Results 1 to 6 of 6
    Pa
    Default 2007 Stohr F1000 (Gen 2 Bodywork) For Sale
    I guarantee you will not find a nicer/cleaner F1000 in the country!
    I am third owner purchased in 2019. Maintained by prep shops its life! I don’t NEED to sell but adding a new car for 2021.
    Car & Driver featured in Dec. 2020 “Let’s Race Magazine” (4 page spread with back cover).
    2020 Rookie of the Year (FRP - North American F1000 Pro Series)
    Features (Standard or came with the car):
    Custom chassis allowing for room for bigger arms, chest and shoulders to fit comfortably.
    Aim MyChron3 Gold XG Data Logging Digital Dash Display and data system w/wheel speed, water temperature, oil temp, and oil pressure
    2 sets (8) of BBS 1-piece Cast Magnesium Racing Wheels (8x13 front, 10x13 rear) included.
    Gen 2 Stohr Fiberglass Bodywork and Composite Front and Rear Wings
    FIA-Style Energy-Absorbing Composite Nose Section, unique to the Stohr F1000
    Full Ground Effect Downforce Rear Diffuser Tunnel Floor
    Pushrod suspension on all four wheels, front and rear
    Quaife Limited Slip Differential with Fully-Machined "Stohr Spar"
    Wilwood Master Cylinders with Stohr CNC Machined Pedal Assembly
    Stohr Specific Machined Fully-Floating Brake Rotors on lightweight Billet Aluminum hats
    Wilwood Billet Aluminum Brake Calipers - 4 Piston Front, Twin Piston Rear
    Cockpit Adjustable Brake Bias Control
    MOMO Suede Steering Wheel with SPA Quick Release Hub
    F1 Style Steering Wheel Column Mounted Billet Aluminum Sequential “Single Cable Upgraged” Paddle Shifter.
    Brand New Dual Aluminum Water Radiator Custom Made for Stohr Cars
    Brand New Dual Oil Coolers.
    AFFF Fire System with two outlet nozzles per SCCA GCR 17.22.1
    C2P Double Adjustable Dampers – Built custom for this car!
    800 pound front, 1000 pound rear – Hypercoil Springs
    Stohr Ram air box intake with K&N filter
    AMB Hardwired Transponder
    Brand New battery (2020)
    Wired for Radio
    DynoJet Power Commander (Prior owner – not required)
    DynoJet AutoTune for Power Commander(Prior owner – not required)
    Three Midwestern Council (MC) Logbooks showing full history
    Full original Homologation Paperwork
    Midwestern Council History of frequent top 3 Overall finisher.
    Log Book
    BHF: 1:09 (prior owner)
    RA: 2:20 (prior owner)
    Upgrades done in 2020:
    2020 - Engine Replaced never raced 2006 GSXR 1000 LOW MILES (4400 miles)
    (2018) - New Stohr Composite Wing Mounts (Rear)
    2020 - Replaced ECU.
    2020 - Replaced rectifier.
    2020 - Took out sprocket studs, cleaned and re-locktight.
    2020 – Brand New Wiring Harness from Rilltech w/ new spare from George Dean Racing.
    2020 – 90% of ALL wiring in car replaced.
    2020 – Brand New (Latest Version) Relltech Flat Shift system.
    2020 - New K&N Air Filter and replaced intake clamps with NOS clamps.
    2020 - All new Silicone water hoses, Clamps, Cap, and associated hardware.
    2020 - All new thermostat. (you can run without one but never have)
    2020 - All new Fire retardant material around hoses and fittings
    2020 - All new Stainless Aeroquip oil lines, Oil filter, and fittings
    2020 - New oil cooler.
    2020 - All fresh fluids (oil, brake, clutch fluid, etc)
    2020 - Checked and Re-lubed CV joints
    2020 - Brand New Fuel Pump
    2020 - Brand new in line fuel filter
    2020 - Checked Diff bolts & Lubed Diff
    2020 - Chain and Link – Fresh lube
    2020 - New Sabelt (6-Point Harness)
    2020 – New Carbon Fiber Gen 2 Air Box (Dauntless Racing)
    Spares:
    Limited used spares but adds to the package:
    Couple of sprockets
    Drive Chain
    Rear Wing
    Various wing lips (front)
    Wing sides (rear)
    Hardware – Misc.
    Rear Wing Mounts (welded)
    Asking: $36,000 OBO
    Rhys "Reese" (717) 421-4665
    Bailey, CO
    Unbelievably gorgeous car my friend, glws!!
    near Athens, GA
    Liked: 861
    Also a pretty nice finish line shot .. of the car JUST edging out the "win"? Isn't that a FC beside it though?
    I could be wrong about the FC.. still a nice LOOKING shot, though.
    Member Ben Hedrick's Avatar
    Ormond Beach, FL
    Liked: 18
    Is this car sold? I thought I saw that it was sold. If not, let me know.
    Thanks, Ben
    Colorado
    Liked: 12
    Quote Originally Posted by Ben Hedrick View Post
    Thanks, Ben
    Yes, it lives and is racing in Colorado now.
    Ormond Beach, FL
    Liked: 18
    Quote Originally Posted by Shanek20002 View Post
    Thank you!
