Over on the General Formula Car Discussion topic, I've been conducting a survey of operational costs for each class. Here I'm only interested in costs that differ significantly between the classes, and not, for example, entrance fees, hotel, food, etc.
Drivers from some classes have responded with data for their class, and the result is a spreadsheet in Google docs.
Here's what I have for this class. If you have changes, please reply below, and I will update the spreadsheet.
Class name: FV
Engine make: VW
Engine model: H4
Displacement: 1200
Power at crank, HP: 60
Torque at crank, ft-lbs: 70
Weight with driver, lbs: 1,025
Purchase new, $: 26,000
Tires set, $: 766
Tire competitive heat cycles: 10
Engine rebuild, $: 1,500
Engine competitive hours: 53
Fuel $/gallon: 3.50
Fuel gallons/hour: 6
Brake pads set, $: 500
Brake pads hours: 13
Gearbox hours: ?
Gearbox rebuild, $: ?
Other operational costs, $:
Greg Holmberg
