Results 1 to 6 of 6
    Liked: 3325
    Default FC bias spec tire pressure question:
    Since my 1st time running the Hoosier FC club & FRP bias spec tires (43164 front, 43285 rear) will be Mid Ohio at the end of the month, what pressures (cold, hot, front & rear) are you running ?
    Hoosier recommends 15-17 cold and 18-20 hot both front & rear. However, in the past I've always had to take manufacturers' recommendations with a grain of salt, so I'd like to know what works for you so I can have a good starting point.
    zypher cove, nevada
    I’m running 14 to 15 cold pacific f 2000 series works good at our tracks
    Liked: 3325
    Quote Originally Posted by tahoe z View Post
    Liked: 4363
    Dave,
    We found the 18-20 psi range worked well, finishing at 18-19 or 19-20. I don't know what that relates to cold, as I never use cold pressures as a baseline.
    This is old news, but anyone switching from the radials to bias, needs to make sure they put the appropriate spacers with their tripod housings to keep their rear axles contained. If you throw out an axle, you will offset much of the savings from the new tires.
    Also, be careful with your pyrometer, as the construction is much easier to puncture than the radials.
    We found camber settings were not sensitive to grip, but did effect wear. No need to be aggressive with camber.
    Liked: 3325
    Dave,
    Thanks, Greg. I value your knowledge and willingness to share it.
    Destin FL
    Liked: 649
    Dave,
    Geez, overwhelmed as usual.
    Thx Man.
