Page 2 of 5 FirstFirst 12345 LastLast
Results 41 to 80 of 184
  1. #41
    Park City, Utah
    Default Buttonwillow Gears
    ...OH GREAT FC ORACLE....
    How about kickin' out some Buttonwillow 10:31 gear recommendations?!?
    ( I promise I won't pass you!!!)( I just want a good look at Rick Kirchner's rear wing!)
  2. #42
    Liked: 1507
    18-34, 20-32, 22-30, 23-28 Your mileage may vary
    I think you've set the record for "lowest goal set", as BW13 is where I'm even slower than usual!
    Found a cracked header and 100% leak in the corresponding cylinder last night, so I'm doing an unexpected head job.
    SLC is a helluva tow to Buttonwillow! 12 hrs?
  3. #43
    Memphis, TN
    Default Gearing for Nashville
    Does anyone have a clue where to start for gearing at the Nasville Track? There is an event there Labor Day.
    Thanks, Mike
    Mike Bass
  4. #44
    decatur, GA
    Default track map?
    Is there a track map available somewhere? That would be the first place to start. We could compare to existing tracks for a starting point.
    I expect that after the first session, there will be a lot of cars with their rear ends up in the air.
  5. #45
    Contributing Member GT1Vette's Avatar
    St Marys, GA
    Liked: 202
    Default Nashville Gearing
    I'm not in a formula car, but I DID stay in a Holiday Inn...
    I've run both, and a good starting point for Nashville will be what you run at CMP. Top end should be very close to the same and both tracks have tight stuff that you'll want a grandma low to pull out of.
    But then a taxi-cab has a bit more bottom end than a Pinto does.
    Butch Kummer
    2006, 2007, 2010 SARRC GTA Champion
  6. #46
    Memphis, TN
    Default Insult
    I'm new at this but I think that taxicab remark was an insult?
    Rick there is a track map at the Nashville speedway site- see if you can figure out how it will be run?????
    Mike
    Mike Bass
  7. #47
    Senior Member ghoneycutt's Avatar
    Default Pocono South?
    recommended gears for Pocono South?
    10/31 R/P
    Greg
    SF86 Reynard FC
    FRCCA http://www.formularacecarclubofamerica.com
    Bill Scott Formula Car Series http://www.bsfcs.com
    BMod Autocrosser http://www.nationalroadrally.com/
  8. #48
    Destin FL
    Liked: 650
    Default RA Gearing
    Fellas;
    I went to the "Baseline Gearing" information on RA for my RF-94/95 (10:31), where it listed:
    • 18:32
    • 20:30
    • 23:28 (yes)
    • 23:24
    Taylor Race Engineering has it at:
    • 19:32
    • 21:30
    • 21:25
    • 25:27
    These are not even close. Any help?
  9. #49
    Lake In The Hills, Illinois
    Default Autobahn Gearing South Track
    Quote Originally Posted by Keith Carter
    Please post your requests for baseline gearing setups in this thread. It will prevent redundant requests and also make it much easier to find.
    BASELINE GEARING FOR MOST TRACKS
    The SCCA Chicago Region is holding a regional race at Autobahn on July 29-30 and it looks like they are going to use the South Track which is 2.1 miles and 15 turns. If you check out the Autobahn web site http://www.autobahncountryclub.net/ you can see the course layout. It is really a nice facility as I went there last year and got a lap of the North Course from the Director of Marketing.
    The South Track looks like you might be able to run similar gears as Blackhawk Farms.
    Does anyone have any gearing ideas for Autobahn for FC or CFC?
    Terry
    Terry
  10. #50
    Lurker Keith Carter's Avatar
    Mokena, IL
    Liked: 447
    Quote Originally Posted by hthierry
    Where did you find this out from? Up until now they have run the North course. It would be good to have another track to add to the books.
    EDIT:
    Nevermind... I found it listed on the Autobahn calendar.
    http://www.autobahncountryclub.net/xCalendarjuly.html
    2003 VanDiemen FSCCA #29
  11. #51
    Default RA Gearing
    Rick,
    I just did a review with Taylor for my 84 Reynard CFC 10:31 ring and pinion for RA.
    Here is what they recommended for me and what I found out from various sources.
    1st - 18:32 = 1.77
    2nd - 20:30 = 1.5
    3rd - 23:27 = 1.26
    4th 24:26 = 1.08 or 25:26 = 1.04
    If you run Grattan also, you will see the ratios there are very close and you can run the same ratios if it is an occasional event Vs your home track. I have not run Road America and am looking forward to the June 17 - 18 race. Perhaps someone who actually has run RA with these or similar gears has a view.
