    OH
    Liked: 60
    Default Oil Return Swirl Pot
    if my aging memory serves me correct, there are two oil return swirl pots. What is the advantage of one over the other. One was low with a skinny neck and small line connection. The second was fat on the bottom, taller and had a larger AN fitting.
    Prescott, AZ
    Liked: 182
    Xx
    Senior Member tige00's Avatar
    arizona
    Liked: 49
    It does if you for 1 have a round tank. And 2 the taller the tank the better aeration.
    Liked: 804
    Quote Originally Posted by jrh3 View Post
    It will be interesting to hear people's thoughts on this subject. I had assumed a trip through the oil cooler and a properly designed dry sump tank did a good job deaeriating the oil.
    the last thing you want in an oil cooler is heavily-aerated oil; very poor heat transfer :-)
    Pittsboro IN
    Liked: 282
    The skinny one is the newer design.
    We have used both with good results
    OH
    Liked: 60
    What was the reason for the new design?
    Pittsboro IN
    Liked: 282
    I honestly do not know. I would not be surprised if it was nothing more than ease of fabrication and cost.
