Page 3 of 5 FirstFirst 12345 LastLast
Results 81 to 120 of 184
  1. #81
    Liked: 3326
    Default Pro F2000 VIR Gearing?
    From the baseline gearing sheet, it appears that VIR requires gearing similar to that required for Nelson Ledges, or maybe Mid-Ohio.
    I used 19/32, 21/30, 23/29, 19/21 at both M-O and Nelson, when I was there last in 2007.
    Anyone have any updates on that selection based on using the Hoosier radials?
  2. #82
    Senior Member Ian McKechnie's Avatar
    Rockaway, New Jersey
    Default Gearing for NJMP Thunderbolt
    Now that the Thunderbolt track has had its first year of racing, does anyone have a suggestion for starting gears for the track (for 10:31 final drive)?
    Ian L. McKechnie (dad)
    Crewchief FC 61
  3. #83
    Junior Member fcmazaracing's Avatar
    new jersey
    Default Need Formula Continental Setup Gears for NJ Motorsport Track
    Need Formula Continental Setup Gears for NJ Motorsport Track - This is my first time attending the NJ Motorsport Track on June 6-7th 2009 and was wondering if anyone had the gear setup for Formula Continental (Pinto Engine). Any help would be much appreciated!!
    Luis Maza
    FC #30
    Luis Maza
    FC# 30
  4. #84
    PLANO
    Liked: 35
    Default New Jersey
    Luis
    Here is a base for T Bolt
    10-31 7000rmp 22 tire
    17-28 89.6 mph
    18-25
    21-25
    23-24 142.1 mph
    Hope this helps ya
    Scotty
    Taylor Race Engineering
    scotty@taylor-race.com
    Scotty
    Est. 1990
  5. #85
    Member Randy46's Avatar
    Salt Lake City, UT
    Default Reno-Fernley Gearing??
    Please post your requests for baseline gearing setups in this thread. It will prevent redundant requests and also make it much easier to find.
    BASELINE GEARING FOR MOST TRACKS
    Does anyone know a good baseline gearing for Reno/Fernley. Formula C, 22 inch, shift at 7000? Thank you in advance for your guidance.
  6. #86
    Salt Lake City, UT
    Default Gearing for Fernley/Reno
    Does anyone have a good baseline gearing for Fernley/Reno. 22 inch, shift @ 7000, Formula C, Pinto. Thank You.
  7. #87
    North Eastern NJ
    Default Gearing - NJMP Lightning FC
    I just did a site search and a top to bottom review of this thread and came up with nothing...
    I'm guessing, close to Summit Main:
    1- 19/33
    2- 20/30
    3- 23/29
    4 -24/26
    Anyone have any ohter guidance.
    (Pinto FC 10:31) for NJMP Lighting (EMRA/FPR July 10-11, 09).
  8. #88
    Senior Member FASTDAD's Avatar
    Cannon Falls, MN
    Liked: 40
    Default Milwaukee Mile
    Going to the Mile for the double regional and am wondering if anybody has an idea for gearing selection. FC with a pinto.
    I would rather be making racing news than reading it. Living the dream out here in the middle of farm country
  9. #89
    Contributing Member SWMyers's Avatar
    Saline, MI
    Default Road Atlanta
    Thinking about the ARRC. Anyone willing to share base gearing for Road Atlanta?
  10. #90
    Default Baseline Gearing For Local Tracks
    Looking for Baseline Gearing for my local tracks, Laguna, Sears and Thunderhill. I will be running a 94 VD Pinto. Any help will be much appreciated.
  11. #91
    Member frankwissman's Avatar
    Belmont, CA
    Default SFR Gearing
    Hi, Instinct,
    Here are three sets of ratios for Thunderhill, mine is the 1st column, 10/31 R&P:
    1st 17/35 17/35 17/35
    2nd 20/32 19/31 18/29
    3rd 22/30 22/30 19/25
    4th 24/28 23/27 24/27
    I use the same at Laguna and can't speak for Infineon. My motor was going soft last year so I would not run anything taller but still had a good time.
