Considering the "I'll make them pay" lawyer mentality you see on TV all the time, in the case of a serious injury, it's a definite possibility. I can certainly see why SCCA and other racing organizations would be concerned.
As BeerBudgetRacing said, "Preventive best efforts action is the best defense." Once the issue has been raised, the cat's out of the bag.
In general, in the US, anybody can sue anybody else for pretty much any reason.
Whether that suit prospers is another question. But it does impose cost and risk on SCCA.
For example, there is a lawsuit presently working its way through the court system, filed by a (now ex-) member. Among other things, it alleges dirty work at the crossroads around Pro and Ventures. In addition, he feels hard done by because the BOD terminated his membership for violation of the Club's bylaws.
I expect that the lawsuit will fail in the end, but, meanwhile, the Club is spending money on lawyers to defend the suit.
John Nesbitt
ex-Swift DB-1
I understand that. I didn't say anything about who that person would sue but it's clear the club is only concerned about the club being sued (which is fair).
I guess I like to believe the best in my fellow racers and don't expect to see the ambulance-chasing, slip & fall mentality in the racing world. If I'm on track with anyone that thinks that way I may seek other hobbies. However, I'm very confident that I don't have to worry about it and I'm almost as confident that no court in the land would take the case.
https://www.fia.com/sites/default/fi...n_lights_1.pdf
Note, although referred to as a 2008 spec, it was last updated in 2021. Also note, the Afterburner (Advanced Control Technology) is shown in the US / ACCUS section, and the Great Britain / MSA section shows what appears to be two versions of what is sold here as the Ultimate (50 LED) light.
OBTW - an alternative to all this BS is for the stewards to call a halt in the action until the weather clears sufficiently...
I know, I know, what's the standard for "sufficiently"?
You know the answer to that idea. Unlike NASCAR, SCCA races in the rain.
Typically, it is lightning that halts racing. Very heavy rain, or a flooded track, can stop proceedings (e.g. NJMP Majors race this year).
<sigh> The race organizers and stewards work up a full weekend of track time. And do their level best to deliver it. Stopping racing for some rain would blow the schedule out of the water. So to speak. If you do not want to race in the race, then accept that you will miss a bunch of track time.
John Nesbitt
ex-Swift DB-1
How about an airplane marker light? That would have an FAA spec.
~Matt Clark| RTJ-02 FV #92 | My YouTube Onboard Videos (helmet cam)
For a wing nav light with "an FAA spec" you would want the least expensive red nav light that meets the TSO requirements, that's $130 for just the bulb on Aircraft Spruce. Prices go up from there to over $3,000.
You can get a non-TSO, non-PMA red nav light bulb for $26 that is the same brake light you can get from Amazon for $26 - but not manufactured to an FAA specification.
Jim Phoenix Van Diemen RF79 CF
Disco lights. Done.
”Stayin’ Alive” activated with brake pedal optional.
No, because it does not NEED to be more than that.
Despite it being your specialty, quit trying to make it more than it is.
As mentioned above, if this is such a dire safety issue, then Halos / wheel tethers / crush zones / etc. NEED to happen right away too... because those are way more dangerous to not have, since that affects way more people than a blinky light some people never use.
I'll say again - we've been focusing on the technical details along with nitnoid things like lumens vs candelas (while candelas may be appropriate for a lab environment, it's also possible that lumens, far simpler to measure in an installed field environment, gets you 99% of the way there).
The bottom line is that the full set of requirements beyond the technical have not been disclosed by the SCCA - and likely will not be, and therefore any further attempt to solve this problem technically is an exercise in frustration.
Which is why I stopped my SCCA membership a year ago after paying dues since 1974. And yes I am still driving at my advanced age. Just not with SCCA. Vintage around here is much more competitive.
Roland Johnson
San Diego, Ca
DanW, E1pix, Jim Edmonds, Joefisherff, jrh3, pacratt, TimH
This is a clear example of you guys not being able to grasp the technical design aspects of a rail light design. FIA, DOT, SAE, etc. all spec their light systems using candelas. None of them ever mention lumens for any issue. Is it possible that they know something that you don't? The CRB knew they had no knowledge about rain light design nor the time or money to develop that knowledge, so they went with the FIA's specs.
What in the world is an 'installed environment'? Sounds like a can of worms for tech to navigated.
Face facts, the only thing you can challenge is the need for and cost of a better rail light.
I don't know what you did for a living Brian, but if you're going to challenge me on technical capabilities you better bring more game than your usual weak sauce.
A candela is a lumen per steradian - in other words, it takes into account direction. So depending on how you build the measurement device to capture the light you can end up with a decent equivalence.
Installed environment? The spec lays out angles that the light is supposed to be viewed from. If you block those angles with wings, supports, exhausts, etc, the installed measurement changes, essentially, you're left with a different value for the steradians. The FIA can force the mounting of the light in F1, 2, 3 to maintain the visibility. Unless the SCCA does the same, the results will be different. In other words, part of the light is going places where it is not useful. Depending on the surface the light strikes it may be lost, reflected, partially reflected, etc in the direction the user needs to see it.
