Time Before: 0.00043 seconds
Time After: 0.00059 seconds
Time Taken: 0.00016 seconds
Memory Before: 505.578 KB
Memory After: 530.289 KB
Memory Used: 24.711 KB
Time Before: 0.00062 seconds
Time After: 0.00108 seconds
Time Taken: 0.00046 seconds
Memory Before: 530.227 KB
Memory After: 531.219 KB
Memory Used: 0.992 KB
SET @@sql_mode = ''
Time Before: 0.00122 seconds
Time After: 0.00133 seconds
Time Taken: 0.00011 seconds
Memory Before: 531.773 KB
Memory After: 532.305 KB
Memory Used: 0.531 KB
SELECT * FROM datastore WHERE title IN ('smiliecache','bbcodecache','navdata','options','bitfields','attachmentcache','forumcache','usergroupcache','stylecache','languagecache','products','pluginlist','cron','profilefield','loadcache','noticecache','activitystream','routes')
id | select_type | table | partitions | type | possible_keys | key | key_len | ref | rows | filtered | Extra |
1 | SIMPLE | datastore | range | PRIMARY | PRIMARY | 52 | 18 | 100.00 | Using index condition |
Time Before: 0.00174 seconds
Time After: 0.00322 seconds
Time Taken: 0.00148 seconds
Memory Before: 535.328 KB
Memory After: 536.211 KB
Memory Used: 0.883 KB
Time Before: 0.00135 seconds
Time After: 0.00512 seconds
Time Taken: 0.00376 seconds
Memory Before: 531.555 KB
Memory After: 2,895.891 KB
Memory Used: 2,364.336 KB
SELECT * FROM session WHERE userid = 0 AND host = '18.218.182.50' AND idhash = '8bd6ac7ee06d67ac75a84784fa175004' LIMIT 1
1 | SIMPLE | session | ref | guest_lookup,user_activity | guest_lookup | 51 | const,const,const | 2 | 100.00 |
Time Before: 0.00582 seconds
Time After: 0.00598 seconds
Memory Before: 3,395.109 KB
Memory After: 3,395.742 KB
Memory Used: 0.633 KB
SELECT languageid, phrasegroup_global AS phrasegroup_global, phrasegroup_showthread AS phrasegroup_showthread, phrasegroup_postbit AS phrasegroup_postbit, phrasegroupinfo AS lang_phrasegroupinfo, options AS lang_options, languagecode AS lang_code, charset AS lang_charset, locale AS lang_locale, imagesoverride AS lang_imagesoverride, dateoverride AS lang_dateoverride, timeoverride AS lang_timeoverride, registereddateoverride AS lang_registereddateoverride, calformat1override AS lang_calformat1override, calformat2override AS lang_calformat2override, logdateoverride AS lang_logdateoverride, decimalsep AS lang_decimalsep, thousandsep AS lang_thousandsep FROM language WHERE languageid = 1
1 | SIMPLE | language | system | PRIMARY | 1 | 100.00 |
Time Before: 0.00641 seconds
Time After: 0.00669 seconds
Time Taken: 0.00028 seconds
Memory Before: 3,407.633 KB
Memory After: 3,407.656 KB
Memory Used: 0.023 KB
Time Before: 0.00547 seconds
Time After: 0.00676 seconds
Time Taken: 0.00130 seconds
Memory Before: 3,387.430 KB
Memory After: 3,460.547 KB
Memory Used: 73.117 KB
SELECT IF(thread.visible = 2, 1, 0) AS isdeleted, post.pagetext AS description, thread.* FROM thread AS thread LEFT JOIN post AS post ON(post.postid = thread.firstpostid) WHERE thread.threadid = 97656 LIMIT 1
