Originally Posted by
DaveW
As I've said before, we have been suffering from a lack of grip in all corners, especially the slow ones. So based on some advice, I set the front swaybar full soft at Mid Ohio, and that seemed to help a bit so the car was slightly faster both in Q2 and R2.
Bottom line is I think we're finally on the right track with decreasing the overall roll stiffness[?] way more than I ever thought would be necessary. I have known that too much roll stiffness from any cause (friction, too high roll centers, too much damping, etc.) will degrade grip, but I had not realized how much reduction in roll stiffness was necessary for the Hoosier spec FC bias tires.
I'm looking forward to Summit Point which is a low grip track, and if we go well there, it will be confirmation of this approach (vastly lower roll stiffness) [front only or rear also?].
If the latest front swaybar setup in its softest setting is not soft enough, the next step will be to disconnect the front bar completely.
