Time Before: 0.00039 seconds
Time After: 0.00055 seconds
Time Taken: 0.00015 seconds
Memory Before: 506.078 KB
Memory After: 530.789 KB
Memory Used: 24.711 KB
Time Before: 0.00057 seconds
Time After: 0.00100 seconds
Time Taken: 0.00043 seconds
Memory Before: 530.727 KB
Memory After: 531.719 KB
Memory Used: 0.992 KB
SET @@sql_mode = ''
Time Before: 0.00116 seconds
Time After: 0.00126 seconds
Time Taken: 0.00011 seconds
Memory Before: 532.273 KB
Memory After: 532.805 KB
Memory Used: 0.531 KB
SELECT * FROM datastore WHERE title IN ('smiliecache','bbcodecache','navdata','options','bitfields','attachmentcache','forumcache','usergroupcache','stylecache','languagecache','products','pluginlist','cron','profilefield','loadcache','noticecache','activitystream','routes')
id | select_type | table | partitions | type | possible_keys | key | key_len | ref | rows | filtered | Extra |
1 | SIMPLE | datastore | range | PRIMARY | PRIMARY | 52 | 18 | 100.00 | Using index condition |
Time Before: 0.00166 seconds
Time After: 0.00315 seconds
Time Taken: 0.00149 seconds
Memory Before: 535.828 KB
Memory After: 536.711 KB
Memory Used: 0.883 KB
Time Before: 0.00129 seconds
Time After: 0.00482 seconds
Time Taken: 0.00353 seconds
Memory Before: 532.055 KB
Memory After: 2,896.438 KB
Memory Used: 2,364.383 KB
SELECT * FROM session WHERE userid = 0 AND host = '3.128.206.48' AND idhash = '546b31cd8f5fa555bfac0bc5f94e7d9e' LIMIT 1
1 | SIMPLE | session | ref | guest_lookup,user_activity | guest_lookup | 51 | const,const,const | 2 | 100.00 |
Time Before: 0.00550 seconds
Time After: 0.00566 seconds
Time Taken: 0.00016 seconds
Memory Before: 3,395.734 KB
Memory After: 3,396.195 KB
Memory Used: 0.461 KB
SELECT languageid, phrasegroup_global AS phrasegroup_global, phrasegroup_showthread AS phrasegroup_showthread, phrasegroup_postbit AS phrasegroup_postbit, phrasegroupinfo AS lang_phrasegroupinfo, options AS lang_options, languagecode AS lang_code, charset AS lang_charset, locale AS lang_locale, imagesoverride AS lang_imagesoverride, dateoverride AS lang_dateoverride, timeoverride AS lang_timeoverride, registereddateoverride AS lang_registereddateoverride, calformat1override AS lang_calformat1override, calformat2override AS lang_calformat2override, logdateoverride AS lang_logdateoverride, decimalsep AS lang_decimalsep, thousandsep AS lang_thousandsep FROM language WHERE languageid = 1
1 | SIMPLE | language | system | PRIMARY | 1 | 100.00 |
Time Before: 0.00611 seconds
Time After: 0.00637 seconds
Time Taken: 0.00026 seconds
Memory Before: 3,409.273 KB
Memory After: 3,409.297 KB
Memory Used: 0.023 KB
Time Before: 0.00516 seconds
Time After: 0.00643 seconds
Time Taken: 0.00128 seconds
Memory Before: 3,388.070 KB
Memory After: 3,461.844 KB
Memory Used: 73.773 KB
SELECT IF(thread.visible = 2, 1, 0) AS isdeleted, post.pagetext AS description, thread.* FROM thread AS thread LEFT JOIN post AS post ON(post.postid = thread.firstpostid) WHERE thread.threadid = 97366 LIMIT 1
1 | SIMPLE | thread | const | PRIMARY | PRIMARY | 4 | const | 1 | 100.00 | ||
1 | SIMPLE | post | const | PRIMARY | PRIMARY | 4 | const | 1 | 100.00 |
