Page 4 of 11 FirstFirst 12345678 ... LastLast
Results 121 to 160 of 434
  1. #121
    Danbury, CT.
    Liked: 2174
    Default Homestead gears
    Thanks Champ !
  2. #122
    Senior Member Scott Hanba's Avatar
    Commerce Twp, MI
    Default Gear Ratios for MSR Houston
    Finally getting my FF together. Hoping to do the MSR Houston Dbl reg in January. Looking for suggestions on gear ratios, or min & max speeds for MSR Houston to get me in the ballpark. I have a 10:31 R&P, please supply R&P with your ratios.
    Scott
  3. #123
    Akron, Ohio
    Default Roebling Road gears
    Need gearing for Roebling Road . 10-31 R&P
    Happy New Year!
  4. #124
    Petaluma, CA
    Liked: 675
    Default Buttonwillow
    Anyone got Buttonwillow gearing, 25 clockwise configuration? 10:31 or other, I can do the math...
    -Ethan
    Ethan Shippert
    https://www.norwestff.com
  5. #125
    Liked: 931
    Default Buttonwillow #25 CW
    It's been a while since I ran BRP (and I'd like to think that I'm a little better than the last time) but here's what I used the last time out (DB6, 10/31, Hoosiers):
    17/35, 20/32, 22/30, 24/28
  6. #126
    Liked: 931
    Post #46 had some info - I hope you ween't trying to get this info for last weekend!
    savannah >>>here's something 20/32 21/30 24/28 25/25
    here's something else...run a taller first than above, just a tooth or two under the second ratio...use it as an alternative second if you're slowed a little by traffic in turns 5-6 ..also get a one tooth under fourth - if the wind is coming strong from the west, run it
    Personally, I've tried both gearing so I only used 2-4 in the race and for using 1-4 during the race. My fastest laps were using 2-4 but it was also my second time at the track and I had THE driver coach helping me (James Lee).
  7. #127
    Contributing Member PaulT's Avatar
    St. Charles, IL
    Default Table Info
    Back in Feb 07, This was posted
    Quote Originally Posted by Whoomah View Post
    This is in the baseline gearing file for a 10:31
    Texas World Speedway (2.9 config.) 18/33, 20/30, 23/29, 24/26
    http://www.apexspeed.com/resources/baseline_gearing.htm
    Curt
    Does someone know the tire size associated with the gearing in this chart?
    PaulT
  8. #128
    Classifieds Super License Scotty Segers's Avatar
    Keller Texas
    Those are the correct gears for TWS 2.9 or 1.8 counter clockwise using standard Goodyear FF tires.
  9. #129
    St. Charles, IL
    Default Standard GY Tire
    Since I have a vintage Lotus that uses Dunlops, I have no idea how big a standard Goodyear Tire is? Can someone help me move past the last oil crunch (70s)?
    Paul
  10. #130
    Liked: 931
    The GY rear tire is listed at 22.5 diameter (Hoosier says the same thing).
    My measurements for the rear GY tire has been between 22.2 and 22.75, which makes 22.5 a reasonable number to use for your conversion.
    What's the diameter (or circumfrance, which is what I measure) of the Dunlops? I seem to think thay were a little taller or was that just the fronts?
  11. #131
    Senior Member T644HU05's Avatar
    Ahwatukee, AZ
    Default Fontana
    I looked, but didn't see anything. Looking for advice on Fontana, with a weak gerbil powering a brick with wheels using a 9:31 spinning American Racers. I have two and a half months to prepare!
    KC
    Man will race anything. It's in his blood. His Soul. He must.
    Kurtis C. Shirley MacLane FV (sold), Lola T644 (sold), Murray FK1 FST (sold), Vector MG-95FF (sold), PRS 82F (sold), Lola T340... AKA PRS82F
  12. #132
    St. Charles, IL
    Default Vintage Dunlops
    Vintage Dunlops are supposed to be 23" OD. So a little taller (~2%)
    Paul
  13. #133
    usa
    Default Road America ?
    Anybody care to share Road America gear suggestions? 9/31 or 10/31 doesn't matter.
  14. #134
    Liked: 931
    From Jake Lamont's book, a great source of info for every FF'er:
    18/34 20/30 23/29 25/27 with 10/31
  15. #135
    Senior Member Ed Erlandson's Avatar
    Burbank, California
    Default Topeka gears
    Can someone give me an idea of gears for Topeka?
    Either 9/31 or 10/31 using goodyear tires
    thanks
  16. #136
    Burbank, California
    Default Fontana gears for 9/31
    this will be a starting point which should not over rev your motor
    it is for 9/31 and the goodyear 22.5 inch tires
    25/25
    21/24
    22/29
    20/30
    it is very hot and dry by june, and the lap times are quite a bit slower than during the winter.
  17. #137
    Senior Member R.DeVoe's Avatar
    Philadelphia, PA
    Default New Hampshire International Raceway
    Gearing for a 10:31 R&P please, thanks.
    "The winner ain't the one with the fastest car, it's the one who refuses to lose." - Dale Earnhardt Sr.
  18. #138
    Liked: 313
    Default NHIS or NHMS gearing
    In Jake's book it is listed as: 17:33, 19:31, 21:30, 23:29 for a 10:31 with a note "Courtesy of Peter Symonds". I haven't been to NHIS in years but am going to run something close to the above next weekend. We'll see how it works out.
    Ed
  19. #139
    Contributing Member todcp's Avatar
    Redding Ct
    Default New Jersey Motorports Lightning Track
    Anyone want to take a guess at a starting point for gears for Lightning?? CFF
    Guess I will bring all my gears and make decisions at the track.
