Including Functions.php
Time Before: 0.00035 seconds
Time After: 0.00049 seconds
Time Taken: 0.00014 seconds
Memory Before: 506.078 KB
Memory After: 530.789 KB
Memory Used: 24.711 KB
Connect to Database on Server: 127.0.0.1
Time Before: 0.00052 seconds
Time After: 0.00087 seconds
Time Taken: 0.00036 seconds
Memory Before: 530.727 KB
Memory After: 531.719 KB
Memory Used: 0.992 KB
SQL Query
SET @@sql_mode = ''
Time Before: 0.00100 seconds
Time After: 0.00108 seconds
Time Taken: 0.00008 seconds
Memory Before: 532.273 KB
Memory After: 532.805 KB
Memory Used: 0.531 KB
Datastore Setup
SQL Query
SELECT *
FROM datastore
WHERE title IN ('smiliecache','bbcodecache','navdata','options','bitfields','attachmentcache','forumcache','usergroupcache','stylecache','languagecache','products','pluginlist','cron','profilefield','loadcache','noticecache','activitystream','routes')
idselect_typetablepartitionstypepossible_keyskeykey_lenrefrowsfilteredExtra
1SIMPLEdatastore rangePRIMARYPRIMARY52 18100.00Using index condition
Time Before: 0.00157 seconds
Time After: 0.00309 seconds
Time Taken: 0.00152 seconds
Memory Before: 535.828 KB
Memory After: 536.711 KB
Memory Used: 0.883 KB
Time Before: 0.00110 seconds
Time After: 0.00547 seconds
Time Taken: 0.00437 seconds
Memory Before: 532.055 KB
Memory After: 2,896.438 KB
Memory Used: 2,364.383 KB
Session Handling
SQL Query
SELECT *
FROM session
WHERE userid = 0
	AND host = '18.221.194.44'
	AND idhash = 'f0930925b4ba3c382887ad5c0f02784f'
LIMIT 1
1SIMPLEsession refguest_lookup,user_activityguest_lookup51const,const,const2100.00
Time Before: 0.00667 seconds
Time After: 0.00684 seconds
Time Taken: 0.00018 seconds
Memory Before: 3,395.750 KB
Memory After: 3,396.383 KB
Memory Used: 0.633 KB
SQL Query
SELECT languageid,
			phrasegroup_global AS phrasegroup_global,
			phrasegroup_showthread AS phrasegroup_showthread,
			phrasegroup_postbit AS phrasegroup_postbit,
			phrasegroupinfo AS lang_phrasegroupinfo,
			options AS lang_options,
			languagecode AS lang_code,
			charset AS lang_charset,
			locale AS lang_locale,
			imagesoverride AS lang_imagesoverride,
			dateoverride AS lang_dateoverride,
			timeoverride AS lang_timeoverride,
			registereddateoverride AS lang_registereddateoverride,
			calformat1override AS lang_calformat1override,
			calformat2override AS lang_calformat2override,
			logdateoverride AS lang_logdateoverride,
			decimalsep AS lang_decimalsep,
			thousandsep AS lang_thousandsep
FROM language
WHERE languageid = 1
1SIMPLElanguage systemPRIMARY   1100.00
Time Before: 0.00725 seconds
Time After: 0.00750 seconds
Time Taken: 0.00024 seconds
Memory Before: 3,408.273 KB
Memory After: 3,408.297 KB
Memory Used: 0.023 KB
Time Before: 0.00587 seconds
Time After: 0.00756 seconds
Time Taken: 0.00169 seconds
Memory Before: 3,388.070 KB
Memory After: 3,461.188 KB
Memory Used: 73.117 KB
SQL Query
SELECT IF(thread.visible = 2, 1, 0) AS isdeleted,
post.pagetext AS description,
thread.*
FROM thread AS thread
LEFT JOIN post AS post ON(post.postid = thread.firstpostid)
WHERE thread.threadid = 97560 LIMIT 1
