Page 10 of 11 FirstFirst ... 67891011 LastLast
Results 361 to 400 of 436
Thread: Pinto Upgrades
  1. #361
    Columbus, OH
    Liked: 86
    Was rereading part of this thread today and veering back on track (no pun intended), to me a good path would be:
    1) Allow an overbore (.030?) and the subsequent compression increase (makes more blocks viable w/o sleeves) - keeps the head "as is" and allows lower cost first build of junkyard block (vs. sleeve)
    2) Allow an alternate carb on the stock intake (several have been mentioned in the 36 - 38 mm range) - sub $300
    3) Allow any 5.7" rod w/any flat top piston that does not exceed the stock deck height (allows competition)
    4) Require a spec rev limiter w/ a spec chip w/larger carb- (extends lifespan of motor).
    This would seem to be a (relatively) cost effective package that would allow a modest performance and durability upgrade.
    Just my $ .02
    Craig Butt
  3. #362
    Arizona
    Liked: 375
    Quote Originally Posted by Craig71188 View Post
    1. My understanding of the newly approved Wiseco piston is that it is a stock diameter. Doing an overbore would probably be fine for an engine that has not been sleeved. But, for those engines that had to be sleeved during their life, overboring the sleeve is most probably not an option. So, staying with a stock size bore works for everyone whether your engine is sleeved or not. To me, this appears to be the logical choice.
    I contacted Quicksilver to ask about pricing and availability of the recently approved long rod and piston. Their pricing was right in line with what I have researched other long rod piston combos to cost. From Quicksilver's message, they plan to order 3 complete sets of rods and pistons at a time. They will keep these in stock and when that stock is depleted they will order more. Sounds logical to me. Only concern I see here is the duration of time it will take for them to get new stock when theirs is depleted.
    2. Look at the most recent GCR. 9.1.1 Section 15 Ford NE engine. In here you will see that the carburetor you are mentioning has recently been allowed. The price you quote may or may not be accurate. I was told by one of the engine builders that on their dyno they didn't see much difference between 32/36 and 38/38. So, my guess is to see any gains, a 38/38 would need to be tuned by someone that knows what they are doing. I have proven to myself that I am terrible at tuning a carb. So, I don't bother. I keep a prepped carb which came from an engine builder in my trailer at all times. It cost more than $300, but if I am at an event that I just paid $1000 of entry fees, motels and travel time... the dollar value of having a 'hot standby' in my trailer is worth it.
    3. See comments under #1
  5. #363
    Liked: 712
    Default Pinto Upgrades
    Keith- I assume you are referring to FRP when you say "an east coast series" and I need to respond.
    We did NOT change our rules away from SCCA Club. That is a wrong statement. Club wrote in some specific line items that allowed the builders to 'adjust' the specs found in the crate motor in perfectly legal manner so of course they did. See GCR 9.1.1.16, then read our technical specifications.
    What we have done is adjust the map to make the motor start better which is why we have a different map. Everything else is the same as Club. Oh, yea- we added 10 lbs to minimum weight to compensate for the heavier radial tire so people didn't have to spend stupid money to shed 10 extra pounds.
    Yes Bob, I'm talking about the FRP. The following from SCCA's GCR has not been followed. There is even a current advertisement for a car selling on Apexspeed that has a "blueprinted" motor.
    This is what the GCR has to say;
    "16. Ford Zetec Engine
    The Ford Zetec ZX3 engine shall conform to the following specifications and may be modified only as specifically allowed. If these specifications do not explicitly allow a modification, then it may not be done. The philos*ophy of the Zetec engine in FC is to allow limited engine rebuilds but no performance modifications to the engine. Blue printing, balancing, head porting, polishing, etc. are strictly prohibited and against the spirit of the Zetec formula. Where Ford part numbers are specified, normal industry part number supersession is expected and the superseding part numbers are automatically included."
    I'll bet if we had a proper SCCA tear-down at the Run-Offs that these illegal modifications would have be found years ago.
    The increase of power in the Zetec, over when it was first allowed in the Pinto powered FC class, has nothing to do with a newer design but performance improvements that have not only, not been kept in check by race organizations, but with those same groups having turned a blind eye to the practice.