In effect, this is not much different than antenna gain or a "bug splat" pattern compared to an isotropic radiator. I'm torturing the analogy a bit, but it works.
https://www.bbc.com/sport/formula1/66351630
Drivers are complaining that the extreme wet tyres are pointless... because they're only best when conditions are so poor that visibility is unsuitable and cars aren't allowed on track. As soon as the visibility is good enough to drive... they're better off on inters.
I guess the 2019 FIA spec lights aren't much good if you've got full aero/ground effects. Good thing we don't have that problem... oh, wait.
I do think it's clear that the aero impact on spray creation is a driving force in the need to have better rain lighting... hence why FV and the like don't have the same kind of problem as Things with Wings.
Mud flaps? FIA is testing them.....
https://news.italy24.press/local/716421.html
https://www.motorsport.com/f1/news/w...plex/10498479/
People that live their lives afraid to do any task because they might get sued, are living pretty lame lives. Just driving to the corner store, or walking your dog around the block, are tasks full of prospective legal action. Much like "write a letter", SCCA surveys, etc, claiming threats of legal action, is just a stalling mechanism to avoid making tough decisions.
Greg has a very good point. Unfortunately, until we change the right to sue anyone with the no cost to the surer, if you lose, we will as a society have to put up with the bull**** law suits.
Ed
The problem with deleting contingency cases, though, is then only the wealthy have any chance of restitution.
But if you mean minimizing ambulance chasing and wholly-frivilous cases, then you’re spot on.
We may be talking about different scenarios, Tim.
In legitimate cases of, say, medical malpractice, lawyers do much better work when motivated *only* by victory. There’s less incentive to succeed when getting paid whether winning or losing and that’s unfair to plaintiffs.
And like I said, just because a plaintiff can’t afford an attorney is one shameful reason to not get deserved restitution — and that plays right into the hands of all guilty parties who have the money.
I’d rather not post how I know.
Back to the origin of this thread, I just got the new sale flyer from Pegasus and the Afterburner rain light is on sale for $96. Like I have mentioned before here, I have used these since they came out on my FV and now on my First car. I don't think it is out of line price wise and made in US.
Ed
Of course it's on sale; it doesn't meet the new spec, so they wanna offload the old stock before it's really devalued.
The 2019 spec light is now out of stock at Pegasus:
https://www.pegasusautoracing.com/pr...sp?RecID=33297
See how that worked?
OK... we've talked (typed) and typed about this for quite a while now. I've been wondering what really IS the difference between the Afterburner (2008 FIA spec) and this newer 2019 FIA spec. Summit Racing sells the Lifeline version (this is the rectangular type), so I bought one to compare it to my Afterburner
Lifeline Fire LED Rain Lights 421-100-011
The first thing I noticed was the WEIGHT - I might be able to take some weight out of my car?. Not sure what the weight really is since I didn't weight it on a scale, but it feels like about a POUND or more. When you mount this thing it will have to be attached to something pretty STURDY. Has 2 ~6mm mounting studs and came with lock nuts. I received mine set for VERTICAL mounting (as shown above- about ~2.5 x ~4" but didn't measure it). It has a clear 'face cover' held on with 6 (I think) small locktighted screws and came with another cover that is supposed to be used for horizontal mounting .. with instructions on how to change them. Overall, it's about 2 times larger than my Afterburner and weighs 4 or 5 times more.. or maybe even more than that.
Visibly, the clear covers look identical except the LIFELINE writing is written in the other plane. I'm guessing that it MIGHT be polarized to help direct the light rays.
Anyway, I balanced the new one on top of my Afterburner and took some short videos. I used my car wiring for the Afterburner and a spare 12 volt battery for the LifeLine.
You can see the results at
https://www.wedgeracing.com/RainLigh...ineFIA2019.mp4
The Afterburner flashes at a slightly slower rate, but the Lifeline clearly overpowers it and the LEDs are physically much larger - that explains the additional current draw for sure. I can say that the Lifeline is substantially brighter .. so bright it will BLIND YOU .. so, fair warning. The Afterburner just 'hurts my eyes' a bit. So, if you're curious like me, take a gander. I promise the file is virus and spam free.
I couldn't find a trailer 15 watt bulb to compare with.
The Hungarian GP gave us a great view of what F1 can do with all this new LED power and an infinite wallet. I think the ones on their cars are still 3 times larger than this one. Wonder how much current THEY draw? .. and they have at least THREE of them.
OH.. and turn down the audio. I had the radio on in the back ground and didn't notice that my cell phone was picking that up at quite a high level. And please excuse the messy garage.. it never gets any better that it shows in the video.
These guys still have some:
https://www.moreheadspeedworks.com/p...pec-rainlight/
I ordered on Monday last week and had it Thursday.
Like Steve said - these is much heavier. A big chuck of epoxy. The cartek I bought does not have a single lens but rather small lenses on each LED.
There are currently 15 users browsing this thread. (0 members and 15 guests)
