Originally Posted by
Malfred
What engine is in your Radical ? Who built the engine ?
How many hours on the engine / trans combo ? Condition of clutches is critical as well.
Does it have stainless steel valves or are they the stock titanium valves ? How many HP ? or is it stock ? Carbs of FI ?
Any spare wheels & tires come with the car ? --- You will need at least one spare set of tires mounted & balanced & ready to put on the car as a flat can happen to any one, any time.
A spare nose is a highley recomended Item for any sports racer.
Do you have a way to add air to your tires at the track ?
Fuel Juggs, D-funnel, tools, super accuate tire pressure guage, long handle torque wrench, specal socket & extension to fit wheel nuts, fuel transfer pump, tires & wheels, extra oil, spare chain, chain lube, low profile lift jack to get car up off the ground on both ends, racer tape that matches car color, Book to write your on track settings & changes, battery charger & long extension cord, small generator, extra rear sprocket set, etc. , etc... would be a good start.
m.