    Cheers,
    FW
  12. #92
    Liked: 97
    Default Palm Beach International Raceway gears FC?
    Does anyone have gears yet for a 95 or 2001 Van Diemen FC car at PBIR, the new Moroso? 10/31 RP.
    Thanks very much!!
    Skip Weld
  13. #93
    North Bend, OR
    Default Spokane County Raceway gearing
    If anybody has run at Spokane, would you be willing to share gearing or setup advice?
    Daryl
  14. #94
    Tacoma, Washington
    Liked: 210
    Daryl,
    We've never run Spokane. But Michael Lensen has. Get ahold of him. He will give you gearing.
    If you cannot find a contact for him, I'll try to get his E-mail.
    Rick Broadhead
  15. #95
    Huntsville, AL
    Anyone have any guidance for gearing they might run with a 10:31 at Barber on Hoosier 7" and 9" tires? Thanks.
  16. #96
    Default NJMP Lightning
    Need suggested starting gears for the NJMP Lightning track.
    Crewchief FC 61
  17. #97
    greenville, sc
    Default Gear Ratios for Barber
    Hey All,
    Got a friend who'll be running Barber Motorsports in Sept. in his 97 VD FC. Any suggestions on good gear ratios for that track. Any input is appreciated. I'll be running CSR.
    Thanks, Tony
  18. #98
    Administrator dc's Avatar
    Chicagoland, Illinois
    Liked: 1417
    You should really check the Baseline Gearing thread stickied at the top of this forum...
    FC Gearing for Barber Motorsports Park
  19. #99
    Senior Member Buc01's Avatar
    Moore, OK
    Liked: 73
    Default Gearing for Hallett
    Fellow FC racers:
    I have looked through the baseline gearing chart here on Apex, this is great information so Thank You.
    The gearing that is suggested with a 10:31 is:
    1st 16/35
    2nd 18/33
    3rd 20/30
    4th 23/28
    This is great information but Hewland nor Webster make an 18/33 for the LD-200.
    So, I am asking for advice on gear ratios (10:31, LD-200, 1991 VD FC, 22" rear tires) from fellow VD FC racers that have run Hallett.
    Thank You,
    Aaron
  20. #100
    Contributing Member Ken Lawrence's Avatar
    Tulsa, OK
    Liked: 53
    Default Hallett gears
    Aaron,
    I run COMMA at Hallett and run the following gears in my RF2000 FC.
    17/34
    19/33
    19/27
    23/29
    Ken Lawrence
  21. #101
    Moore, OK
    Liked: 73
    Ken,
    Thank you very much for the information. Looking forward to getting out there and racing with you. Did you run the race last weekend?
    I am targeting the upcoming August 22 weekend for my first outing in the car.
    Aaron Strouhal
  22. #102
    Senior Member bhayes's Avatar
    Pendleton, IN
    Liked: 65
    Default Blackhawk Farms
    Can anyone share a starting point for zetec gearing at Blackhawk Farms.
  23. #103
    North Bend, OR
    Default Gearing for Oregon Raceway Park
    If anybody's been out to ORP, would you be willing to share gearing suggestions? Since my car is such a mongrel of parts it would help if you also shared a comparison of gearing at a track I'm familiar with such as PIR (w/ or w/o chicane, Pacific Raceways or Spokane).
    Senior Member gcoffin's Avatar
    Verdale, Washington
    Liked: 145
    Default orp
    Use your 3rd gear for Portland with the chicane for top gear and go up a couple gears from same for low gear......just a rumor I heard fromsome of the S2000 guys
  25. #105
    Contributing Member tjcezar's Avatar
    PA
    Any gearing suggestions for Shenandoah 10:31 RP
    Better to have raced for a day...
    than been a spectator for life!