1 | SIMPLE | thread | const | PRIMARY | PRIMARY | 4 | const | 1 | 100.00 | ||
1 | SIMPLE | post | const | PRIMARY | PRIMARY | 4 | const | 1 | 100.00 |
Time Before: 0.00795 seconds
Time After: 0.00813 seconds
Time Taken: 0.00018 seconds
Memory Before: 3,783.156 KB
Memory After: 3,783.836 KB
Memory Used: 0.680 KB
SELECT MAX(permissions & 1) AS perm FROM cms_permissions WHERE nodeid = 1 AND usergroupid IN (1)
1 | SIMPLE | cms_permissions | const | usergroupid,nodeid | usergroupid | 8 | const,const | 1 | 100.00 |
Time Before: 0.00848 seconds
Time After: 0.00862 seconds
Time Taken: 0.00013 seconds
Memory Before: 3,817.570 KB
Memory After: 3,818.102 KB
SELECT * FROM style WHERE (styleid = 20 AND userselect = 1) OR styleid = 20 ORDER BY styleid ASC LIMIT 1
1 | SIMPLE | style | const | PRIMARY | PRIMARY | 2 | const | 1 | 100.00 |
Time Before: 0.01246 seconds
Time After: 0.01269 seconds
Time Taken: 0.00023 seconds
Memory Before: 3,821.641 KB
Memory After: 3,822.266 KB
Memory Used: 0.625 KB
SELECT COUNT(*) AS total FROM post AS post WHERE threadid=97656 AND visible=1
1 | SIMPLE | post | ref | threadid,threadid_visible_dateline | threadid_visible_dateline | 6 | const,const | 62 | 100.00 | Using index |
Time Before: 0.01363 seconds
Time After: 0.01379 seconds
Memory Before: 4,645.516 KB
Memory After: 4,646.063 KB
Memory Used: 0.547 KB
SELECT post.*,post.username AS postusername,user.username FROM post AS post LEFT JOIN user AS user ON(user.userid = post.userid) WHERE post.threadid=97656 AND post.visible=1 ORDER BY dateline LIMIT 0, 40
1 | SIMPLE | post | range | threadid,threadid_visible_dateline | threadid_visible_dateline | 6 | 62 | 100.00 | Using index condition | ||
1 | SIMPLE | user | eq_ref | PRIMARY | PRIMARY | 4 | xapexspeed.post.userid | 1 | 100.00 |
Time Before: 0.01416 seconds
Time After: 0.01452 seconds
Time Taken: 0.00036 seconds
Memory Before: 4,678.664 KB
Memory After: 4,682.820 KB
Memory Used: 4.156 KB
SELECT title, template FROM template WHERE templateid IN (6592,5972,5973,5656,5658,5660,5662,6608,6606,6609,6211,4538,4537,4539,4534,4533,5615,5616,7020,6840,4542,4543,5620,5926,6200,6585,6586,5873,5874,5875,6230,0,0,6210,6171,5896,5897,5899,5900,6123,6242,6224,6174,6175,5723,5722,5726,6667,6625,6635,6633,6632)
1 | SIMPLE | template | range | PRIMARY | PRIMARY | 4 | 51 | 100.00 | Using index condition |
Time Before: 0.01552 seconds
Time After: 0.01599 seconds
Time Taken: 0.00047 seconds
Memory Before: 4,936.273 KB
Memory After: 4,937.734 KB
Memory Used: 1.461 KB
UPDATE session SET lastactivity = 1718620376, location = '/printthread.php?explain=1&page=1&pp=40&t=97656', inforum = 144, inthread = 97656, badlocation = 0, useragent = 'Mozilla/5.0 AppleWebKit/537.36 (KHTML, like Gecko; compatible; ClaudeBot/1.0; +claudebot@anthropic.com)' WHERE sessionhash = '46ec6653e9babe558984b0072ad2157b'
Time Before: 0.02384 seconds
Time After: 0.02655 seconds
Time Taken: 0.00270 seconds
Memory Before: 5,241.258 KB
Memory After: 5,241.305 KB
Memory Used: 0.047 KB
