    Coquitlam, B.C.
    Liked: 30
    Default Kent dipstick tube sealing
    Kent Dipstick tub blocking
    Sorry if it's been posted already - but curious on a Kent 1.6 block that still has the factory dip stick tube, are you removing it from top and drilling the tapping and blocking on the top surface ? or on the bottom block hole ?
    Are these press fitted in or o-ring ?
    Don
    Lincoln NE
    press fit
    I've only ever seen them plugged from the top, can't see it really matters
    Savannah, GA (via Montreal)
    Liked: 1003
    I'd hesitate to plug it with JBWeld or similar on a built motor, for not knowing if any fell into the sump.
    (no, I don't say that from experience LOL)
    A press-fit "T" shaped plug will be fine.
    Coquitlam, B.C.
    Liked: 30
    thanx for the replies.... I wasn't near the block when I posted so my brain got me overthinking it last night.
    simply tapped out the insert with a long punch, and tapped it with a 1/8" NPT tap and plugged it up.
    All good.
