I'm rebuilding a Lola T540 (Kent/Hewland), it will probably be used for autocross initially. Maybe CF down the road. Any recommendations on a clutch setup?
You’re in luck. You’re in Texas and so is Scott Young. He can set you up with everything you need. White or buff spring Tilton clutch, with an annular slave setup.
https://www.sy-gearboxes.com/
You may want to ask Scott about an integral first gear too is you are using for Autocross.
