Results 1 to 15 of 15
    Brownsburg, IN
    For Sale 1984 RF-84 Van Diemen
    Sold ! Thanks Apexspeed !
    1984 Rf84 Van Diemen Formula Ford, set up for SCCA Solo C-mod. I purchased the car from Craig Carr in June 2013. Craig had Bruce Domeck of Unique Automotive, Louisville, KY, (502-452-2688) perform a bare chassis rebuild of the car a couple of years earlier, including rebuilding the engine and inspecting the transmission. Car was inspected and aligned by Mark Lamm spring of 2016.
    I autocrossed the car locally since 2013, then began sharing the car with my son, traveling more, including Nationals in 2015 and 2016.
    Car is eligible to run PCF (Post Club Ford) in SVRA and other vintage groups, as well as SCCA Club Racing, but would require a ring and pinion change.
    I am 6' tall, 200 lb., and fit the car comfortably. Car will accept taller drivers, and heavier ones (I used to be heavier !!). My 5'5", 120# daughter has also driven the car.
    Reason for selling: My son wants to change classes, and I simply don't want to run the car by myself.
    An Rf-84 Van Diemen has placed First (2018), Second (2019), and Third (2016, 2017) at Solo Nationals, so the chassis is competitive.
    Asking $9,800. Price negotiable with reduced spares.
    The car is equipped with:
    New fuel cell
    Transmission ratios in car: 15:36, 18:34, 21:30, 24:28
    7/31 Ring and Pinion(4.429 ratio)
    Aluminum radiator with electric fan
    Hi-Tech header
    Fox double adjustable shocks, rebuilt by Chris Billingsly (the Shock Shop) winter of 2015/16.
    Electronic ignition
    MSD adjustable rev limiter
    Adjustable Shift light
    Removable Super Trapp muffler
    New Momo steering wheel
    Adjustable seat
    Compartment for ballast weights
    On board fire system
    One set OZ one piece light weight wheels
    The car comes with:
    3 sets Compomotive 3 piece wheels (one with older mounted rains)
    Spacers for mounting wheels
    Additional gearsets
    Spare painted nose, 2 spare unpainted noses
    Misc. body parts
    Misc. spares, including fuel pump, water pump
    Additional springs
    Sway bars
    Stub axles, spare drive hub, wheel studs
    Brake pads
    Ignition parts, coil, plugs
    Oil cooler and ducting
    Master cylinder
    Like new Carrera non-adjustable shocks
    Original SCCA road racing log book (number 85-499)
    Likely other stuff I'm forgetting...
    Auckland, NZ
    Default Could I view this weekend?
    Hello. I am staying in Indianapolis for a few days and wondered if I could view your car on Sunday.
    I know it is short notice but hope you can organise this for me.
    Cheers
    RTP
    Brownsburg, IN
    Quote Originally Posted by RTP View Post
    Cheers
    RTP
    Yes, that is very possible. Please provide a telephone number where I can reach you, and we can arrange it. You can PM me so you don't have to publish you number.
    Brownsburg, IN
    Cheers
    RTP
    Sorry I missed your calls. Please call again, to the same number. Car is available to be seen today, Sunday.
    Brownsburg, IN
    Still available.
    Brownsburg, IN
    Prince reduced $9,800 !
    Wichita, Kansas
    Quote Originally Posted by raisin racin' View Post
    Do you still have the car?
    Brownsburg, IN
    Quote Originally Posted by gbo3 View Post
    Yes, the car is still available. You can contact me at bnsfaucett@yahoo.com.
    Brownsburg, IN
    Still available
    GA
    Default Got your nose!
    Pardon my intrusion, but how did you acquire those spare noses? I've been looking for two years to no avail.
    Brownsburg, IN
    Quote Originally Posted by Iheartboost92 View Post
    The are available from Universal, in the UK. http://www.universalracing.co.uk/urs.htm Ask for Simon.
    Milwaukee Wi
    Liked: 107
    Default Sorry for the hijack
    I have always liked these cars. Had a FC version that was prone to overheating as well as a bit of a slow corner push I couldn't get dialed out.
    I took the side pods and radiators from an 88 Reynard and replaced the mid mounted radiator. Moved C.G. forward and cured the overheating problem. Should never have sold it!
    Brownsburg, IN
    Sold ! Thanks Apexspeed !!
  15. #14
    San Jose Ca
    Liked: 88
    Good for you Bruce,
    Is it staying in Autocross ?
    Ben
  16. #15
    Brownsburg, IN
    Thanks,. A young man from New Jersey will be road racing it.
