    Member porsche0nut's Avatar
    Ottawa, Canada
    Liked: 22
    Default Van Diemen RF00 Ford with Tools/Equipment/Spares
    For sale is my 2000 Van Diemen, ford engine. Raced in the Ontario Toyo Tires F1600 series in 2021/22/23. Reliable, race-ready car comes with long list of spares, specialty tools, and equipment. Located near Ottawa, ON.
    Price: $25,500 USD (will happily deal in CAD funds for Canadian buyers)
    Engine Rebuild - 2024:
    • full engine rebuild & dyno by Britain West Motorsports
    • new aluminum head, valves
    • new cam bearings
    • new piston rings
    • new clutch
    • resealed oil pump
    • new distributor
    • 0 hrs on engine since dyno & break-in by BW
    Car Details:
    • CASC-OR Annual Tech Inspection 2023, has vehicle logbooks
    • RF00K ChassisLD19 brakes all 4 corners, rebuilt calipers (2022)
    • Master cylinders resealed (2022)
    • New front brake fluid reservoir (2023)
    • Custom drilled rotors (BW)
    • In-car adjustable brake bias
    • New clutch (2024)
    • Re-sealed bellhousing input shaft tunnel to gearbox (2023)
    • New fuel pump (2023)
    • New radiator (2024)
    • Penske 3-way adjustable shocks, rebuilt (2018)
    • In-car adjustable front ARB
    • Rear adjustable ARB
    • AIM Evo4 with Formula Wheel V2 (refreshed by AIM in 2024 and factory tested)
    • Steering quick release
    • Varley red top 30 battery (2020)
    • Custom foam seat (1-piece) with fire retardant cloth upholstery
    • Panosport wheels with Toyo R888 tires (50% life) - 2 sets + spare rim
    Tools & Equipment Included with Car:
    • String alignment bars/camber shims
    • Low car stands
    • High car stands
    • Formula quick jack
    • Engine stand
    • Battery cart with cables
    • Gearset removal tool
    • Dzeus hand tool
    • Clutch alignment tool
    • Cylinder head socket
    • How to build and maintain formula ford 1600 engines book
    Spare Parts:
    • Engine cowling bodywork
    • Right side pod floor bodywork
    • Spare set of wheels with tires (matching car, 50% life)
    • Wheel spacers
    • Extra spare rim (no tire)
    • Starter
    • Distributor and ignition wires
    • Ignition coil
    • Gearsets (see below for ratios)
    • Front ARB pushrod
    • Front pushrod
    • Rear right upper A-arm
    • Front left lower A-arm
    • Throttle cables
    • Rear upright and 2x hubs with bearings
    • Front steering clevice
    • Set of used brake pads
    • Set of Weber jets and spare carb parts
    • Spare springs (250/300/350/400/450/500/550/650)
    • Suspension hardware (AN)
    • Various rod ends, hardware, seals, o-rings, etc
    • Some other misc components
    Expiries (not valid after year shown, good for that year):
    • Shoulder belts: 2026
    • Crotch belts: 2027
    • Lap belts: 2024
    • Fire bottle: ?? Worn off date stamp
    Gearsets:
    1st
    • 16/34
    • 15/30 (in car)
    2nd/3rd/4th
    • 17/29
    • 20/32 (in car)
    • 18/28
    • 19/27
    • 21/29
    • 19/25 (in car)
    • 21/24
    • 24/26 (in car)
    Jonathan
    Van Diemen RF00/Ford
  2. The following 8 users liked this post:
    Ottawa, Canada
    Liked: 22
    Racing season is almost here (for us up north...)!
    Happy to help with transport if needed and within reasonable distance.
    Jonathan
    Ottawa, Canada
    Liked: 22
    this isn't a bump... just a light tap to let you know I'm there...
    Jonathan
    Glendale, Arizona
    Liked: 503
    Great deal
