Results 1 to 8 of 8
    Colorado
    Default 40' S&S Freightliner Toterhome with 28' Haulmark Stacker
    The following is a description put together by my father to sell his toterhome. He has since passed away and I am needing to move this on. He and I raced for quite a while with this rig and it always did us right. I am relatively familiar with the rig and will do my best to answer any and all questions. I do have a significant pile of receipts kept by my father. He was very meticulous about maintaining his vehicles, and this one is no exception.
    Photographs of the truck and trailer can be viewed here: https://photos.app.goo.gl/3UEWrNk7yaZKY3Je7
    I can be contacted via email at nickhsorensen@gmail.com. The truck and trailer are located in Longmont, Colorado and are being offered with clean Nebraska titles. I am asking $95,000 for both truck and trailer. I will consider selling the trailer and truck separately, but would prefer to sell them as a unit.
    40-Foot S&S Freightliner Toterhome and 28-Foot Haulmark Stacker Trailer
    Toterhome
    Highly respected S&S motorhome conversion built on 1996 Freightliner FLD 120 Chassis, 40 feet overall length
    Powered by 14.7 Liter Caterpillar 3406E engine rated at 455 HP, no DEF required
    Rockwell 10-speed transmission
    300 Gallons fuel
    Dual Drive axles on air suspension, with inter-axle differential lock
    40,000-pound pintle hook
    All new rubber (Toyo) in past 3 years
    Crossfire Dual Tire pressure equalization systems on both drive axles, makes checking dual wheel pressures a breeze
    Kenwood Touch Screen head unit with satellite radio system and back-up camera
    Driver and passenger air seats
    Alloy Wheels
    New Truck Batteries 2018
    Electrical Master switches for both truck and living space
    All required and suggested maintenance and repairs completed
    750,000 miles
    5 KW Onan Genset, runs on propane
    2 40-pound propane tanks, one for genset, one for motorhome
    60 gal Fresh, 50-gal gray and 30 gal black water tanks
    Large slide out
    Electric awning curbside with pull-down awnings over rear bedroom windows and slide-out windows
    Full bathroom and shower
    3-burner propane stove and oven
    Refrigerator/freezer runs on 12v DC, propane, or 110v AC
    Two rooftop AC units, both blow cold
    Sleeps up to 8
    Clear Nebraska Title
    Trailer
    28-ft Haulmark Stacker, 33-ft overall with tongue
    Electric Heavy-duty tongue jack
    Lunette ring tow hitch
    Observation deck, ladder not currently installed but included with sale
    4,000-lb Gemini Hydraulic lift
    Wired for both 12v DC and 110v AC
    Good interior lighting in attic, over shop, and in garage, both 12v and 110v
    Curbside and Rear Flood lights
    Radio receiver and speakers so you can hear paddock announcements
    Plumbed for compressed air
    Lots of Jegs Cabinets for storage
    Sizeable workbench
    3 X 6,000-pound axles
    Alloy wheels, 2 spares
    Tires new in 2015
    Wide loading ramps
    Loading Winch
    PitPal Fuel storage rack, 4 X 5-gallon jugs
    PitPal door shelf
    Note: The pop-up Canopies pictured in trailer are not included in the sale
    Clear Nebraska Title – Salvage title
    The trailer was issued a salvage title several years before I bought it, for reasons unknown to me. I suspect it was damaged by hail and totaled, then re-skinned, but I can’t confirm that. I have pulled the trailer over 10,000 miles. It tracks very straight, exhibits no unusual tire wear or other abnormal behaviors. In fact, I usually am not even aware it’s behind me until going uphill, then I might have to go a gear deeper with the trailer than without it. The trailer can easily handle two race cars, or a race car and a dingy. I raced vintage formula fords and put two race cars and a Miata in it with ease. With a little creativity driven by need, a third race car could be made to fit in the attic area.