  6. #364
    Liked: 1469
    My 38 is being race prepped right now. If tuned correctly one of the biggest benefits is even burn across the cylinders and better low end response. I should have mine for the ButtonWillow race at month end.
  8. #365
    Liked: 1469
    As I've been told they just won't tear 'em down without a racer challenge. They aren't police.
    Just think if that was the way the real police operated.
    The quick-tech-check they do at the majors involves checking the restrictor only. Whoopee....
  9. #366
    Chatham Center, New York
    Liked: 1073
    I think there is a need to understand the word "blueprinting" in context to the above post. The word was use by someone advertising their car. The engine builders our series use seal their motors: that seal is their certification (and their reputation) that the motor is legal to the rules. Our rules and SCCA dovetail, and we accept that the sealed motors in our series are legal. When we think otherwise, we check them (pull intakes and exhausts, cc them, use bore scopes, etc). We have never had to tear a motor to the crankshaft yet and yes, we have tech people who know how to do it.
    But this thread is about Pinto upgrades. The package as it now stands should be very potent, and the motors should last far longer between rebuilds than what I experienced when I raced them.
    I also know that QS will be very accommodating if they can do group rebuilds (more than 5 motors at a time) so they can set up an assembly line. They also have very reasonable shipping costs.
  10. #367
    Liked: 2039
    I'd still like to see details of just what these "illegal" modifications are that are alluded to every once in a while. In reading the GCR, there are actually quite a few areas that are allowed to be modified that can all help gain HP, and I would bet that the builders are doing just about everything they can to find the best combination of dimensions withing what the rules allow.
    Selective parts building is perfectly legal, if that is what is going on, and can indeed yield extra HP.
  11. #368
    Liked: 1469
    For just about every OTHER engine in the book (GCR) BUT I'd say "selective parts building" flies in the face of
    the GCR " The philosophy of the Zetec engine in FC is to allow limited engine rebuilds but no performance modifications to the engine." Swapping parts for performance (as opposed to replacing worn out parts) is not in the spirit of the GCR.
    Isn't the Zetec the only engine that contains that statement in the GCR?
    kea
  13. #369
    Liked: 712
    Default Pinto
    Richard,
    It may be for some engine types but by the rules that allowed the Zetec in the first place, not legal.
    "The philosophy of the Zetec engine in FC is to allow limited engine rebuilds but no performance modifications to the engine".
  14. #370
    Somerset, Kentucky
    Liked: 126
    What about machining the intake and/or exhaust ports of the heads due to core shift of the casting?
  15. #371
    Liked: 1469
    That's a funny one..... you are kidding right?
    If you're serious, geez, absolutely not. I'd call that a "performance modification".
    The whole 2014 Miata-core-shift fiasco should be a lesson that engine builders don't understand the very rules they write.
    Either they don't understand, choose to be vague, or choose to interpret with a lot of latitude.
    So that makes them either stupid or cheaters. Take your pick.
    Another flaw in the "system".
    On a spec engine correcting core shift is legit. This isn't the case with the Zetec.
  16. #372
    Liked: 2039
    Kea: There are almost 2 pages worth of details on areas that the Zetec can be massaged within certain specifications.
    "The philosophy of the Zetec engine in FC is to allow limited engine rebuilds but no performance modifications to the engine"."
    Define "performance modification" in a manner that it can be followed without questions.
    The GCR allows the building up of a motor as a rebuild. Within what is normal in a rebuild is the use of selected components that are within the specifications in the GCR. Legal, and within what the GCR specifies.
    You are also allowed to sleeve the block, and there are (I expect, anyway) sleeves available that are lower friction. Again, legal and within what the GCR specifies.
    And no, Rob, machining of Zetec ports is specifically not allowed.
  17. #373
    Liked: 1073
    The rules recommendation that came out of the zetec committee was basically to use a crate motor unmodified in any way. What was finally voted on by the BoD had some minor changes which allowed for a little wiggle room, which is what we are talking about here. BTW, if the rule was unmodified crate motors only- we'd be out of business as there are no crate motors anymore.
    I can tell you from experience as both a driver of a Zetec, and owner of the Series for the last 13 years- there is very little difference between a motor that's been 'tweaked' and a straight crate motor. IIRC, Tim Minor won two championships with a crate motor- the same crate motor- and also went to the runoffs with it.
