Time Before: 0.00040 seconds
Time After: 0.00057 seconds
Time Taken: 0.00018 seconds
Memory Before: 516.766 KB
Memory After: 541.477 KB
Memory Used: 24.711 KB
Time Before: 0.00060 seconds
Time After: 0.00105 seconds
Time Taken: 0.00045 seconds
Memory Before: 541.414 KB
Memory After: 542.406 KB
Memory Used: 0.992 KB
SET @@sql_mode = ''
Time Before: 0.00119 seconds
Time After: 0.00130 seconds
Time Taken: 0.00011 seconds
Memory Before: 542.961 KB
Memory After: 543.492 KB
Memory Used: 0.531 KB
SELECT * FROM datastore WHERE title IN ('smiliecache','bbcodecache','mailqueue','bookmarksitecache','navdata','options','bitfields','attachmentcache','forumcache','usergroupcache','stylecache','languagecache','products','pluginlist','cron','profilefield','loadcache','noticecache','activitystream','routes')
id | select_type | table | partitions | type | possible_keys | key | key_len | ref | rows | filtered | Extra |
1 | SIMPLE | datastore | range | PRIMARY | PRIMARY | 52 | 20 | 100.00 | Using index condition |
Time Before: 0.00172 seconds
Time After: 0.00323 seconds
Time Taken: 0.00151 seconds
Memory Before: 546.609 KB
Memory After: 547.523 KB
Memory Used: 0.914 KB
Time Before: 0.00132 seconds
Time After: 0.00500 seconds
Time Taken: 0.00368 seconds
Memory Before: 542.742 KB
Memory After: 2,913.648 KB
Memory Used: 2,370.906 KB
SELECT * FROM session WHERE userid = 0 AND host = '18.222.107.64' AND idhash = '7b8446a67d86b2f9f1965943b4798e4b' LIMIT 1
1 | SIMPLE | session | ref | guest_lookup,user_activity | guest_lookup | 51 | const,const,const | 2 | 100.00 |
Time Before: 0.00573 seconds
Time After: 0.00589 seconds
Time Taken: 0.00016 seconds
Memory Before: 3,416.211 KB
Memory After: 3,416.672 KB
Memory Used: 0.461 KB
SELECT languageid, phrasegroup_global AS phrasegroup_global, phrasegroup_posting AS phrasegroup_posting, phrasegroup_postbit AS phrasegroup_postbit, phrasegroup_showthread AS phrasegroup_showthread, phrasegroup_inlinemod AS phrasegroup_inlinemod, phrasegroupinfo AS lang_phrasegroupinfo, options AS lang_options, languagecode AS lang_code, charset AS lang_charset, locale AS lang_locale, imagesoverride AS lang_imagesoverride, dateoverride AS lang_dateoverride, timeoverride AS lang_timeoverride, registereddateoverride AS lang_registereddateoverride, calformat1override AS lang_calformat1override, calformat2override AS lang_calformat2override, logdateoverride AS lang_logdateoverride, decimalsep AS lang_decimalsep, thousandsep AS lang_thousandsep FROM language WHERE languageid = 1
1 | SIMPLE | language | system | PRIMARY | 1 | 100.00 |
Time Before: 0.00638 seconds
Time After: 0.00668 seconds
Time Taken: 0.00030 seconds
Memory Before: 3,429.992 KB
Memory After: 3,429.938 KB
Memory Used: -0.055 KB
Time Before: 0.00536 seconds
Time After: 0.00674 seconds
Time Taken: 0.00139 seconds
Memory Before: 3,408.219 KB
Memory After: 3,505.469 KB
Memory Used: 97.250 KB
SELECT MAX(permissions & 1) AS perm FROM cms_permissions WHERE nodeid = 1 AND usergroupid IN (1)
1 | SIMPLE | cms_permissions | const | usergroupid,nodeid | usergroupid | 8 | const,const | 1 | 100.00 |
Time Before: 0.00806 seconds
Time After: 0.00819 seconds
Time Taken: 0.00013 seconds
Memory Before: 3,942.164 KB
Memory After: 3,942.695 KB
SELECT * FROM style WHERE (styleid = 20 AND userselect = 1) OR styleid = 20 ORDER BY styleid ASC LIMIT 1
1 | SIMPLE | style | const | PRIMARY | PRIMARY | 2 | const | 1 | 100.00 |
Time Before: 0.01203 seconds
Time After: 0.01230 seconds
Time Taken: 0.00027 seconds
Memory Before: 3,946.109 KB
Memory After: 3,946.734 KB
Memory Used: 0.625 KB
SELECT text, languageid, special FROM phrase AS phrase LEFT JOIN phrasetype USING (fieldname) WHERE phrase.fieldname = 'error' AND varname = 'noid' AND languageid IN (-1, 0, 1)
1 | SIMPLE | phrase | range | name_lang_type,languageid | name_lang_type | 276 | 3 | 100.00 | Using index condition | ||
1 | SIMPLE | phrasetype | const | PRIMARY | PRIMARY | 22 | const | 1 | 100.00 |
Time Before: 0.01341 seconds
Time After: 0.01369 seconds
Time Taken: 0.00028 seconds
Memory Before: 4,644.398 KB
Memory After: 4,644.844 KB
Memory Used: 0.445 KB
SELECT title, template FROM template WHERE templateid IN (4543,4542,5620,5621,6181,5755,5756,5758,5764,5763,5958,5962,5948,5949,5951,5950,5953,5955,5956,5957,5960,5655,5657,5659,5661,5663,6596,6016,6017,6018,6015,6085,5936,5935,5937,5942,5940,6109,5717,5718,5884,5711,5710,5713,5714,5727,5725,6608,6606,6609,6211,4538,4537,4539,4534,4533,5615,5616,7020,6840,5926,6200,6585,6586,5873,5874,5875,6230,0,0,6210,6171,5896,5897,5899,5900,6123,6242,6224,6174,6175,5723,5722,5726,6667,6660,6661,6662,6663,6665,6656,6625,6635,6633,6632)
1 | SIMPLE | template | range | PRIMARY | PRIMARY | 4 | 94 | 100.00 | Using index condition |
Time Before: 0.01537 seconds
Time After: 0.01616 seconds
Time Taken: 0.00079 seconds
Memory Before: 5,270.703 KB
Memory After: 5,272.953 KB
Memory Used: 2.250 KB
INSERT IGNORE INTO session (sessionhash, userid, host, idhash, lastactivity, location, styleid, languageid, loggedin, inforum, inthread, incalendar, badlocation, useragent, bypass, profileupdate, apiclientid, apiaccesstoken) VALUES ('85ec38adeb7be3c01490a5aae68d244b', 0, '18.222.107.64', '7b8446a67d86b2f9f1965943b4798e4b', 1718579671, '/showthread.php?explain=1&goto=nextoldest', 0, 0, 0, 0, 0, 0, 3, 'Mozilla/5.0 AppleWebKit/537.36 (KHTML, like Gecko; compatible; ClaudeBot/1.0; +claudebot@anthropic.com)', 0, 0, 0, '')
Time Before: 0.02309 seconds
Time After: 0.02597 seconds
Time Taken: 0.00288 seconds
Memory Before: 5,579.758 KB
Memory After: 5,579.633 KB
Memory Used: -0.125 KB
