Page 5 of 5 FirstFirst 12345
Results 161 to 179 of 179
  1. #161
    Southeast MI
    Liked: 254
    Default Pitt Race
    Any insights on the gearing for the new configuration of Pitt Race? 22" Hoosier rears
  2. #162
    Liked: 3292
    Default Pitt
    I've been running 19/32, 21/30, 23/28, 25/27 with 70.5" circumference (22.4" diameter) radial rear Hoosiers and a 10/31.
  3. #163
    Houston, TX
    Liked: 75
    Default Gearing - MSR Houston
    Any gear ratio recommendations for an FC with 10:31 R&P and Pinto engine running counter clockwise at MSR Houston. Well, while were at it, Eagles Canyon ratios would also be welcome. Thanks
  4. #164
    Senior Member Bob Coury's Avatar
    Jupiter, Florida
    Liked: 79
    Default Daytona gear rations for 13:36/Zetec
    Looking for the subject gears on AR diameter tires please. Can make due with Hoosier data.
    Bob
  5. #165
    Houston, TX
    Liked: 75
    Default COTA Baseline Gearing
    Anyone with Circuit of the Americas baseline gearing insight for a Pinto powered '88 Reynard FC?
  6. #166
    Liked: 3292
    Default Barber Motorsports Park
    Anyone have a gear setup for Barber?
    Citation F2000 Zetec, 10/31 CWP, Hoosier F2KCS spec radials w/ 70.5" circumference
  7. #167
    Pittsboro IN
    Liked: 281
    Anyone have gear advise for MSR Cresson?
  8. #168
    Burlington, WI
    Liked: 391
    Default Gingerman Gears
    Anyone have a known decent gear setup for Gingerman? I have a 13:36 R&P, but I can convert from 10:31. I'm not sure if the suggestions in the baseline database are for the newer long course.
  9. #169
    third stone from the sun
    Liked: 101
    Default swift 016 gear ratios
    need gear ratios for for a swift 016 , laguna seca, sonoma and auto club raceway roval
    thanks,
    dee
  10. #170
    Michigan
    Liked: 238
    Default Cota
    Any ideas on COTA would be appreciated.
    Vintage FB car with 9:31 Mk 8.
  11. #171
    Liked: 1262
    Looking for MSR Cresson... 10/31 final.
  12. #172
    Orlando Florida 32812
    Liked: 605
    Default PBIR / chopped up old Moroso
    Was thinking to run PBIR one last time....... before it maybe becomes a WalMart distribution center?
    There was never a published reply back in 2010 to Skip when he asked about Palm Beach gears and no update to the proverbial "what gearing" list over the many years
    So some considerations......the back stretch seems shorter than Roebling's straight.....the 180+ degree turn at the end of that straight seems rather tight
    so how about comments on this selection for a 10/31 diff '94 Pinto FC 1st = 17/33 (0.5151) 2nd 18/28 (0.6428) 3rd = 21/27 (0.777) 4th = 19/21 (0.9047) Note I think backwards from how some people discuss gear numbers but I've also noticed there are some that think my way. Roughly steps of 13's in between the gears
    Squamish, British Columbia, Canada
    Default Northwest Tracks/ Zetec compensation
    Seattle; Pacific Raceway Park, and The Ridge are not listed here if anyone would like to share their recomendations.
    Is it safe to assume that the bulk of the gearing here is for Pinto setups?
    Would a Zetec car go up a gear across the board or......?
  14. #174
    Knoxville, Tennessee
    Liked: 36
    Planning a track day at National Corvette Museum motorsport park, could use some recommendations. I've ran the track a few times in other things but will be first time with the FF1600 on track. RF78, Avon radials and 10:31
    Van Diemen RF78 #258
  15. #175
    Jupiter, Florida
    Liked: 79
    Default Homestead with Zetec please
    I thought that I had them-can't find them now.
    Thanks!
  16. #176
    Regina Sk Canada
    I already had that chart, but did not see T.H. Thank-you for your response
    Please post your requests for baseline gearing setups in this thread. It will prevent redundant requests and also make it much easier to find.
    BASELINE GEARING FOR MOST TRACKS
  17. #177
    Mulberry, Florida
    Liked: 105
    Default NJMP Thunderbolt Zetec with 13:39 CWP
    Any ideas on where to start guys and gals?
    Hartley MacDonald
    2006 Van Dieman RF06
  18. #178
    Mulberry, Florida
    Liked: 105
    Default Still looking for gear suggestions NJMP Thunderbolt
    Quote Originally Posted by Hartley View Post
    Anyone?
    Hartley MacDonald
  19. #179
    Chatham Center, New York
    Liked: 862
    Start with a 17/35 first and a 21/25 fourth. Fill in the other two equally, but be prepared to change them based on how you drive the track.
