I have been having some trouble with my long rod pinto engine and im hoping to get some advice in what general direction to go here. I am told this is 3 race long rod engine.
I first noticed on track during a test day. About halfway through the day I started to notice a few puffs of white smoke in my mirror when blipping the the throttle going to first gear. Then I started having trouble blipping throttle and getting it to REV and it started running pretty rough. We came in and noticed black soot on the exhaust pipe and puff of black smoke while hitting throttle. But not white smoke. Then winter came I looked in the CARB and there was black debris in it so I sent the carb of for rebuild and cleaning, just knowing that was the issue. Put the new Carb on have same issues. Sometimes I have white smoke on revs going up but not down and always black smoke while revving. I have also added a fuel filter and have checked that and the carb and there is no more debris.
I took the carb apart and float is set a little high ( the beach is just fully covered) so I intended to get that right but
I decided to do compression and leak down test and got distracted. Compression was done warm and wide open throttle.
1 - 140 4% leak down
2 - 134 6% leak down
3 - 128 10% leak down
4 - 138 7% leak down
I thought the numbers were pretty good. But on cylinder 3 I can definitely feel air coming out of cylinder 4 spark plug hole and a little on cylinder 2 spark plug hole. That confused me since the % is within a acceptable level. also the air from cylinder 4 or 2 does not go into 3.
I took the manifolds off last night and all 4 intake ports and valves are coated with what appears to be slimey oil. the wetness smells of fuel, ( see pictures) all intakes ports look exactly the same. On the exhaust side
cylinder 1 - looks very nasty and oiled up.
cylinder 2 - dry
cylinder 3 (suspect problem cylinder) - is half oil and half dry
cylinder 4 - dry
I briefly spoke to the engine builder and he suggests that all of this is residual symptoms of the float being too high. I am hoping on some feedback to help point me in which direction to go!
