Results 1 to 15 of 15
Thread: Ralt RT-40
    Administrator Keith Roberts's Avatar
    LaGrange, Georgia
    I've decided I can't make time to get this to the track. I purchased it in October 2015 from Rick Ross who had done ALOT of work to get it top condition but never finished assembling it.
    We got it here at my shop and finished the job over a period of about 4 months.
    All the critical components have been crack checked.
    The tub was gone through at Algie Composites.
    Dyno time only Loyning engine w/carbs.
    Top of the line PI "Delta" logger and dash.
    Fresh "everything"
    Has numerous spares, gear sets, wheels (unassembled) that I have not inventoried
    Needs belts and a couple of little things.
    $32,000
    Keith Roberts
    Located in Lagrange, GA 30240
    706-407-1850
    Ralt RT-40 Formula Atlantic
    Chassis #1015
    Engine
    • Zero-mile fresh Loyning Toyota 4AGE #1074 (dyno time only)
    • Weber carbs
    • TRD ECU and coil packs
    • New throttle cable
    Dampers
    • Ohlins TT44 dampers
    • 5-way adjustable
    • Valved specifically for the RT-40/41
    Data Acquisition
    • New Pi Delta System with Expansion Module and Harnesses
    • New Omega D1 dash display
    • New GPS speed sensor
    • New Shift light module
    • 16 MB memory, 200 Hz logging rate, 22 analog channels
    • USB download cable
    • Custom dash panel with all new switches and placards
    Gearbox
    • New bearing carrier
    • Salisbury LSD with Atlantic ramps (rebuilt by K-Hill)
    • Pre-load and backlash set/verified
    • All new apex joints in shift linkage
    • All new saddle washers in shift linkage
    Brakes
    • New brake master cylinders and reservoirs
    • New caliper pistons and seals
    • New caliper fluid cross-over pipes
    • New rotor bobbins
    • New brake lines
    • New brake bias adjuster
    • New brake pedal bushings
    Fuel System
    • New fuel pumps (2)
    • New fuel pressure regulator valve
    • New fuel lines and filters
    Oil/Cooling
    • Oil tank cleaned out and side engine mount threads repaired
    • Oil cooler ultrasonically cleaned
    • Radiator ultrasonically cleaned
    Suspension/Steering
    • New Hyperco hydraulic spring perches (4)
    • Rebuilt steering rack (K-Hill)
    • New rear rocker mounting block by Fast Forward
    • New rocker bearings and thrust washers
    • New custom made front damper mount
    • New “Pro-Coat” black coating applied to most suspension pieces
    • All worn rod ends replaced
    • Uprights inspected and cleaned by Fast Forward
    • New steering shaft apex joints
    Tub
    • Tub No. 1015
    • New engine mount studs in tub
    • Re-bushed engine trunion aft mounting holes
    • New Halon fire bottle and new mechanical activation cable
    • New battery and starter electrical cables
    Wheels
    • Two disassembled sets of Jungbloed wheels
    • Jungbloed wheel centers crack checked and re-coated
    • One set of Kodiak wheels
    LaGrange, Georgia
    Default Nobody?
    Not one inquiry.
    Priced too high?
    I thought that with everything that has been done to the car and the very high end Pi system I would get "some" interest..
    Senior Member Nardi's Avatar
    Southeast
    Liked: 126
    I'm surprised as well. Sounds like a reasonable package & price to me. But then again, I have four cars that I don't have time for so what do I know!
    Good luck with the sale..... I'm sure it will come.
    Liked: 573
    I know how meticulous both Keith and Rick are, and I've been hearing about the refurbishing (for the past 3-5 years?), so there's no doubt in my mind that this car is as close to perfect as possible.
    There are only two reasons why I haven't bought it (and you can probably guess them. :-)
    Good luck with the sale (but I'm disappointed we wont be racing together like old times).
    Senior Member bill gillespie's Avatar
    atlanta
    Liked: 101
    Quote Originally Posted by Keith Roberts View Post
    Not one inquiry.
    Priced too high?
    I know a little bit about Rt40 & 41s.....this is an amazing deal, and a giveaway price for the car...and , yes, I have looked at it closely.....The RT40 is still faster than most of us.....Villeneuve and Bourbonnais were practicing in the 13"s at Road Atlanta with the Dip....
    Regards,
    Bill
    Liked: 3979
    Having purchased a car from Keith in the past... very reputable seller.
    You are talking about one of the fastest cars in SCCA racing at about 1/3 the price of a competitive FC.
    A lot of bang for the buck.
    LaGrange, Georgia
    Default Pictures posted
    I've had a few requests for pictures. I've uploaded an album to my Amazon drive at:
    https://www.amazon.com/photos/share/...cruhC3m7DMXWmn
    LaGrange, Georgia
    Default Still available
    I've had a few inquiries but no deal yet.
    LaGrange, Georgia
    Default Sold!
    Sold
    Default Where is it now?????
    I was just talking with Keith (the seller), and we were wondering what happened to this car? It was bought by someone who was a VIR member, but we can't recall his name. This was a really nice Ralt, and I hope someone has been enjoying it for the past few years.
    Does anyone have any ideas regarding the status/location of this car? Thanks!
    Anderson, South Carolina
    I am a VIR member and run a couple cars in the open wheel category but don't recall seeing this car last year. Of course, if the color was changed from these photos, it may have been there in 'disguise'.
    Thanks for the response. I actually recently located this car and touched base with the owner. He has not had the car on track since his purchase. Hopefully the car will make an appearance at VIR soon.
  17. #13
    Arlington, Texas
    Liked: 105
    Default Rt40
    Could it be for sale?
  19. #14
    pardeeville , wisconsin
    Default rt 40
    car still for sale ? art jahn 608 617 3793
  20. #15
    Default rt 40
