For sale is my 2000 Van Diemen, ford engine. Raced in the Ontario Toyo Tires F1600 series in 2021/22/23. Reliable, race-ready car comes with long list of spares, specialty tools, and equipment. Located near Ottawa, ON.
Price: $25,500 USD (will happily deal in CAD funds for Canadian buyers)
Engine Rebuild - 2024:
- full engine rebuild & dyno by Britain West Motorsports
- new aluminum head, valves
- new cam bearings
- new piston rings
- new clutch
- resealed oil pump
- new distributor
- 0 hrs on engine since dyno & break-in by BW
Car Details:
- CASC-OR Annual Tech Inspection 2023, has vehicle logbooks
- RF00K ChassisLD19 brakes all 4 corners, rebuilt calipers (2022)
- Master cylinders resealed (2022)
- New front brake fluid reservoir (2023)
- Custom drilled rotors (BW)
- In-car adjustable brake bias
- New clutch (2024)
- Re-sealed bellhousing input shaft tunnel to gearbox (2023)
- New fuel pump (2023)
- New radiator (2024)
- Penske 3-way adjustable shocks, rebuilt (2018)
- In-car adjustable front ARB
- Rear adjustable ARB
- AIM Evo4 with Formula Wheel V2 (refreshed by AIM in 2024 and factory tested)
- Steering quick release
- Varley red top 30 battery (2020)
- Custom foam seat (1-piece) with fire retardant cloth upholstery
- Panosport wheels with Toyo R888 tires (50% life) - 2 sets + spare rim
Tools & Equipment Included with Car:
- String alignment bars/camber shims
- Low car stands
- High car stands
- Formula quick jack
- Engine stand
- Battery cart with cables
- Gearset removal tool
- Dzeus hand tool
- Clutch alignment tool
- Cylinder head socket
- How to build and maintain formula ford 1600 engines book
Spare Parts:
- Engine cowling bodywork
- Right side pod floor bodywork
- Spare set of wheels with tires (matching car, 50% life)
- Wheel spacers
- Extra spare rim (no tire)
- Starter
- Distributor and ignition wires
- Ignition coil
- Gearsets (see below for ratios)
- Front ARB pushrod
- Front pushrod
- Rear right upper A-arm
- Front left lower A-arm
- Throttle cables
- Rear upright and 2x hubs with bearings
- Front steering clevice
- Set of used brake pads
- Set of Weber jets and spare carb parts
- Spare springs (250/300/350/400/450/500/550/650)
- Suspension hardware (AN)
- Various rod ends, hardware, seals, o-rings, etc
- Some other misc components
Expiries (not valid after year shown, good for that year):
- Shoulder belts: 2026
- Crotch belts: 2027
- Lap belts: 2024
- Fire bottle: ?? Worn off date stamp
Gearsets:
1st
- 16/34
- 15/30 (in car)
2nd/3rd/4th
- 17/29
- 20/32 (in car)
- 18/28
- 19/27
- 21/29
- 19/25 (in car)
- 21/24
- 24/26 (in car)
