Gents:
From an Apex post:
Thoughts on venting the reservoir. And if advisable, best location recommendations, please.
Gents:
From an Apex post:
I always vent all fluid reservoirs to catch cans and not just to atmosphere or ground. Cleaner and safer.
I just discovered mine was blocked and capped off from previous owners. Currently just have a hose going into a water bottle mounted at the wing. Im debating on hooking this cavity back up or just upgrading to a little more official external catch can.
I have also been told that the internal cavity catch sometimes starts to not be very reliable. Which one do you guys recommend?
the can still needs to be vented, either with a loose hose entry or a dedicated hose off the top and over the side. Otherwise you are going to build pressure in the system.
I have had many late model VD - all using the factory catch tank with no issues at all. Yours is already vented with small filter. I believe all of the ones I have seen also are vented through the four small holes in the top of the casing above the tank - YMMV
We run a separate catch bottle per GCR for the water but not the oil - we drain the overflow tank after every event and if it doesn't have anything in it we raise our oil level. Typically we run 2-2.5 inches above the input shaft tube.
If you have leakage problem it is likely not a design issue.
JM
RaceDog
Messenger Racing
Muleshoe, Texas USA
94/95 VD here. The stand up tube on top of the bellhousing that is used for adding oil, or checking oil level via a dip stick when the engine is running, has a tap about half-way up its side for a tube that leads down to a catch can. I guess it could be called a vent. The same catch can has a place in its top for a tiny tube's entry that leads from the tranny
There are currently 10 users browsing this thread. (0 members and 10 guests)
