Results 1 to 9 of 9
    near Athens, GA
    Liked: 1096
    Default Upside down photos...
    How's about an IMAGE INVERTER Built into the postings? That way someone could quickly turn those uploaded pix back right side up instead of everyone having to try to look at them UPSIDE DOWN?
    That would be neat. I wonder if the board software has ..or could get an 'add-on' like that.
    Liked: 1371
    That would be good, if possible.
    Or users could just take five seconds to rotate photos before posting — as available on every phone and basic photo program on home computers.
    EDIT: I was wrong about this being a fix.
    Liked: 160
    Is there a way to predict how it will end up? It's correct on my end, then when posted it rotates. I have rotated 90 degrees saved original, selected from Apex and it's still wrong.
    Liked: 1371
    Oh, Thanks.
    That’s a different kettle of fish indeed…
    You might write KR about that.
    Liked: 3794
    Oh, Thanks.
    I've had that same issue also - correctly oriented photos wind up in the wrong orientation in a post. Maybe it has something to do with the photo's aspect ratio?
    Liked: 1371
    Knowing nothing about site software, that seems possible, Dave.
    I also wonder if it happens when any image exceeds a maximum image size, in pixels — though there again, I’m just speculating.
    near Athens, GA
    Liked: 1096
    Oh, Thanks.
    that's exactly why I posted the question. Seems LOTS of people have uploaded pix a couple of times and they are STILL upside down. There MUST be a reason why. Seems to me the easiest answer would be within the software of this board. Looks like it's VBulletin.. I'll see what I can find about it.
    Liked: 1371
    Did a Google search on this. Some claim it’s a “downloaded from iPhone issue,” but software respondents claim it’s related to versions prior to v5.
    None were very confidence-building, or at least not convincingly stated as an absolutely known fix by even the manufacturer.
    This *may*
    be a fix but needs testing to confirm. I am not offering to test it, Sorry, am well beyond burned-out in relying on tech “tools” that have yet to perform as well as any other tool since the first atlatl:
    https://g05.bimmerpost.com/forums/sh....php?t=1759820
    “When your photos exceed the max horizontal width or vertical height, vBulletin will rotate them to fit those dimensions.
    For example, when you upload a portrait sized image from your mobile device and the height exceeds 1600px, then it will rotate the image sideways.”
    Member JoshuaJustice's Avatar
    Dallas, Texas
    Liked: 87
    The reason images get rotated weirdly is because phones have metadata included which indicate rotation direction, and some image editors will preserve that metadata while ignoring it when rendering the image. So you take a landscape photo, phone says "this is rotated 90 degrees", Paint or whatever ignores that and shows you the image sideways - then you rotate it 90 degrees, save it, and then open it in browser... and it's now got 180 total degrees of rotation (90 from metadata, 90 from you rotating it).
    The easiest thing to do with free image software is to open the image in GIMP https://www.gimp.org/ , rotate it if needed, then File->Export as a fresh image (PNG), and call it a day. GIMP exports clear the original metadata. You can also resize/crop in GIMP if that's part of the issue.
There are currently 2 users browsing this thread. (1 members and 1 guests)
  1. ChuckP
