4-hz flashing mode. Here are 3 photos, one off, one during a flash, and one from 30-degrees to the side.
It's way brighter than my previous 20+ YO LED rain light. It hurts my eyes to look at it. And it's mounted in a MUCH more visible location. Also, most of it is visible from 30-degrees to the side.
I soldered and shrink-wrapped on the connector and wiring from my old light to hook it up.
Motorsports UK regulations had approved lights and I don't think all were FIA. They also had regulations on how when and where they are used so you needed a three position switch. Maybe a UK member could comment. SCCA says on/off at stewards direction.
Actually, I included view angle in determining the mounting position. Most of the light is visible at a 30-degree angle to either side and at least half of it at more than a 45-degree angle. It's not as far back inside the body as it looks, only ~2.5". View from 30-degrees to left below. Beyond 30 degrees, the light intensity falls off rapidly, so more viewing angle is not very useful.
I could have mounted mine more rearward, but any of those locations that were practical would have had the light far less visible to a following driver than where I put it. Having it up higher makes it much more visible than where I had my previous one, down below the support wing. There were a very limited # of locations that were not in danger of the light being destroyed with minor off's or contact and still met the intent of the GCR mounting rule.
This thread is such a reflection on SCCA in the year 2024.
All we need now is some TikTok action and a You Tube channel to help us with the installation.
Some days I am thankful that I am not a young person having to deal with 2 wars and a FIA rain light installation.
So I get that folks may be upset about the way the rule was Instituted and having to possibly fabricate a mount but the cost aspect holds no water for me.
The approved light is $175 which is nothing compared to what we spend in a single weekend.
I do this cheaper than 90% of people; I'm spending $4500-$5000 a season. I'm spending between $900 for local races and $1200-$1400 per weekend for out of town events. This my all in costs; including amortizing the cost of tires, fuel and even the registration for my tow vehicle.
Note I'm racing a $6700 Formula 500.
Simple math shows us that the light is 19.5% of a $900 weekend, and 15.5% of a $1200 weekend.
As suggested by several people already, this situation seems to require a buddy system. Everyone who considers this an insignificant expense should buy two and give one to a fellow racer who considers it a significant expense. For aspiring buddies out there, I will need four.
This buddy system would solve all our problems and save OW club racing.
If this is truly an insignificant cost, there will be no objections. Perhaps we could develop a similar buddy system for the FT cash grab.
Now you are just being silly.
But I am sure people would remove the "insignificant cost" label if they also had to buy one for their buddy. Or perhaps they would remove the "significant safety issue" label. If someone believes both labels are valid, then they should have no trouble opening up their wallets to help make it happen. After all, remember that SCCA is a club!
Simple common sense reminds us that a rain light is not a per weekend cost, aka a consumable. The person your simple math is based on is spending $5,000 a season and it is certainly reasonable to expect this to last 5 years at minimum (though I expect MUCH longer). Therefore, the cost of this rain light is approximately 0.7% of the cost of racing for 5 years. This is literally a rounding error and I cannot even believe this has gone on for this many pages.
-Mark
Mark Uhlmann
Vancouver, Canada
'12 Stohr WF1
Much better to resolve this important issue than be wasting time discussing how to keep OW racing alive, reforming SCCA, reducing costs, or actually making the racing safer. And Peter assured us that SCCA race operations does a perfect job, so no need to discuss ways to improve that department.
That is a silly interpretation. The first weekend you go out with it, it will cost you +15.5%. The second weekend, it will cost you 0%. Third weekend, 0%. Tenth weekend, 0%. What's the point of making this "analysis?"
Here's another way to analyze this - as a % of your initial asking price of $75,000 for your Mygale Formula Ford, this rain light upgrade will cost 0.2% of the car's purchase price. As a % of your reduced asking price after 6 months, it is 0.3%. As a % of your further reduced price after 9 months, it's 0.31%. After 10 months for sale, it's 0.32%. After 11 months for sale at $50,000 it's now 0.35%.
Ironically a much more accurate way to measure it, but equally silly.
-Mark
Mark Uhlmann
Vancouver, Canada
'12 Stohr WF1
The 1000th post will land just about exactly on Christmas Day.
Maybe whoever makes the 1000th post should get a free light.
Let's make this a sporting proposition. If the 1000th post (i.e. 999th reply) lands on Christmas Day (Eastern Time), I shall buy the poster an FIA rain light, including delivery in the Lower 48.
Have at it, boys!![]()
John Nesbitt
ex-Swift DB-1
673
I stopped reading this thread long ago......just go out and buy one....by now as this thread has gone along I figure the average reader of this thread has spent more on beer than the cost of a new rain light.
Sorry but it is a small cost. The estimated life of an FIA ran light is something like 30,000 to 35,000 hours. It will last the life of the car.
In 1990 I was towing a $2000 Formula Vee ($4700 today) with a 8 year old mini pickup. I was spending about $800-$1000 ($1900-$2300 today) to do 4 regionals a year. The rain light would represent about $80 back then. Even with my limited budget I could have swung it given it would be a one time purchase.
Do note I get the rule being / feeling arbitrary.
For less than the cost of the rain light, I can buy a sixtel keg of an excellent local IPA. While the rain light will last longer*, my friends and I will enjoy the beer much much more.
* I don't own rain tires and I no longer race in the rain but I do need a brake light. And I'm just trying to help the thread post count.![]()
There are currently 14 users browsing this thread. (0 members and 14 guests)