    Tod
  20. #140
    Liked: 313
    Default NJMS gearing
    From the slow lap I did around it in a street car I would guess something close to Watkins Glenn short course gearing as a place to start.
    Ed
  21. #141
    PA
    Default NJ gearing
    Hi Eddie:
    I viewed the slide show of the track that is posted elsewhere on the site. It looked like it had a lot of flow with no 1st or 2nd gear corners. Is that fairly accurate?
    Regards,
    Greg Kokolus
    NCF #56
  22. #142
    Liked: 313
    Default Yep
    Yep, I think it will be a fairly fast track. The slowest corner seem to be the left hander after the bridge. Somewhere on Youtube there is a video of a lap of the track taken from the back seat of my car. The link is somewhere here in apexspeed but not sure I could find it.
    Ed
  23. #143
    St. Charles, IL
    Default Autobahn South
    Anyone have any gearing for the South Autobahn track? Please include final ratio and rear tire diameter if possible.
    Paul T
  24. #144
    Idaho
    Default "what gears for Sandia"
    Looking for a starting point for gear ratios for Sandia in New Mexico, 10/31 c/p
    thanks Terry
  25. #145
    Woodland Hills, ca
    Default Buttonwillow #25 Gears
    I'm going to run at Buttonwillow Raceway in September (New Driver).
    Lola 342, Formula Ford, 9/31 R&P, with American Racers
    The track configuration is Clockwise 25.
    What gears should I start with?
    Thanks..
  26. #146
    Woodland Hills, ca
    Default What gears
    Quote Originally Posted by LesB View Post
    Thanks..
    Can anyone help me??
    Please....
    Les
  27. #147
    Liked: 931
    Les,
    See post #125.
    I assume you can do the conversion....
  28. #148
    Burbank, California
    Default buttonwillow #25A
    I have a 9/31
    used in my EuroSwift with goodyear tires 22.5" tall
    18/33
    21/31
    23/28
    25/26
    If your tires are taller, then you should run lower, meaning
    18/34
    20/30
    22/28
    25/27
    send a message if you need more info, I run at BW often
    Ed
  29. #149
    Senior Member Bill Steele's Avatar
    Not here anymore
    Quote Originally Posted by Ed Erlandson View Post
    I have a 9/31
    18/33
    21/31
    23/28
    25/26
    18/34
    20/30
    22/28
    25/27
    Ed
    Les,
    I have not run BW 25 but Ed's Swift gears are very tall for a Lola 342 on AR tires, I think if you started with his secondary list you would be getting pretty close.
  30. #150
    New Jersey
    Default NJMP Thunderbolt?
    Any thoughts on NJMP Thunderbolt Raceway gearing for a Club Ford (9:31 R&P) ?
  31. #151
    Senior Member andyllc's Avatar
    Columbia, SC
    Liked: 208
    Default Mid Ohio Gearing
    Looking for gearing for Mid Ohio for a FF.
    It will actually be a CF running the hard tires with a 9:31 but gearing from a modern FF would be a good start for us as well (just let us know if it is with a 9:31 or 10:31 so we can convert)
  32. #152
    Senior Member bhayes's Avatar
    Pendleton, IN
    Liked: 65
    Default Mid-Ohio CFF
    Last year when I ran my Z16 there, I used these gears...
    19/31
    22/30
    23/28
    25/26
    This was with a 9:31, runing Hoosier R60's. It may not be the ideal gearing, but it will at least give you a starting point.
    ___________________
    BradHayesRacing.com
  34. #153
    Contributing Member Don Denomme's Avatar
    Massachusetts
    Default NJMP Lightning gears?
    Thinking of going to the race at NJMP Lightning course later this month. Looking for starting point on gears for a 10:31 R&P.
    Don
  35. #154
    New Jersey
    Hey Don! I'd check with Jim MacNicholl, he was the man to beat last time! I think he was running The Glen short course gears, but not using 1st gear? I ran LRP gears, 21:30/22:28/24:27/25:26 and ran the same lap times as Jim. I don't know if the extra shift was helping or hurting me!
    Massachusetts
    These look like 9:31 gears. I can convert them. If not 9:31 they are way off my gears for LRP and the Glen.
    Don
  37. #156
    New Jersey
    Oops, yes they're for 9:31's, I should know better than to forget that!
  38. #157
    Senior Member captdigi's Avatar
    Phoenix, AZ
    Liked: 126
    Default Laguna Seca
    Thinking of making the trek from Phoenix for a regional this year. Any gearing suggestions??
    John
  39. #158
    Round Rock, TX
    Default Eagle Canyon, Texas
    Making a come back. Should be ready for the Double Regional end of March. My DB-1 has 10:33 R&P, how about a good starter gear set for Eagle Canyon.
  40. #159
    Austin Texas
    Hey Walter...Look forward to seeing you back out on the track!! I'll be my first run there too and first time out on the track in about a year. I don't have any idea what gearing to run either... I'm thinking about starting with what I run at motorsport ranch which is
    16-31, 16-25, 18-23, 24-26
    I also have a 10:31 The straights aren't too long and it looks like there are some pretty slow corners leading into them
    Or, you could give Craig Taylor a call and see if he knows...
  41. #160
    Arlington, Texas
    Liked: 105
    Default Gearing for Eagles Canyon
    Walter- Great to hear you are coming back.We should have 12-14 cars if everyone shows up..Michael you should be at the Double National.I would use a 17/33 .20/31,22/30,24/28 to start at Eagles Canyon. Mike Sauce
There are currently 20 users browsing this thread. (0 members and 20 guests)