    I would contact Taylor and talk to Craig and get his thoughts.
    Terry
    Quote Originally Posted by Rick Iverson
    Fellas;
    • 18:32
    • 20:30
    • 23:28 (yes)
    • 23:24
    • 19:32
    • 21:30
    • 21:25
    • 25:27
    Terry
  12. #52
    Senior Member Westroc #19's Avatar
    windsor,ont. canada
    Liked: 22
    Default Autobahn gearing
    Has anyone come up with anything yet?
    Corey Collins
  13. #53
    Wichita Ks
    Default Pueblo
    Anyone have gears for Pueblo? I raced there (what seems to be) a long time ago in a DSR but have no notes left and I don't find any on the thread. Seems like they were like Lake Afton- another indication of my age. Thanks for any help!
  14. #54
    Liked: 3327
    Default HPT "Runoffs" course gearing?
    Anyone know what gears to run for the HPT "Runoffs" course?
  15. #55
    Arlington ,Tx
    Default HTP Gears
    Dave- I ran in my FF 17/34,19,32,22/30,24/28.I prepped the FC that finished 2nd to N. Coello and we had 18,34,20/32,22/29,24/27.It is a good starting point.
  16. #56
    Liked: 3327
    Thanks, Mike!
    What rev limit and tire circumference were you using with those gears? I assume it was a 10:31 R&P.
  17. #57
    Senior Member Ian McKechnie's Avatar
    Rockaway, New Jersey
    Default Gears for current SCCA Pocono long course
    Can anyone advise as to the gears I should try for the current (with chicane) SCCA long course at Pocono for a 10:31 final drive??
    Ian L. McKechnie (dad)
    Crewchief FC 61
  18. #58
    Senior Member anthonywill3's Avatar
    Lower Slower Delaware
    Quote Originally Posted by Ian McKechnie
    Ian- This is what I dug up for Pocono (pro) Long course. I am running a close derivative (I dont have all the exact ratios)
    Suggested 19:33, 21:30, 23:28, 25:26
    Say hi to Doug, see you guys Sunday!
    Tony Williams
  19. #59
    Memphis, TN
    Default Gearing For Mid America
    Can anyone give me a starting point for gearing Mid America (near Omaha)?
    Mike Bass
  20. #60
    Senior Member Phil Picard's Avatar
    Carolina Motorsports Park
    Liked: 106
    Default Need Canadian Input
    Seems my cars are going to Canada. And I promised Gear-sets to match. sooooooo any body ever hear of a track called Race City Calgary? and knows what FC MK9 gears work there?
    Phil
  21. #61
    Senior Member RacerDave51's Avatar
    Florida
    Liked: 30
    Default HELP...FC Gateway gears--first timer
    It's my first trip the Gateway in this car so I did a search on the subject and folks have hit all around it but nothing definitive for FC. Is anyone using anyone using a 25:27 or 24:26 (or????) 4th? Some are using 24:27 but that seems low...
    Travis at Taylor Eng. was helpful but admitted their data is dated & not definitive either (3 different numbers).
    DaveK
  22. #62
    Member frankwissman's Avatar
    Belmont, CA
    Default Baseline gearing for N. Cal
    Hi, Could someone share their baseline gearing for Thunderhill and Laguna, please? Also, is there a site to better understand the methodology of selecting gears? Thanks!
  23. #63
    Fallen Friend Mike Allison's Avatar
    Hendersonville, NC
    Default North Course
    VIR...Anyone care to venture a gear selection for Club Ford at the VIR North Course. 9:31 R&P.
    Mike
  24. #64
    Contributing Member jdp526's Avatar
    Texas
    Default Autox gear combos
    Hello, I just found this site tonight and I am going to be looking for lots of info on FC racing. I bought a '90 Reynard recently and the car will need lots of attention before it can be run again. I plan to run the car in autox and solo I events so that I can learn to tune and prep the car. Later on I would like to run in some drivers' schools and possibly some road races.
    The car is set up with 10:31 r&p, and the following gears: 1st 18:25, 2nd 21:30, 3rd 23:28, 4th 25:27.
    Can anyone suggest possible gear combos that would work for medium speed autox events? Thanks,
  25. #65
    North Eastern NJ
    Default Summit Shannondoah Gears?
    Anyone have gear Reccommendations for Summitt Shannondoah Course... FC w/10:31
  26. #66
    Senior Member Gary_T's Avatar
    Regina, Sk. Canada
    Liked: 106
    I'm looking for some gear hints for Mosport in Ontario, Canada. I'm running an '84 Reynard F2000 with a mk IX hewland, 9:31 R/P, 22" rears, and 7K rpm limit.
