    Elkhorn, Wisconsin
    Default $14 a gallon for 93 octane?
    Liked: 558
    Quote Originally Posted by Hanssen26 View Post
    What's so special about the Sunoco 93 octane that that the series requires to run in the JS F4 cars? Wondering why it's $14 per gallon, when I can go to the pump and get 93 octane for $4 gallon.
    Is Sunoco one of the series sponsors?
    (Maybe all "professional" series should require entrants and drivers complete a course in the economics of racing.)
    Peter Olivola
    (polivola@gmail.com)
  3. The following 4 users liked this post:
    Hartford, WI
    Liked: 231
    Default Spec Fuel = Easy to Tech
    Tim, two reasons they want a spec fuel: 1) to balance the Honda engine performance playing field so that everyone is getting "equal" power from the fuel, and 2) because it makes it much easier to test each racer's fuel for cheating.
    The tech people know the chemical "fingerprint" properties of the Sunoco fuel (dielectric constant, density, RVP, reagent reactions, etc), making it easier to confirm if a competitor has illegally added any performance improvers.
    Side note: Illinois and Wisconsin pump gas at 93 octane contains approximately 10% ethanol. My guess is the Sunoco 93 has no ethanol.
    Liked: 1072
    10% ethanol will make about 4-6 hp less than 100% gasoline. There are fewer simply fewer BTUs in ethanol than gasoline.
    Savannah, GA (via Montreal)
    Liked: 1003
    a cynic (not me LOL) might suggest that a dying ‘pro series’ with only 8 entries is finding ways to generate cash flow… ?
    ymmv
  10. #6
    Deep River, Ontario, Canada
    Liked: 154
    Default Bar codes
    ymmv
    Remember the bar code bs on parts in Formula Renault? Canada.
    Repaired sidepod, nose, difuser etc. DQ. No f/glass repair allowed.
    You had to buy new series parts.
    Series and clowns that organised it. Gone in 2 years
  11. #7
    Cumming, GA
    Liked: 234
    Track prices for Sunoco 93 are higher than regular retail, although the usual markup is usually only about $3 to $5 per gallon which in some cases is actually well worth it if you don't want to go tooling around town with 30 gallons of gasoline in your trunk. So on the face of it it does seem a bit excessive.
    But that's how modern "pro" racing "sponsorships" work, especially when said "pro" series can't skim $1 million. For instance, in F1600 we pay a bit of a premium for our spec tires, even though they're identical to the club-racing tires that are on average $150 a set less from non-series tire dealers. But, we get good service each weekend, they make sure to stock more than enough tires, and they give away up to a dozen a weekend as part of the prize package.
    Sam Lockwood
    Raceworks, Inc
    www.lockraceworks.com
