Results 1 to 23 of 23
    Savannah, GA (via Montreal)
    Liked: 976
    Default ProMazda engine oil?
    What are current thoughts on engine oil brand and weight for PFM?
    thx
    I always use Idemitsu oil for the engine and the pre-mix. Full synthetic 20W-50 for the engine.
    Ottawa,ON
    Liked: 138
    Is the premix a synthetic or standard? For now I used a stihl 2 stroke oil I had just for garage idling.
    I saw some new fancy 2 stroke oils that are for snowmobiles synthetic though which seemed odd to me.
    Senior Member tige00's Avatar
    arizona
    Liked: 49
    Stay away from all that stuff only use
    Idematsu
    Redline
    Amsoil
    locust valley, ny USA
    Liked: 156
    i ran rotella t6
    Ottawa,ON
    Liked: 138
    Quote Originally Posted by tige00 View Post
    Idematsu
    Redline
    Amsoil
    For which oil?
    Ottawa,ON
    Liked: 138
    This?
    https://www.amsoil.com/shop/by-produ...?code=AIOQT-EA
    Idemitsu pre-mix is synthetic
    I recommend stick with Idemitsu
    Ottawa,ON
    Liked: 138
    This?
    https://www.amazon.com/Idemitsu-3001.../dp/B07MMT3SLB
    Liked: 976
    Gentlemen, thanks for the feedback, but to get back on track, the question was what ENGINE oil to use, in the bellhousing, if that helps with any ambiguity LOL...
    There was going to be a follow up question regarding oil to premix in the fuel; back in the day the pro series provided premixed fuel, I don't personally know what was in it; anyone know for sure?
    thx again
    This?
    Yes. That’s just new label on bottle of same ol’ Stuff
    thx again
    Still Idemitsu LOL. 20w50 full synthetic
    Ottawa,ON
    Liked: 138
    Something special about it?
    arizona
    Liked: 49
    Idematsu From Japan made only for the rotary
    Contributing Member troyt's Avatar
    Half Moon Bay, CA
    Liked: 126
    Redline 20-50W syn or Mobil1 15w/50 for the engine.
    Been using Redline two-stroke for the premix.
    TroyT - SFR SCCA, VARA, CSRG, SVRA
    www.ThingsThatGoVroom.net
    '00 Carbir CS2, P2 #60
    '79 Lola T492, S2 #61
  17. #16
    Ottawa,ON
    Liked: 138
    Another oil question.
    Level, 6-6.5 inches in sump says the manual.
    Is that running? And warm? Or warm and off?
  18. #17
    Pittsboro IN
    Liked: 313
    Warm and off and it depends which oil tower you have. the original and the later ones are not the same height
  20. #18
    Ottawa,ON
    Liked: 138
    Which is this one? Old or new and what changes?
  21. #19
    IIRC, the "depends which tower you have" comment was because guides have often referenced oil filled to a level below the top of the tower, vs from the bottom of the sump. IIRC it's 9.5 inches from the top of the tower you have - hopefully someone can confirm.
    the reason to measure from the top is that it can be difficult to probe to the bottom sometimes as things are in the way.
  22. #20
    Pittsboro IN
    Liked: 313
    That looks to be the early model
  23. #21
    Ottawa,ON
    Liked: 138
    Thanks guys thought it was odd it would matter from the bottom.
    I am using a small rod so I think I got to the bottom but it's hard to tell if I'm hitting something else or not.
    I'll double check from the top too.
  24. #22
    Senior Member captdigi's Avatar
    Phoenix, AZ
    Liked: 126
    Default Engine oil
    New to PFM.
    Which Amsoil do people use in the engine, and how many quarts?
  25. #23
    Idemitsu only..
There are currently 8 users browsing this thread. (0 members and 8 guests)
