Hi All,
In the process of identifying a small coolant leak from a loose clamp, it was noticed that the aluminum cooling pipes going to the left pod are partially worn through despite having rubber padding between them and the frame.
I checked Moses' website and I see the silicone hose parts but not the aluminum pieces. Does anyone know whee these can be sourced?
TIA
