Including Functions.php
Time Before: 0.00053 seconds
Time After: 0.00071 seconds
Time Taken: 0.00018 seconds
Memory Before: 505.578 KB
Memory After: 530.289 KB
Memory Used: 24.711 KB
Connect to Database on Server: 127.0.0.1
Time Before: 0.00074 seconds
Time After: 0.00121 seconds
Time Taken: 0.00047 seconds
Memory Before: 530.227 KB
Memory After: 531.219 KB
Memory Used: 0.992 KB
SQL Query
SET @@sql_mode = ''
Time Before: 0.00138 seconds
Time After: 0.00150 seconds
Time Taken: 0.00012 seconds
Memory Before: 531.773 KB
Memory After: 532.305 KB
Memory Used: 0.531 KB
Datastore Setup
SQL Query
SELECT *
FROM datastore
WHERE title IN ('smiliecache','bbcodecache','navdata','options','bitfields','attachmentcache','forumcache','usergroupcache','stylecache','languagecache','products','pluginlist','cron','profilefield','loadcache','noticecache','activitystream','routes')
idselect_typetablepartitionstypepossible_keyskeykey_lenrefrowsfilteredExtra
1SIMPLEdatastore rangePRIMARYPRIMARY52 18100.00Using index condition
Time Before: 0.00199 seconds
Time After: 0.00554 seconds
Time Taken: 0.00355 seconds
Memory Before: 535.328 KB
Memory After: 536.211 KB
Memory Used: 0.883 KB
Time Before: 0.00152 seconds
Time After: 0.00854 seconds
Time Taken: 0.00701 seconds
Memory Before: 531.555 KB
Memory After: 2,895.891 KB
Memory Used: 2,364.336 KB
Session Handling
SQL Query
SELECT *
FROM session
WHERE userid = 0
	AND host = '52.14.239.155'
	AND idhash = 'e2419086c253fbd2bb6e662e41ca132f'
LIMIT 1
1SIMPLEsession refguest_lookup,user_activityguest_lookup51const,const,const2100.00
Time Before: 0.00937 seconds
Time After: 0.00956 seconds
Time Taken: 0.00020 seconds
Memory Before: 3,395.109 KB
Memory After: 3,395.742 KB
Memory Used: 0.633 KB
SQL Query
SELECT languageid,
			phrasegroup_global AS phrasegroup_global,
			phrasegroup_showthread AS phrasegroup_showthread,
			phrasegroup_postbit AS phrasegroup_postbit,
			phrasegroupinfo AS lang_phrasegroupinfo,
			options AS lang_options,
			languagecode AS lang_code,
			charset AS lang_charset,
			locale AS lang_locale,
			imagesoverride AS lang_imagesoverride,
			dateoverride AS lang_dateoverride,
			timeoverride AS lang_timeoverride,
			registereddateoverride AS lang_registereddateoverride,
			calformat1override AS lang_calformat1override,
			calformat2override AS lang_calformat2override,
			logdateoverride AS lang_logdateoverride,
			decimalsep AS lang_decimalsep,
			thousandsep AS lang_thousandsep
FROM language
WHERE languageid = 1
1SIMPLElanguage systemPRIMARY   1100.00
Time Before: 0.01009 seconds
Time After: 0.01038 seconds
Time Taken: 0.00028 seconds
Memory Before: 3,407.633 KB
Memory After: 3,407.656 KB
Memory Used: 0.023 KB
Time Before: 0.00893 seconds
Time After: 0.01045 seconds
Time Taken: 0.00152 seconds
Memory Before: 3,387.430 KB
Memory After: 3,460.547 KB
Memory Used: 73.117 KB
SQL Query
SELECT IF(thread.visible = 2, 1, 0) AS isdeleted,
post.pagetext AS description,
thread.*
FROM thread AS thread
LEFT JOIN post AS post ON(post.postid = thread.firstpostid)
WHERE thread.threadid = 97684 LIMIT 1