  26. #106
    If you do not get any info on this track at Summit Point, go to:
    Formula Race Car Club of America
    or to the DC Region of the SCCA
    Crewchief FC 61
  27. #107
    Senior Member Becker Motorsports's Avatar
    redondo beach, calif.
    Nick, these are the gears we use at Buttonwillow
    1 st 16.35
    2 nd 17.28
    3 rd 22.29
    4th 24.27 or 24.26
    4th gear selection depends on any wind effecting the track, or how dialed in the driver is!
    more often we use the 24.27
    regards Ernie
  28. #108
    Senior Member roun0016's Avatar
    Minneapolis
    Default x
    x
    Patrick M Rounds
    #27 - RF97
  29. #109
    Liked: 3326
    Default Gears for Watkins Glen?
    I have some old info on this, but the Zetec seems to require significantly different gears than the Pinto does. And, since I have not run the Glen since 1992, I need a more current gear set-up that would apply to the Zetec as used with the spec Hoosier radials. My R&P is 10:31.
    Thank you in advance for any help you can give me.
  30. #110
    Pendleton, IN
    Liked: 65
    Dave,
    You have email
  31. #111
    Muleshoe, Texas USA
    Liked: 161
    Default Pikes Peak (PPIR) gearing
    Pikes Peak (PPIR) is new to us in two weeks so I thought I would seek the greater knowledge - I will be in an S2 but FC gearing will give me info for the decision. 10 31 r & p
    Thoughts?
    JM
  32. #112
    Contributing Member blackbmwk1200r's Avatar
    Great Falls, VA
    Default Shenandoah FC 10:31 Baseline Gearing
    Looking for suggestions on baseline gearing at Shenandoah?
    Senior Member Michael Edick's Avatar
    Pine Grove, CA
    Default CF gearing for Buttonwillow 25CCW?
    Just as the title says!
    (I did a search within the thread and didn't find anything)
    Thanks!!
    www.mteengineering.com
    1969 Lotus 61 FF, chassis #226
    1978 Ralt RT1 FSV, chassis #144
  34. #114
    Liked: 3326
    Default F2000 Zetec (Pro map) Gears for NJMP Thunderbolt?
    As the title says, does anyone have a good gear setup for Zetec F2000 that they have used at this track? I have never been there, and with the limited practice time, I would like to avoid having to experiment with gears during the F2KCS weekend.
    Thanks for any help you can give,
  35. #115
    North Bend, OR
    Default The Ridge Motorsports Park gearing
    I know nobody's raced there yet but but perhaps somebody can compare the speed (gearing) with one of the other tracks out here? The front straight looks pretty long on the track map so maybe I'll just play it safe and leave the gearing I'll be running at Spokane in the car. Any thoughts?
  36. #116
    Bethel CT
    I think most of us are in the same boat,Dave. Even if we coiuld come up with some corner speeds it would be a little helpful.
    Mountain Lion Motorsports
    Danbury,CT
  37. #117
    Can anyone give me an idea of what gears to start with at the NJMP Lightning Raceway for a Pinto FC with a 10:31 final drive and an LD200 gear box? It would be very much appreciated.
    Crewchief FC 61
  38. #118
    Senior Member anthonywill3's Avatar
    Lower Slower Delaware
    Quote Originally Posted by Ian McKechnie View Post
    I ran Summit Point gears there, which should be pretty close for you. It was good enough to get me into the low 1:05's...
  39. #119
    Sarver, Pa
    Yep ! That's what I was going to say. Depending on how well you can get off the banking you might go with a little higher top. Loved the track, hated the tow !
  40. #120
    Great Falls, VA
    Hi Ian,
    Last year with FRCCA at NJMP Lightning we used the baseline gearing suggested in this forum for Summit Point except for top gear where we started slightly taller with 25:27's instead of 24:26's. We were still working through some new car issues and can't really comment on gears 1-3, but we did find the 25:27 too short for the front straight and ended up going with 23:24 (our next available gear).
    Sid Smith