    What goes into making these cars go fast is waaaayyyy beyond the motor.
  18. The following 4 users liked this post:
  19. #374
    Courtice, Ontario, Canada
    Liked: 142
    Sounds like it's time to get a Pinto FC, get the motor updated, and have a giggle!
    Stephen Adams
    RF92 Van Diemen FFord
    1980 Lola T540 FFord
  21. #375
    Livonia,MI
    Liked: 39
    My turn......Here's the solution....two classes, FC /Pinto, FC / Other......all done..... we all race together, let the cars / drivers decide. I'm sure that Michael Andretti driving my '90 Reynard, could have broken track records wherever I raced!!!!!!!
  22. #376
    Liked: 2039
    Can you imagine how expensive these motors would have been had only "as delivered" crate motors been allowed? Crate motor HPs are not all the same, so you would need to buy multiple motors, dyno them all, and select the best one - any you still have no assurance that it will be as good as the next guy's. Add to that, if the requirement was that - only "as delivered" being allowed - by definition you would not be allowed to rebuild them, meaning that you would have to go through the whole process all over again when your crate motor finally wore out.
  23. #377
    Liked: 3795
    That was the case with the Sports Renaults when they first arrived. The engines varied widely and people were dynoing multiple engines to get the best one they could find. When I was doing the testing for them, I tested and ran several different cars, and the engine in every one was different from the rest. One had to have the pee wound out of it to work, another wouldn't get within 500 RPM of redline w/o petering out, but had great torque. And some were just not very good.
  24. #378
    Liked: 1681
    Generally speaking the Club has to act in measured steps as once a rule is put into place it is difficult to pull it back if an error was made. It is a conservative process.
    John
    John - much has been made in this thread about the "process". Given that it's been referred to as a "process" where are the specifics documented? If dyno information is required, what are the requirements? Say Art Smith and I built up a motor and took it down to Bobby Cram's dyno out on Inyokern road and compared that engine against my recent Cricket Farm's rebuild? What would make that data sufficient - or not?
    From Peter Olivia: " It has been my experience that such letters fail to consider all aspects of the process, focusing only on those parts that support the request"
    Again, referring to a "process". What is this process?
  25. #379
    Senior Member pcarnut's Avatar
    NC
    Default Re: comparisons
    I personally would like to see comparisons between Zetec, and "new" Pinto with long rods and pistons. The dirt tracker guys around where I live have been using the long rod short piston idea in their cars for the last several years. Would be interesting to see if and how these various configurations compare and if the "new" (really old) technology in the Pinto is really worth doing.
  26. #380
    Liked: 1073
    Somehow....I betcha QS already has them...
    Rick; the process is fairy specific and has been detailed by John LaRue in other threads. The CRB has a lot of leeway but needs enough information to make an informed decision. It will also take into account long term ramifications of the proposed change. To maybe answer your specific question- data from different dynos usually is insufficient.
  28. #381
    Liked: 1681
    once again, this wasn't about Zetec vs pinto......
  30. #382
    Senior Member LenFC11's Avatar
    Houston TX
    Liked: 239
    Yea... But the same people always make it about that...
    Cheers
    Len
    Porsche River Oaks. Houston
  32. #383
    Contributing Member Latebraker's Avatar
    British columbia Canada
    Liked: 25
    Default Zetec vs Pinto
    If they are running in the same class or group for the same points in a championship it will always be Zetec vs Pinto. As long as we have a competitive bone in our bodies no one wants to give up any competitive edge to the next guy.
    kea
  34. #384
    Dallas, TX
    I'm running a bit behind on keeping up with this thread-thanks to Monte and Purple Frog for your responses! So, if mileage between rebuilds doubles with the new rods and pistons, are we talking about 3,000 miles between rebuilds, or...? And, do the aluminum heads have an overheating issue? I have not heard of this but as I said in my first post, I have been out of it for a while (tired of being an interested spectator...).
    Thanks much!
    -R
  35. #385
    Columbus, OH
    Liked: 482
    Default Aluminum head problems?
    Still curious about aluminum heads based on this short thread:
    http://www.apexspeed.com/forums/show...+aluminum+head
  36. #386
    Liked: 1681
    Well I started that thread and have had no issues. There are still west coast S2000 guys running them. Since there aren't a lot of Pinto FCs coming out you don't see the AL head, but other than increasing the HP, which increases the cooling load, i've had no issues.
