Results 1 to 13 of 13
Thread: Reynard 88SF FC
    Junior Member mx_edge's Avatar
    Southeast Michigan
    For Sale Reynard 88SF FC
    Reynard 88SF FC
    Chassis # 88SF100
    ***SOLD***Turnkey and race ready!
    Perfect car to run the Great Lakes Challenge Series.
    The car is located about 15 minuets from Keith Averills shop in south east Michigan.
    Keith has provided the following service.
    - New Clutch disc and pressure plate- Two races.
    - New water pump and associated belt and pulleys - Two races.
    - New Hewland shift fork and jigged trans - 0 time.
    - New starter Bendix- Two races.
    ***Includes***
    - Two sets of OZ wheels, one with mounted and balanced Hoosier A35 stickers stored in plastic bags in temp controlled room.
    - Mounted rains on Compomotive's - Used
    - One set of Compomotive's wheels - Old Tires
    - 15 Gear sets. All of the recommended GLC series gears. Some new and used. (Waterford gears installed)
    - LD-20 Front and LD-19 Rear calipers. Pads are 75%
    - Cockpit adjustable brake bias.
    - Averill front Wing on ultra nose. Spare ultra nose complete with wing.
    - Gyro Dynamics diffuser.
    - Pennon diffuser pump. Not installed for muffler clearance. Installs in minuets when straight pipe is used.
    - Updated Pennon rear wing.
    - 10:31 ring and pinion.
    - Gun drilled Fast-Forward half shafts. Some spare parts.
    - Stimola 8100 Penske Shocks. Low time.
    - Ray Grienke Wired this car on previous owners watch. Professional Job!
    - Ray Grienke LED rain light - New
    - 2010 Fuel Cell. Excellent shape.
    - Engine by Rex Gunning with Steve Knapp fly wheel.(and all the other good stuff) Running strong.
    - Magna Flow muffler to run Waterford. Has straight pipe as well. Quick change
    - Electronic ignition.
    - Clutch master cylinder - two races.
    - Stack tach.
    - Willans belts good through 2018. Narrow shoulder belts to fit Hans.
    - Averill droop limiter.
    - Cockpit adjustable rear sway bar.
    - New factory type wind screen from Averill not installed. Smoke tint.
    - Fuel sample port.
    - Fire system
    - Suspension A-arms and rockers to rebuild all four corners. Two aluminum up rights.
    - Assortment of sway bars.
    - Alignment bars for string aligning.
    - Two binders of documents with set up info and receipts.
    - Log books.
    - Mounted antenna for radio
    - Misc body and parts. Old stuff
    6'-2" 210lb driver fit but right to the limit.
    Was purchased 11/15 and raced once in 2016 and once in 2017. The drivers schedule is limiting track time.
    Transponder not included. The annual is due.
    Howell, MI
    Liked: 218
    Holy crap that's cheap! I've chased this car around Waterford Hills. It's fast. I have not wrenched on it, so I can't speak to that. Keith will know.
    Keep it out here and run GLC!
    www.wrenchaholics.com
    Rental, Coaching, and Data Analysis for Great Lakes Region
    Liked: 992
    I believe that this is the EX Bingham / Rex Gunning car. Am I correct.
    If so it is one hell of a deal.
    Southeast Michigan
    This is it
    Livonia,MI
    Liked: 39
    Another rental Cade!!!!!!!!
    Liked: 3916
    Good thing i signed a pledge that my next car has to have push rods.
    What a deal! No possible way in hell to go fast any cheaper.
    It would be worth that without all the great spares...
    Howell, MI
    Liked: 218
    Quote Originally Posted by BruceRace View Post
    Commit to a season with me and I'll pick it up!
    Gotta have the business case... dang business case. Always ruining the fun.
    Houston
    Liked: 280
    Theres a couple lovely early 90's VD FF's for sale. Can you say 50th?
    Glendale, Arizona
    Liked: 502
    Pm sent.
    Trying to buy this. Shipping with spares may be prohibitive. Anyone with ideas regarding this and help getting this car to Arizona, please PM myself or the seller.
    Senior Member captdigi's Avatar
    Phoenix, AZ
    Liked: 126
    Time for a road trip.
  14. #11
    Southeast Michigan
    Default Sold
    Sold. Heading to California.
    Thanks Apex and all the interest.
  15. #12
    Prescott, AZ
    Liked: 202
    Default Available
    Shop is too full. Anyone looking for a nice Reynard? $12.k. It is available in AZ , April 2023. Excellent car with a ton of spares and a fresh long rod Pinto.
    jrheath3@hotmail
    714 308 8087
  16. #13
    Liked: 911
    Is this car for sale? If it is, it requires an asking price.