1SIMPLEthread constPRIMARYPRIMARY4const1100.00
1SIMPLEpost constPRIMARYPRIMARY4const1100.00
Time Before: 0.01193 seconds
Time After: 0.01214 seconds
Time Taken: 0.00022 seconds
Memory Before: 3,783.156 KB
Memory After: 3,783.836 KB
Memory Used: 0.680 KB
SQL Query
SELECT MAX(permissions & 1) AS perm
FROM cms_permissions
WHERE nodeid = 1 AND usergroupid IN (1)
1SIMPLEcms_permissions constusergroupid,nodeidusergroupid8const,const1100.00
Time Before: 0.01257 seconds
Time After: 0.01271 seconds
Time Taken: 0.00015 seconds
Memory Before: 3,817.438 KB
Memory After: 3,817.969 KB
SQL Query
SELECT *
FROM style
WHERE (styleid = 20 AND userselect = 1)
	OR styleid = 20
ORDER BY styleid ASC
LIMIT 1
1SIMPLEstyle constPRIMARYPRIMARY2const1100.00
Time Before: 0.01952 seconds
Time After: 0.01983 seconds
Time Taken: 0.00031 seconds
Memory Before: 3,821.531 KB
Memory After: 3,822.156 KB
Memory Used: 0.625 KB
End call of global.php: 0.030974864959717
SQL Query
SELECT COUNT(*) AS total
FROM post AS post
WHERE threadid=97684 AND visible=1
1SIMPLEpost refthreadid,threadid_visible_datelinethreadid_visible_dateline6const,const10100.00Using index
Time Before: 0.03152 seconds
Time After: 0.03167 seconds
Time Taken: 0.00016 seconds
Memory Before: 4,645.430 KB
Memory After: 4,645.977 KB
Memory Used: 0.547 KB
SQL Query
SELECT post.*,post.username AS postusername,user.username
FROM post AS post
LEFT JOIN user AS user ON(user.userid = post.userid)
WHERE post.threadid=97684 AND post.visible=1
ORDER BY dateline
LIMIT 0, 40
1SIMPLEpost rangethreadid,threadid_visible_datelinethreadid_visible_dateline6 10100.00Using index condition
1SIMPLEuser eq_refPRIMARYPRIMARY4xapexspeed.post.userid1100.00
Time Before: 0.03215 seconds
Time After: 0.03273 seconds
Time Taken: 0.00058 seconds
Memory Before: 4,678.578 KB
Memory After: 4,679.688 KB
Memory Used: 1.109 KB
SQL Query
SELECT title, template
FROM template
WHERE templateid IN (6592,5972,5973,5656,5658,5660,5662,6608,6606,6609,6211,4538,4537,4539,4534,4533,5615,5616,7020,6840,4542,4543,5620,5926,6200,6585,6586,5873,5874,5875,6230,0,0,6210,6171,5896,5897,5899,5900,6123,6242,6224,6174,6175,5723,5722,5726,6667,6625,6635,6633,6632)
1SIMPLEtemplate rangePRIMARYPRIMARY4 51100.00Using index condition
Time Before: 0.03585 seconds
Time After: 0.03645 seconds
Time Taken: 0.00061 seconds
Memory Before: 4,932.875 KB
Memory After: 4,934.336 KB
Memory Used: 1.461 KB
SQL Query
UPDATE session
SET lastactivity = 1718594481, location = '/printthread.php?explain=1&page=1&pp=40&t=97684', inforum = 201, inthread = 97684, badlocation = 0, useragent = 'Mozilla/5.0 AppleWebKit/537.36 (KHTML, like Gecko; compatible; ClaudeBot/1.0; +claudebot@anthropic.com)'
WHERE sessionhash = '85e443d789d68384c375b7b68c359090'
Time Before: 0.04069 seconds
Time After: 0.04583 seconds
Time Taken: 0.00514 seconds
Memory Before: 5,116.344 KB
Memory After: 5,116.391 KB
Memory Used: 0.047 KB
Page generated in 0.040272951126099 seconds with 11 queries, spending 0.011784076690674 doing MySQL queries and 0.028488874435425 doing PHP things.
Shutdown Queries:
DISABLED