    I suppose if it cracks I can get it welded.
  37. #387
    Columbus, OH
    Liked: 482
    Okay, so no apparent user-wide problems with aluminum head. Good to know!
  38. #388
    Southeast MI
    Liked: 266
    I have the solution to this entire fiasco. The claimer rule!
    While I say that in jest it's not an entirely out of left field suggestion. It sure would alleviate the arms race of engine updates and rebuilds.
  40. #389
    Liked: 3795
    ...Since there aren't a lot of Pinto FCs coming out you don't see the AL head, but other than increasing the HP, which increases the cooling load, i've had no issues....
    The fact that aluminum conducts more heat to the coolant than the iron head, which keeps more heat in the combustion chamber, also contributes to an increased cooling load.
  41. #390
    Liked: 1681
    I think you would have to get that from the engine builders. This is just my personal experience.
  42. #391
    Liked: 1469
    I only see a few problems with the Al head.
    1. Cost - about $4k new. At that point other options would come into play. Find a used one (good luck finding and good luck with condition). There was one bare for $1500 a couple months ago. I'm thinking maybe 50 of these were made.
    2. Marginal improvement. It's no Zetec killer if that is what you expect.
    3. Increased operating cost and maintenance. It doesn't improve longevity and does nothing to get cars out.
    Other than that, the long rods, Weber 38 and Al head will make a good engine.
  43. The following members LIKED this post:
  44. #392
    Texas
    Liked: 17
    Default AL vs CI head
    Any thoughts on how an engine with the aluminum head with the original cam compares to an engine with an iron head with the alternate camshaft? I guess what I'm asking is, "how much additional power is in the swap to the alternate cam"?
  45. #393
    Liked: 1469
    Quote Originally Posted by rsmart View Post
    I've got the FC (alt) cam and have never driven a car without it. That said, others have said it help, yet some say it does nothing.
    My conclusion is that it depends on your style of driving's compatibility with your cam of choice.
    Rick can chime in on total power gains but he did mention the 21lb difference is worth about 3hp everywhere.
    Again, my criticism of the AL head is totally related to it's cost and lack of improvement in grid sizes. As I said to Rick, it may be a hindrance as some Pinto owners feel they can't even compete in the Pinto group without a big spend.
  46. #394
    Liked: 1681
    AL head + new Ivey pistons got me +9HP over my decent Ivey Iron head; but those comparisons weren't from the same dyno.
  47. #395
    Columbus, OH
    Liked: 482
    Losing 21# up high and rearward sounds nice.
    Or or we can go nuclear: http://www.burtonpower.com/alloy-cyl...-sc1211as.html
  49. #396
    Texas
    Liked: 17
    Default Same cam in both engines?
    Thanks for the info. I'd like to take 21 pounds off the top of the engine, but I've already got 18 pounds of lead under my knees to make weight. Not sure I've got room for 21 more pounds of lead but the 9 hp gain is certainly attractive.
  50. #397
    Liked: 1681
    there's always the opportunity to run two big varley's and never worry about starting power again.....
  51. #398
    Liked: 3795
    As Rick said - not from the same dyno, so don't count on (all of) the 9 HP gain.
  52. #399
    Liked: 1469
    Apparently you've missed a meal somewhere. Fix that.
  53. #400
    Senior Member FASTDAD's Avatar
    Cannon Falls, MN
    Liked: 50
    Default Here it is
    Straight out of the posted Fastrack -
    1. #24155 (Todd Stark) Request new piston part numberIn GCR section 9.1.1.15.f.6, add the wording as follows:"Wiseco piston P/N WD-06526 as supplied by Quicksilver with rings, pin, Crower connecting rod P/NSP93235B-4 (with bolts), but without bearings: Minimum permitted weight: 555 grams."In GCR section 9.1.1.15.h, add the wording as follows:"Alternative Crower connecting rod part number SP93235B-4 is permitted. It’s length mustbe 5.700 inches (+ or .005 -.010”). This rod may be used only with Wiseco piston part number WD06526as supplied by Quicksilver above."
    I would rather be making racing news than reading it. Living the dream out here in the middle of farm country
