Is it still the procedure at National events to weigh the 2nd driver and car?
Mark
Mark
Mark,
The usual procedure (90% of the time) is that all drivers are weighed on Sat with just those in the trophies being weighed on Sun. On Sat, everyone is usually (again, 90% of the time) directed to the scales right after their final run.
There have been deviations from the above, so do not count on anything stated. Just plan to keep you and your co-driver above min at all times; it's way easier that way! :D
Take care,
So.... refuel before your last run? :D
Ok, so my co driver is going to have to run with a 20 lb weight handicap.
Mark
When I was still driving the Citation in CMod my co-driver and I had an easy to remove 15 lb piece of ballast. It took about 10 seconds to place it and about 5 seconds to remove it.
No one had to run at a disadvantage.
Unsecured ballast = bad idea.
