Anybody have a good draw bolt they're looking to get rid of ?
Can’t help with a spare for you, but when I wanted one a few years ago, I had to make one. Should be easy. If my memory is correct, the TPI is some odd number, and was tricky to find a die.
Pretty sure it was 9mm. Maybe 9x1.
One on eBay right now
If push comes to shove, call ScottyYoung
The price listed on Scotty's website is only $55.86, his part-no. INV-040390
hardly worth looking for a used one let alone making one or having one made
Mildly curious.. WHY do you need one? Did the old one BREAK, lost? If it broke, any idea why? Isn't it just a 'holder' with no load during normal use? Been quite some time since I had a hewland apart and my memory gets more fuzzy every day :D
This isn't mine but they will break if you tighten them up. The manual says run in until snug then back off 1/2 a turn and pit the pin through the shaft and hole in the head of the draw bolt. I have seen many who tighten them up and it will snap it off due to the load on the thread.
I admire your dedication to completeness. :D:D
All set. Got one from Scotty last week.