    Even min/max speeds expected in an F-2000 on Mosport would be a good start!!!
    Gary
    Gary Tholl
    #24 BlurredVisionRacing
  27. #67
    atlanta, ga
    Liked: 136
    Default Barber Motorsports Park (Birmingham, AL)
    Hi All, I did not see Barber listed. Anyone? Bueller?
    Might just have to run it as a 3 speed box!
    GC
  28. #68
    Liked: 3795
    Basically the same gears as CMP...
    ALL 10/31 R&P:
    In '04 with the Tatuus @ Barber:
    FirstSecondThirdFourth
    17 17 21 24
    33 28 29 28
    Sean's gears in '03 Barber: (yes Sean, I keep everything)
    19 22 23 24
    32 30 29 27
    Sean's gears in '04 Barber:
    18 20 22 21
    32 32 30 25
    Mike's gears in '03 Barber w/Reynard:
    18 20 22 24
    33 30 29 27
    Tatuus in '05 at CMP:
    19 21 22 24
    33 31 28 27
    Sean in '04 at CMP:
    19 21 22 24
    32 31 29 27
    Sean in '03 at CMP:
    19 20 22 24
    33 30 30 27
    Tatuus in '04 at CMP:
    17 21 23 24
    28 31 28 27
    Reynard at CMP in '03: (CFC lap record at the time)
    18 21 23 24
    33 31 29 27
    I think Sean liked his '04 gears the best...
  29. #69
    atlanta, ga
    Liked: 136
    Default Thanks Purple Phrog
    That was rather succinct and as usual, quite forthcoming and factual.
    GC
  30. #70
    Albuquerque
    Default Gearing for Sandia Motorsports?
    Anyone have any ideas about gearing a 96 VD for Sandia Motorsports Park in Albuquerque? I did some driving there a few weeks ago and felt I should have been running lower gears. I was just wondering if anyone had any experience there.
  31. #71
    Default Autobahn Country Club FC Gearing
    The Midwest Councill Sports Car Club is holding a race at Autobahn Country Club in Chicagoland area on Oct. 6-7, 2007. Last year the SCCA Chicago Region held a regional race at Autobahn on the South track which is 2.1 miles and 15 turns.
    From the guys who ran the SCCA event last year including Keith Carter, did anyone come up with a good gearing selection for the track??? I know a lot of guys were changing gears after the first sessions.
    The South Track looks like you might be able to run similar gears as Road America.
    Does anyone have any gearing ideas for Autobahn South Track for FC or CFC?
    Terry
    Terry
  32. #72
    sandisfield, ma, usa
    Default '07 hartland park
    has anyone run and like to share new base line gearing for the new confiuration at hartland park topeka, fc , 10/31
    thanks-doug rocco
  33. #73
    Liked: 3327
    Last year I ran: 18/33, 20/31, 22/29, 24/27. I don't think the track changes will make much difference in gearing. I am going to start with these again this year.
    I tend to run taller gears than most, so maybe a tooth down from that would suit you better.
  34. #74
    Senior Member JByers's Avatar
    Livonia, MI
    Liked: 24
    From what I heard there seems to be some different thoughts on first gear but fourth gear is just slightly faster.
    1st 17/33 or 18/34
    2nd 18/29 or 20/32
    3rd 22/29
    4th 21/24 or 24/28
  35. #75
    thanks dave, see you there
  36. #76
    North Eastern NJ
    Default Gearing - Pocono North 1.5 Sweeper
    Does this sound about right FC @ Pocono North Gears w/10:31 R&P
    1. 18/34
    2. 20/30
    3. 23/29
    4. 24/27
  37. #77
    North Eastern NJ
    Default NJMP Thunderbolt Config Gearing
    Anyone have any gearing reccommedations for the NJMP Thunderbolt Config?
  38. #78
    North Eastern NJ
    Default NJMP Thunderbolt Gearing
    With all the racing that went on this weekend at Thunderbolt, anyone willing to share baseline gearing suggestions?
  39. #79
    Liked: 3795
    I heard an unverified rumour that the fastest guys were close to VIR gearing.
    It's a much faster track than first appears.
  40. #80
    Contributing Member Tigaman's Avatar
    Virginia Intl Raceway
    Liked: 67
    Quote Originally Posted by racer27 View Post
    I practiced two seconds under the current S2 record in my Lola and used Summit/VIR 1-2-3 and a 24/27 top. Worked fine and hit the right rpm point at braking for T1 (beginning of the curb). Nice track, fun and fast. T8-T9 is a tough little booger.
    -Peter Krause
    1984 Tiga SC
    www.peterkrause.net
    "The Driver is the Greatest Performance Variable in the Racing Equation"
