Results 1 to 9 of 9
    Senior Member holmberg's Avatar
    Lafayette, CA
    Default P1/P2 operational costs
    Over on the General Formula Car Discussion topic, I've been conducting a survey of operational costs for each class. Here I'm only interested in costs that differ significantly between the classes, and not, for example, entrance fees, hotel, food, etc.
    Drivers from some classes have responded with data for their class, and the result is a spreadsheet in Google docs.
    Here's what I have for P1 and P2. If you have changes, please reply below, and I will update the spreadsheet.
    First, P1:
    Class name: P1
    Engine make: Suzuki
    Engine model: GSX R
    Displacement: 1000
    Power at crank, HP: 197
    Torque at crank, ft-lbs: 86
    Weight with driver, lbs: 1,000
    Purchase new, $: 90,000
    Tires set, $: 1006
    Tire competitive heat cycles: 8
    Engine rebuild, $: 5,000
    Engine competitive hours: 27
    Fuel $/gallon: 10.00
    Fuel gallons/hour: 10
    Brake pads set, $: 188
    Brake pads hours: 27
    Other operational costs, $:
    And for P2:
    Class name: P2
    Engine make: Suzuki
    Engine model: GSX R
    Displacement: 1000
    Power at crank, HP: 180
    Torque at crank, ft-lbs: 80
    Purchase new, $: 80,000
    Tires set, $: 1006
    Engine rebuild, $: 3,500
    Greg Holmberg
    Paso Robles, CA
    Liked: 314
    Class name: P2
    Engine make: Mazda
    Engine model: MZR
    Displacement: 1999cc
    Torque at crank, ft-lbs: 160
    Weight with driver, lbs: 1,300
    Purchase new, $: NA
    Tires set, $: 980
    Tire competitive heat cycles: 6
    Engine rebuild, $: 3,100 -- not rebuilt - New from Mazda
    Engine competitive hours: 5000+ mi in USF2000 usage.
    Fuel $/gallon: $2.85
    Fuel gallons/hour: 9
    Brake pads set, $: 290
    Brake pads hours: 25+
    Other operational costs, $: Pays Mazda Contingency for winning.
    David Ferguson
    Veracity Racing Data
    Shift RPM App for iOS
    805-238-1699
    Contributing Member farrout's Avatar
    Sanibel, FL
    For both P1 and P2, using a Purchase Cost of a new car does not tell the entire story. Many drivers will purchase a used car which can still be competitive Nationally but as we all know it is the driver that whittles away those last few seconds. A Stohr WF1 can be had for anywhere from $35K to $60K. A lot of that price is dependent on the car's pedigree and the level of spares.
    Craig Farr
    2006 Stohr WF1 P2
    FARROUT Racing
    Lafayette, CA
    David, I added a line to the spreadsheet and inserted this data.
    Class name: P2
    Engine make: Mazda
    Engine model: MZR
    Purchase new, $: NA
    Tires set, $: 980
    Savannah, GA (via Montreal)
    Liked: 976
    Class name: P2
    Engine make: Mazda
    Engine model: MZR
    Purchase new, $: NA
    Tires set, $: 980
    Hi David,
    Please clarify, you get 197HP for 5,000 hours (!), then replace it with an entirely new engine for $3100 ? Builder? (Elite?)
    Paso Robles, CA
    Liked: 314
    I indicated 5000 miles, not 5000 hours. Let's guess that might be 65 - 75 hours of racing -- 3 - 4 seasons for most folks.
    You can purchase a complete long block from Mazda for $3100 (plus tax and shipping). I can move my parts (dry sump, front pulleys, water pump, intake, fuel rail, exhaust, various cover plates) to the new engine in a few hours and install it in the car), and it will make the same horsepower (used to be 200+, but my new dyno software has a different correction, now the same data is 197hp).
    You can also have this done by Elite, and they may charge you $2500 to disassemble and re-assemble the new engine, plus the $3100 for a new long block.
    To be clear -- the parts to prepare a $3100 engine for racing will probably cost $10-12k, but they don't need to be replaced very often. I'm talking about Dry Sumps, Intakes, Injectors, ECU, wiring, sensors, flywheel/clutch, exhaust system.
    David Ferguson
    805-238-1699
    Lafayette, CA
    The P2 lap record at Thunderhill (2.866 miles) is 1:42.187, or 101.0 mph. So a rough guess would be 5000 miles / 100 mph = 50 hours. That's what I put in the spreadsheet.
    That works out to be $62/hour for the engine, or $207 for the weekend in my 8-session scenario. Which is pretty low for this level of performance. The MC engines in P2 cost twice that to operate per hour (mostly due to shorter lives). The $3/gallon fuel helps lower costs too.
    Paso Robles, CA
    Liked: 314
    I have a hard time doing every lap within 1 mph average of the lap record. But perhaps that's easy for you.
    David Ferguson
    805-238-1699
    Lafayette, CA
    OK, it appears that all the discussions in all the communities have died out, so you can find the results in the spreadsheet.
