Page 2 of 2 FirstFirst 12
Results 41 to 42 of 42
  1. #41
    ohio
    Back at this again. Got some fresh parts.
    The pegasus mechanical pump runs about 1psi lower overall.
    I changed to the DaveW jets. However the car would stall when coming off full throttle.
    DaveW’s jets in 2006 were:
    JET PRI SEC
    AIR 200 140
    FUEL 135 165
    (FOR AVGAS, ~55F)
    So I changed the idle jets from 55 Primary and 50 secondary to 65 Primary and 60 Secondary solved this issue.
    Does anyone know what idle jets DaveW ran with those Air/Fuel jets?
    Also, I added a wire to the distributor base to solve the ground issue. That didn't improve the timing stability. Just wanting for the parts to show up from PerTronix.
  2. #42
    Liked: 3887
    Default Idle jets
    That was a long time ago - all I know is that they were what was in the carburetor when i got it from QS or Stimola. I did have to clean dirt out of them a few times - when they were blocked it wouldn't idle.
There are currently 3 users browsing this thread. (1 members and 2 guests)
  1. WayneM
