Results 1 to 15 of 15
    Florance, AZ
    Liked: 40
    Default Reynard Anti-roll Blade
    Seems I broke my 88SF rear anti-roll bar blade last race - .250" thick... anyone with an extra laying around?
    John H.
    Reynard 88SF
    Detroit, Michigan
    Default Call Keith Averill
    I would get ahold of Keith at Averill Racing Stuff
    Liked: 712
    Default Reynard rear ARB blade
    I do not have them. Try the owners of the Two Doggs "stuff"
    Liked: 313
    Default Roll bar blade
    I have a bunch, not for Reynard but maybe can make it work. Can you give exact sizes?
    Ed
    Orlando Florida 32812
    Liked: 682
    For what I can see of the blade it looks a lot like the rear blade of early 90's Van Diemen.....try Primus ??
    Florance, AZ
    Liked: 40
    Ed
    Quick & dirty... but close:
    John H.
    Reynard 88SF
    Florance, AZ
    Liked: 40
    Default Two Doggs
    Thanks Keith will do.
    John H.
    Reynard 88SF
    Liked: 3889
    ?I had Two Dogg build one for me about 10 years ago... $750
    Florance, AZ
    Liked: 40
    I'm waiting to hear back from Rob. I may have a lead on a NOS in the UK.
    John H.
    Reynard 88SF
    Prescott, AZ
    Liked: 202
    You could always plate both sides to have something to run in May at Podium.
    Florance, AZ
    Liked: 40
    Default Who needs it?
    I'll run without it... unless it broke on the cool down lap I never noticed a change in handling. The last five laps or so were my fastest of the weekend - the last lap was my fastest of the whole weekend.
    John H.
    Reynard 88SF
  15. #12
    Liked: 991
    Default How much
    $750 sems mighty expensive.... Was it gold plated??
  17. #13
    Liked: 712
    Default Arb
    Steve,
    You set up and build just one, in the correct material, that holds up to racing and see what a PIA it is.
    I know I don't what to try it.
  19. #14
    Liked: 1533
    Default No Sway Bars
    Years ago I was the engineer on a Indy Lights car. It was a Dallara. The car was originally designed to run on ovals and it had a massive front front sway bar. We were running the car on road courses and I felt that the bar was way too stiff. Bottom line, I setup our car without any sway bars. I did have springs that were way stiffer than what would be normally used on a car like this but the roll rate at the wheels was very close to what I thought would work. With the very stiff springs I could lower the car a bunch and not worry about pounding the ground. And because the car had ground effects down force we had more down force with the lower ride height.
    The end result was I had a very fast car with an inexperienced driver. We were almost on pace with another team that was dominating the series. The rules in the series we had to run the stock parts, like the sway bars. But the rules did not say you had to use the stock sway bars. Bottom line, I think they may have modified the stock bars in a way to soften them but that the tech people would not easily find. The team in question did wonder what we had done to get the car to go as fast as they were going. My bet is if the tech people had weighed their bars they would have found them to be lighter that the stock part.
    The point that I am trying to make is that you can have a very fast car without any sway bars.
  20. The following 4 users liked this post:
  21. #15
    Liked: 991
    Default point well taken
    Steve,
    Keith I never considered that
There are currently 10 users browsing this thread. (0 members and 10 guests)
