Originally Posted by
Hardingfv32
How do you measure longevity, over 40,80,etc, heat cycles? What performance measure are you using during this test? Say, lapping at 90% until you cannot do the 90% lap? Are the Yok's going to do the same test to make a valid comparison?
Grip: Track time using the same driver, car, track, and day? What level of heat cycles are the tires at for this test?
Who is going to set the above criteria and run the tests?
I can see why the CRB might not consider grip and longevity when deciding on a new spec tire.