1SIMPLEthread constPRIMARYPRIMARY4const1100.00
1SIMPLEpost constPRIMARYPRIMARY4const1100.00
Time Before: 0.00861 seconds
Time After: 0.00878 seconds
Time Taken: 0.00017 seconds
Memory Before: 3,783.797 KB
Memory After: 3,784.477 KB
Memory Used: 0.680 KB
SQL Query
SELECT MAX(permissions & 1) AS perm
FROM cms_permissions
WHERE nodeid = 1 AND usergroupid IN (1)
1SIMPLEcms_permissions constusergroupid,nodeidusergroupid8const,const1100.00
Time Before: 0.00912 seconds
Time After: 0.00925 seconds
Time Taken: 0.00013 seconds
Memory Before: 3,817.922 KB
Memory After: 3,818.453 KB
SQL Query
SELECT *
FROM style
WHERE (styleid = 20 AND userselect = 1)
	OR styleid = 20
ORDER BY styleid ASC
LIMIT 1
1SIMPLEstyle constPRIMARYPRIMARY2const1100.00
Time Before: 0.01298 seconds
Time After: 0.01319 seconds
Time Taken: 0.00021 seconds
Memory Before: 3,822.016 KB
Memory After: 3,822.641 KB
Memory Used: 0.625 KB
End call of global.php: 0.013657808303833
SQL Query
SELECT COUNT(*) AS total
FROM post AS post
WHERE threadid=97560 AND visible=1
1SIMPLEpost refthreadid,threadid_visible_datelinethreadid_visible_dateline6const,const19100.00Using index
Time Before: 0.01409 seconds
Time After: 0.01424 seconds
Time Taken: 0.00015 seconds
Memory Before: 4,645.859 KB
Memory After: 4,646.406 KB
Memory Used: 0.547 KB
SQL Query
SELECT post.*,post.username AS postusername,user.username
FROM post AS post
LEFT JOIN user AS user ON(user.userid = post.userid)
WHERE post.threadid=97560 AND post.visible=1
ORDER BY dateline
LIMIT 0, 40
1SIMPLEpost rangethreadid,threadid_visible_datelinethreadid_visible_dateline6 19100.00Using index condition
1SIMPLEuser eq_refPRIMARYPRIMARY4xapexspeed.post.userid1100.00
Time Before: 0.01460 seconds
Time After: 0.01484 seconds
Memory Before: 4,679.008 KB
Memory After: 4,680.477 KB
Memory Used: 1.469 KB
SQL Query
SELECT title, template
FROM template
WHERE templateid IN (6592,5972,5973,5656,5658,5660,5662,6608,6606,6609,6211,4538,4537,4539,4534,4533,5615,5616,7020,6840,4542,4543,5620,5926,6200,6585,6586,5873,5874,5875,6230,0,0,6210,6171,5896,5897,5899,5900,6123,6242,6224,6174,6175,5723,5722,5726,6667,6625,6635,6633,6632)
1SIMPLEtemplate rangePRIMARYPRIMARY4 51100.00Using index condition
Time Before: 0.01598 seconds
Time After: 0.01643 seconds
Time Taken: 0.00045 seconds
Memory Before: 4,952.945 KB
Memory After: 4,954.406 KB
Memory Used: 1.461 KB
SQL Query
UPDATE session
SET lastactivity = 1718590284, location = '/printthread.php?explain=1&page=1&pp=40&t=97560', inforum = 123, inthread = 97560, badlocation = 0, useragent = 'Mozilla/5.0 AppleWebKit/537.36 (KHTML, like Gecko; compatible; ClaudeBot/1.0; +claudebot@anthropic.com)'
WHERE sessionhash = 'c6af8e372e63c00d67aeb41a632ea6d7'
Time Before: 0.01933 seconds
Time After: 0.02195 seconds
Time Taken: 0.00262 seconds
Memory Before: 5,141.055 KB
Memory After: 5,141.102 KB
Memory Used: 0.047 KB
Page generated in 0.019080877304077 seconds with 11 queries, spending 0.006354808807373 doing MySQL queries and 0.012726068496704 doing PHP things.
Shutdown Queries:
DISABLED
