Results 1 to 10 of 10
    PA
    For Sale Aluminum 26ft Rance Stacker for Sale
    PRICE REDUCTION. This rig is perfect for hauling 2 formula cars or 2 sports racers. We are downsizing. Very lightly used and in fantastic condition. Located in West Chester, PA. Asking $23,000.
    Specifications:
    • 26ft long box
    • 31ft overall length
    • 105ft exterior height
    • 90in interior height
    • Built in 4/2011
    • 6,000lb Axles - 12,000lb GVWR possible
    • GVWR de-rated to 9,990 so no CDL is necessary
    • 6,643lb empty weight
    • TAG
    • Electric lift (4000lb)
    • 13.5K BTU A/C & heat
    • Generator box with slide-out tray and vented door
    • E-Track on floor and walls
    • Aluminum floor & ramp
    • Transition flap
    • 5ft ramp extension
    • Hydraulic tongue jack
    • Winch plate (no winch)
    • Upper & lower cabinets
    • Dark silver exterior
    • 3 x 48in ceiling mounted lights
    • Electric roof vent
    • Two-way vents
    • Bogey wheels
    • Aluminum side door slide-out step
    • 30 AMP panel with receptacles and switches (interior and exterior)
    • Exterior flood lights (side and rear)
    • 22ft Awning (currently removed with some damage)
    • LED running lights
    • In-floor battery box
    • Wall-mounted spare tire
    • 16in Aluminum wheels
    • Rear ramp twist handles with internal locks
    Images
    Michigan
    Liked: 28
    Default Rance
    I am interested to know the empty weight of the trailer as well as the total load capacity and the GVWR.
    Can you also provide more detail on the awning that was mentioned as damaged?
    Thanks!
    Tampa, Florida
    Quote Originally Posted by Firesmith View Post
    Thanks!
    x2, I'm more curious in weight as next year I'll have a second car and need to go to something like this as well.
    PA
    Great question, I should have included that info in my post. The empty weight is 6,643lbs and the GVWR is 9,900lbs. That gives you 3,257lb of cargo capacity. Here is an image of the VIN plate:
    PA
    The awning is a Forest River 22ft 9000 series model. According to the mnf, they do not make replacement parts for the 9000 series. The cost for a new one would be $1,200 - $1,400; however, the mounts on the trailer are such that you could install almost any 22ft awning.
    Also, the trailer has 6,000 axles but we de-rated the registration to 9,900lbs so no CDL would be necessary. If you wanted to re-register the trailer with a 12,000 GVWR you could. Hope that helps!
    Michigan
    Liked: 28
    Default Double Checking Overall Height
    Can you please confirm the overall height of the trailer? It certainly does not look like anywhere near 12 feet in height from the pictures. If that specification is incorrect, what is the actual interior height?
    I am very interested but just trying to get all the details correct.
    Liked: 1469
    Quote Originally Posted by ncbted View Post
    Kinda heavy for an Aluminum trailer. Most 24s I've seen are under 3500#. I guess there's 3000# of added equipment and the extra 2ft... but at 10k it carries 1 road car. Even uprated to 12k it's barely 2 sedan race cars......
    Very nice trailer if it works for you....
    PA
    You are correct, I just went an measured the trailer and it is only 105in tall, or just over 8.5ft. I screwed that up because the drawing said +12in and I read that to mean 12ft overall. 12 feet would be insane! My apologies! The interior height is 90in.
    PA
    Priced reduced to $23,000.
    Member GrahamLoughead35's Avatar
    Carmel, IN
    Liked: 35
    Still available?
    Graham Loughead FV #35
    Formula Vee Hall of Fame Founder