Time Before: 0.00754 seconds
Time After: 0.00772 seconds
Time Taken: 0.00018 seconds
Memory Before: 3,784.422 KB
Memory After: 3,785.086 KB
Memory Used: 0.664 KB
SELECT MAX(permissions & 1) AS perm FROM cms_permissions WHERE nodeid = 1 AND usergroupid IN (1)
1 | SIMPLE | cms_permissions | const | usergroupid,nodeid | usergroupid | 8 | const,const | 1 | 100.00 |
Time Before: 0.00804 seconds
Time After: 0.00818 seconds
Time Taken: 0.00013 seconds
Memory Before: 3,817.906 KB
Memory After: 3,818.422 KB
Memory Used: 0.516 KB
SELECT * FROM style WHERE (styleid = 20 AND userselect = 1) OR styleid = 20 ORDER BY styleid ASC LIMIT 1
1 | SIMPLE | style | const | PRIMARY | PRIMARY | 2 | const | 1 | 100.00 |
Time Before: 0.01194 seconds
Time After: 0.01217 seconds
Time Taken: 0.00023 seconds
Memory Before: 3,821.977 KB
Memory After: 3,822.586 KB
Memory Used: 0.609 KB
SELECT COUNT(*) AS total FROM post AS post WHERE threadid=97366 AND visible=1
1 | SIMPLE | post | ref | threadid,threadid_visible_dateline | threadid_visible_dateline | 6 | const,const | 15 | 100.00 | Using index |
Time Before: 0.01310 seconds
Time After: 0.01326 seconds
Memory Before: 4,645.734 KB
Memory After: 4,646.281 KB
Memory Used: 0.547 KB
SELECT post.*,post.username AS postusername,user.username FROM post AS post LEFT JOIN user AS user ON(user.userid = post.userid) WHERE post.threadid=97366 AND post.visible=1 ORDER BY dateline LIMIT 0, 40
1 | SIMPLE | post | range | threadid,threadid_visible_dateline | threadid_visible_dateline | 6 | 15 | 100.00 | Using index condition | ||
1 | SIMPLE | user | eq_ref | PRIMARY | PRIMARY | 4 | xapexspeed.post.userid | 1 | 100.00 |
Time Before: 0.01364 seconds
Time After: 0.01389 seconds
Time Taken: 0.00025 seconds
Memory Before: 4,678.883 KB
Memory After: 4,680.164 KB
Memory Used: 1.281 KB
SELECT title, template FROM template WHERE templateid IN (6592,5972,5973,5656,5658,5660,5662,6608,6606,6609,6211,4538,4537,4539,4534,4533,5615,5616,7020,6840,4542,4543,5620,5926,6200,6585,6586,5873,5874,5875,6230,0,0,6210,6171,5896,5897,5899,5900,6123,6242,6224,6174,6175,5723,5722,5726,6667,6625,6635,6633,6632)
1 | SIMPLE | template | range | PRIMARY | PRIMARY | 4 | 51 | 100.00 | Using index condition |
Time Before: 0.01565 seconds
Time After: 0.01611 seconds
Time Taken: 0.00046 seconds
Memory Before: 4,958.461 KB
Memory After: 4,959.922 KB
Memory Used: 1.461 KB
INSERT IGNORE INTO session (sessionhash, userid, host, idhash, lastactivity, location, styleid, languageid, loggedin, inforum, inthread, incalendar, badlocation, useragent, bypass, profileupdate, apiclientid, apiaccesstoken) VALUES ('c0ea05e5e77cb79f5d1da9ba87f1639d', 0, '3.128.206.48', '546b31cd8f5fa555bfac0bc5f94e7d9e', 1718600337, '/printthread.php?explain=1&page=1&pp=40&t=97366', 0, 0, 0, 219, 97366, 0, 0, 'Mozilla/5.0 AppleWebKit/537.36 (KHTML, like Gecko; compatible; ClaudeBot/1.0; +claudebot@anthropic.com)', 0, 0, 0, '')
Time Before: 0.01939 seconds
Time After: 0.02233 seconds
Time Taken: 0.00294 seconds
Memory Before: 5,205.789 KB
Memory After: 5,205.641 KB
Memory Used: -0.148 KB