    This is a great combination for solo or small team racing. The 300-gallon fuel capacity provides for a range of a little over 2,000 miles. The truck and trailer are very easy to manage over a 4- or 5-day race weekend, and it’s a great facility for race car support. Everything on both the truck and the trailer works as it is supposed to. The truck and trailer track dead straight, and the dual axles on the toter make for an incredibly stable ride. I’m not a professional truck driver, but I found this rig to be very easy to manage on the road. It’s registered as a motorhome, so a CDL is not required, at least not in most states.
    S&S has a great reputation for building solid, long-lasting conversions on Class 8 trucks. The rear of the box is tied solidly into the frame and all the storage cabinets work fine. It doesn’t creak or moan in the wind or on the road, and the most significant noise I’ve ever noticed in it while camping is buzzing from the awning straps which can be cured by putting a half-twist in them.
    The big Cat engine, rated at only 455 hp, should easily be a million-plus mile engine. I have never had to add oil between changes and have never seen the level fall by more than a quart between changes. (An oil and filter change require 40 quarts of oil.) The engine starts easily from cold without smoke and runs smoothly throughout the rev range. The truck is checked over each time it’s serviced, and all recommended repair and maintenance items are completed. I’m told that the engine can be uprated to around 550 hp with new injectors and engine control systems. I have no idea whether this is advisable or not, I didn’t ever really check it out because I never felt it necessary to have more power. As it is, it will easily run 80 or 85 mph all day long, if you want it to. I usually operated it between 70 and 75 on the interstate.
    The truck will come with bedding for the master bedroom and over-cab bunk, an assortment of bath and kitchen towels (all freshly laundered, of course), along with pots and pans, silverware, and dishes. All you’ll need to do before loading up and taking it to the track will be to fill the fuel, propane, and water tanks, buy some food and drinking water (and beer, probably), and head out.
    Fallen Friend
    Pensacola, Florida
    Liked: 168
    Price?
    Bob L.
    Guest
    Midland, MI
    Liked: 312
    Quote Originally Posted by Bob L. View Post
    Price?
    Bob L.
    Added after original post...
    Senior Member Feffman's Avatar
    Gateway To The West
    Quote Originally Posted by TooMuchStuff! View Post
    ..... I will consider selling the trailer and truck separately, but would prefer to sell them as a unit.
    How much $$$ for just the stacker trailer?
    Feff
    Howell, MI
    Liked: 218
    I'm interested in stacker - price?
    www.wrenchaholics.com
    Rental, Coaching, and Data Analysis for Great Lakes Region
    Victoriaville, Quebec, Canada
    Default Still for sale ? Marcel cell 819-350-9750 text me
    i am interested if not sold can you send me a text at 819-350-9750 Marcel
    Toterhome
    300 Gallons fuel
    Alloy Wheels
    750,000 miles
    Large slide out
    Sleeps up to 8
    Trailer
    Sizeable workbench
    Tires new in 2015
    Wide loading ramps
    Loading Winch
    PitPal door shelf
    Vancouver, BC, Canada
    Liked: 259
    Quote Originally Posted by mlafontaine View Post
    Cmon man - this post is 3 years old and the guy hasn't logged in since 2020. The guy's contact details are in the original post - send an email if you are interested in the highly unlikely chance this hasn't sold years ago.
    -Mark
    Mark Uhlmann
    Vancouver, Canada
    '12 Stohr WF1
    Fallbrook,Ca 92028
    Default Stacker Trailer
    Do you have a price for the stacker trailer? What year is it and where ae you located.
    Please advise....
    Tom Van Wie
    760 703-6400
    tvw@sbcglobal.net
    Toterhome
    300 Gallons fuel
    Alloy Wheels
    750,000 miles
    Large slide out
    Sleeps up to 8
    Trailer
    Sizeable workbench
    Tires new in 2015
    Wide loading ramps
    Loading Winch
    PitPal door shelf
There are currently 8 users browsing this thread. (0 members and 8 guests)
